Page Served to you by
Servers Managed and
Maintained by
Nixperience Pte Ltd
Loading...
Page 1 of 6 12345 ... LastLast
Results 1 to 50 of 300
Thread: Suzuki DRZ400SM - Performance Parts, Accessories & Servicing Packages
  1. #1
    Unique_Motorsports
    is online!
    Advertiser Unique_Motorsports's Avatar
    Apr 2007
    Location
    1 Kaki Bukit Ave 6 #02-54/55 Autobay @ Kaki Bukit (S)417883 / 48 Toh Guan Road East #02-140(S)608586
    13,210
    1 Post(s)
    Default Servicing Packages for Suzuki DRZ400SM
    Link to Servicing Packages for Suzuki DRZ400SM
    Tyres for Suzuki DRZ400SM
    Link to Tyres for Suzuki DRZ400SM
    Sprockets + Chain Kit
    DID X Ring Chain + JT sprockets: $200
    DID X Ring Chain + Original Sprockets: $260
    DID X Ring Chain + DRIVEN sprockets: $280
    DID X Ring Chain + ISA Sprockets: $280
    DID X Ring Chain + AFAM Sprockets: $280
    DID X Ring Chain + Supersprox Sprockets: $280
    EK MVXZ Coloured X Ring Chain + DRIVEN/ISA/AFAM/Supersprox sprockets: $340
    Air Filter
    K&N: $105
    BMC: $106
    Pipercross $55
    Street Legal Exhaust System
    Scorpion Full System: $1080 (New Model)
    Delta Full System: $1050
    WRP slip on aluminium : $890
    WRP slip on Titanium: $1090
    WRP slip on Titanium / carbon tip: $1290
    Leovince slip on: $694.80 (UP $772)
    Leovince Headers: $481
    Leovince Full System: $1127.70 (UP$1253)
    Yoshimura Titanium Oval Full System: $1880
    Brakes/ Control
    STAR Performance Brake lines: $110 (UP $130)
    HEL brake lines + installation: $140
    Venhill brake lines + installation: $230
    Brake pad (WP, Gold Fren, Fizz Power, EBC, BRAKING etc): $25 to $75
    BRAKING Front SK Disc 320mm: $510
    BRAKING Caliper bracket for 320mm brake disc for OEM caliper: $180
    BRAKING Caliper bracket for 320mm brake disc for BRAKING caliper: $180
    BRAKING Rear Disc: $240
    BRAKING 16mm Master Pump with lever: $470
    BRAKING 16mm Master Pump with lever + BRAKING Reservoir:$ 480
    BREMBO RCS15 Master Cylinder: $550
    BREMBO RCS19 Master Cylinder: $550
    BREMBO 16mm Master Pump Assembly: $288
    BREBMO 16mm Master Pump Assembly + Clutch Assembly: $388
    DRIVEN Velocity handlebar $110
    DRIVEN Meteor handlebar: $150
    Renthal standard handlerbar (7/8): $130
    Renthal FATBAR: $180
    Renthal handlebar pad: $25
    AFAM Xbar $130
    AFAM Bigbar $180
    ASV F-1 Unbreakable Brake Lever :$85
    ASV F-1 Unbreakable Clutch Lever: $85
    ASV F-1 Unbreakable Brake and Clutch Lever Pair Pack: $135 (UP $170)
    ASV F-3 Unbreakable Brake Lever :$120
    ASV F-3 Unbreakable Clutch Lever: $120
    ASV F-3 Unbreakable Brake and Clutch Lever Pair Pack: $200 (UP $240)
    ASV C-5 Unbreakable Brake Lever :$150
    ASV C-5 Unbreakable Clutch Lever: $150
    ASV C-5 Unbreakable Brake and Clutch Lever Pair Pack: $240 (UP $300)
    Zeta Brake Lever: $95
    Zeta Clutch Lever: $95
    Zeta Amor Hand Guards: $180
    Motovation Products
    - Motovation fork and axle sliders: $110
    - Motovation heavy balancer with barend sliders : $75
    - Motovation IMS Footpegs Sliders: $65
    Performance Upgrades
    JD Jettings for DRZ400SM: $180
    JD Jettings for DRZ400SM FCR 39mm carburetor: $180
    Keintech Fuel screw: $35
    3 x 3 modifications: $35
    PAIR removal: $35
    ThumperTalk Manual Cam Chain Tensioner: $95
    Pivot Voltage Stabliser (made in Japan) $90
    Pivot Voltage Stabliser with Super Earth Cables (made in Japan) $148
    Revtec Impedance Stabiliser: $90
    Broquet Fuel Charger B/2T: $59
    Broquet Fuel Charger B/3T: $80
    Ohlins fork springs + dust covers + oil seals + fork oil: $320
    Ohlins fork springs + dust covers + oil seals + Ohlins fork oil: $400
    Ohlins rear shocks with installation: $1364
    Others:
    Trial Tech Vapor Speedometer: $350
    Trail Tech Striker: $350.00
    Trial Tech Vector: $320.00
    Trial Tech Endurance Speedometer: $220
    LED signal lamps: $50 to $75
    LED tail lamp Acerbis red: $75
    LED tail lamp Acerbis white: $110
    Safari Fuel Tank 17 litres: $890
    Safari Fuel Tank 28 litres: $1190
    Samco Sports Silicone Hoses: $161 (DIY)
    Samco Sports Silicone Hoses + installation + Engine Ice: $211
    MR Digital voltmeter $55
    Dynamyx Digital Voltmeter: $55
    Stebel Twin Tone Horns (2pcs) + relay + installation: $65
    Stebel Nautilus Compact Horn (1pc): $85
    Hella Disc-Type Horns (2pcs) + relay + installation: $65
    Hella Twin Tone Horns (2pcs) + relay + installation: $65
    BLU Horn + Relay $45
    KTM 200 Headlight Assembly: $210
    KTM 200 Front Fender: $90
    Acerbis Supermoto handguard: $210
    Acerbis Multiplo "E" handguard: $230
    LED Vision headlight: $120
    WRP Wide Foot Pegs: $190
    Rough & Road 591 Rally Rack: $300
    IMS "Super Stock" Foot Pegs: $95
    IMS "Pro-Series" Foot Pegs: $145
    DRC Tail Lamp (Fender Eliminator) $145
    ThumperTalk Case Shields Ignition / Clutch Combo Pack $70 with installation
    DRIVEN coloured sprocket nuts $45
    Brembo Upgrade Kit
    Brembo RCS 15 $550.00
    Brembo Cast 4 Pad Radial Mount Caliper + QTM bracket: $650.00
    Brembo 320mm Full Floating Rotor: $520.00
    *Please check 1st post of this thread for latest updated pricelist. Thank you.
    Standard Servicing Packages (Engine Oil + Oil Filter)
    $48 Package
    - 2x Chessa Chex 9000 10W50 Engine Oil
    - 1x Suzuki DRZ400 Oil filter
    $54 Package
    - 2x Belray Thumper 10W40/ 15W0 Engine Oil
    $56 Package
    - 2x Motul 5100 10W40/ 15W50 Engine Oil
    $60 Package
    - 2x Maxima Extra 15W50 Engine Oil
    $60 Package
    - 2x Silkolene Pro 4 10W50 Engine Oil
    $68 Package
    - 2x Motul H-Tech 100 15W50 Engine Oil
    - 1x Suzuki DRZ400 oil filter
    $69 Package
    - 2x Belray EXS 10W50/ 5W60 Engine Oil
    $74 Package
    - 2x Motul 300V 10W40/ 15W50 Engine Oil
    Standard Servicing Packages (Engine Oil + Oil Filter + Spark Plug)
    $58 Package
    - 1x Denso Regular Spark Plug
    $64 Package
    - 2x Belray Thumper 10W40/ 15W50 Engine Oil
    $66 Package
    $70 Package
    $70 Package
    $78 Package
    - 2x Motul H-Tech 100 10W40 Engine Oil
    $79 Package
    $84 Package
    - 2x Motul 300V 15W50 Engine Oil
    Standard Servicing Packages (Engine Oil + Oil Filter + Spark Plug + Engine Ice)
    $118 Package
    - Engine Ice High Performance Coolant
    $124 Package
    $126 Package
    $130 Package
    $130 Package
    $138 Package
    $139 Package
    $144 Package
    Full Servicing Packages (Engine Oil + Oil Filter + Spark Plug + Engine Ice + Engine Flush + Engine Protector + Gas Treatment)
    $186 Package
    - OWS 210 Engine Flush
    - OWS 220 Engine Protector
    - OWS 360 Gas Treatment
    $192 Package
    $194 Package
    $198 Package
    $198 Package
    $206 Package
    $207 Package
    $212 Package
    James Dean (JD) Jetting - Your source for high performance jet kits
    JDS005 - Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04) #53
    $160 - Cash & carry
    $180 - With installation
    James Dean designed the JDJetting kits so that you don't have to be an expert to get professional high performance results!! Even better, technical support is provided.
    The James Dean custom jetting kit is designed to improve throttle response throughout the range by using specially made multi-taper needles. These are based on the most popular settings used by new generation MX and off-road riders around the globe and the results are impressive.
    Exceeds the performance of the popular EMN, DTM, and other standard factory needle options
    Low and High altitude custom designed triple taper needles
    Main Jets included
    Spare Needle Clip
    Dyno Tested
    Developed and tested from sea level to 12000ft elevation
    You can’t buy this from any OEM factory or aftermarket. It’s JD’s prescription for the headpipe blues.
    This kit fits Suzuki DRZ400S/SM(all), DRZ400E (Calif) (00-09) and Kawasaki KLX400SR (03-04)
    JDFM050 - Keintech Fuel Screw for Suzuki DRZ400S/SM #86
    $35 with installation when purchased together with JD JETTING HIGH PERFORMANCE KIT
    Quote Originally Posted by biting_point View Post
    This JD kit is no joke..
    will eliminate your backfiring problems and giving your the power and same time controlling the FC..
    Good investment for those that wanna get some power and save fuel at the same time..
    the jets in this kit is machine is made to be plug and play for SGP's climate.. no need to play around with the sizes at all.. all you needa do after installing is to tune the air/fuel mixture screw to get a good setting..
    with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring..
    My current FC is 25.3km/L.
    Quote Originally Posted by SparkerS1 View Post
    yeap, the jettings help alot, my friend's drz can feel the diff, i test ride also can feel it
    Quote Originally Posted by konspire View Post
    oh, did u? i was contemplating to come at 10am but then got work to do in the office so i finish it n came at 11. i did eo chg too and accidentally put in the JD jettings. was thinking to do jettings at abboy, then wat the heck. i put bmc air filter alrdy n bike feels overchoke wif air. i oso realise that 3x3 was not done yet. so i just hv the scorpion fs not fully optimised.
    well, didn't regret though. after setting, the bike feeeeeeeeellsss great. like flying alrdy n the ah pui mechanic was happy doing wheelies in front of the shops .
    nxt project, chg decals.
    Trail Tech - Innovative Offroad Solutions
    Vapor ATV/motorcycle speedometer tachometer:
    The Vapor motorcycle speedometer main feature is a large, well lit RPM tachometer graph. Vapor is useful as a motorcycle speedometer and side by side utility vehicle or ATV speedometer (or any machine with a wheel.) Vapor's large digital tachometer bar graph is easy to read. The digital gauge has many other useful features like time keeping, engine temperature, resettable distance, and odometer. Vapor's tachometer shift lights and temperature lights are great to warn about potential mechanical problems while there is still time to react. The built in stop watch and hour meter is perfect for race training. The adjustable distance setting can be used on those tough enduro courses.
    Vapor is enough to replace an entire instrument cluster on your dashboard. Speed, time, distance and tach - Vapor has it covered. If indicator lights are required for dual-sport and supermoto road ready bikes, Vapor is available with a stylish indicator dashboard accessory. If rougher treatment is expected, the Vapor speedo has a full line of model-specific aluminum billet guards and protectors for motocross, enduro, rallies, and trials.
    A combined effort from experts in software, electronics, and mechanical design – each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
    - The latest concept in motorsport on-board computation. A combined effort from experts in software, electronics, and mechanical design - each feature of this 4th generation product is carefully crafted and constructed with the offroad enthusiast in mind.
    - Speedometer
    - Tachometer
    - Temperature
    - Distance
    - Clock
    - Power
    - Model Specific Kits
    - More Features
    Pricing:
    ThumperTalk Manual Cam Chain Tensioner (Suzuki DRZ400SM & Hayabusa 1300)
    Save yourself thousands in costly repairs! ThumperTalk Manual Cam Chain Tensioners (MCCT) are designed to replace the automatic and hydraulic tensioners found on today's hi-performance 4-stroke engines.
    Factory automatic adjusters can back out when the throttle is suddenly closed at higher rpms. This allows the cams to momentarily go out of time and can result in bent valves and/or serious engine damage! Hydraulic tensioners have a tendency to put too much tension on the chain guide under high rpm/high oil pressure conditions, resulting in premature cam chain wear.
    Installation of a ThumperTalk Manual Cam Chain Tensioner will allow you to maintain the proper, constant cam chain tension necessary for reliable hi-performance riding and it will not backout.
    This is a high quality product, proudly made in the USA. There are thousands of these units in service, so buy in confidence!
    - Precision machined billet aluminum body
    - O-ring seals, both on the body and threads
    - Stainless steel adjuster bolt & locknut
    - Clear anodized body for long lasting good looks
    Pricing: $95 with installation
    Brembo Upgrade Kit
    STAR Brake lines: $110.00
    All of above items: $1730 (UP $1830)
    Cylinder Works 434cc Big Bore Kit
    Suzuki DRZ400SM 2000-2011
    Price $999.00
    Yoshimura Engine Mount
    Suzuki DRZ400SM Price: $160.00
    CNC Machined from 6061 T6 alloy
    Very strong. Lighter than OEM stamped version
    Laser etched Yoshimura logo
    Distinctive Yoshimura Magnasonian finish
    Kit includes front and top engine mounts
    Yoshimura Case Savers
    Suzuki DRZ400SM $230.00
    Crafted from 6061 T6 alloy
    Distinctive Yoshimura logo
    Protect the sensitive water pump and ignition cover in the event of a crash
    Yoshimura Rear Brake Clevis
    Suzuki DRZ400SM Price $100.00
    Stronger and lighter than the stock unit
    Smoother brake action
    Better brake pedal feel
    CNC machined from 6061 T6 alloy
    Yoshimura Engine Timing Plug Kit
    Suzuki DRZ400SM Price :$88.00
    Include small TDC plug and crank shaft inspection plug
    Facebook Pictures for Suzuki DRZ400SM http://www.facebook.com/pages/Unique...4947105&type=1
    Please check 1st post of this thread for latest pricing. Thank you.
    [FAQ] All you need to know abt Suzuki DRZ400SM = http://www.singaporebikes.com/forums...uzuki-DRZ400SM
    Regards
    Sales Team Unique
    (KB 68446378 / TG 65154978 / WL 63392178)
    Cash/ NETS/ Mastercard/ VISA/ Diners/ JCB/ AMEX - 0% Interest Free Instalment Plans available for DBS, POSB, Diners & UOB Credit Cards Holders
    Opening hours: 10am to 8pm (Mon to Sat)
    www.uniquemotorsports.com.sg
    *Unique Motorsports Forum*
    Driven Racing Research & Development USA - Highest Quality American-Made Products!
    *Servicing Packages for Super 4/Vtec I/II/III/REVO*
    Looking for any services or promotions offered by Unique Motorsports?
    Simply click and view them at:
    Sitemap of Unique Motorsports
  2. #2
    SparkerS1
    is not the only
    SBF Moderator SparkerS1's Avatar
    Jan 2007
    Location
    Northeast
    12,200
    3 (100%)
    34 Post(s)
    1 Thread(s)
    Quote Originally Posted by Unique_Motorsports View Post
    Tyres
    Pirelli Diablo: $290 (R150)
    Pirelli Diablo: $290 (R160)
    Dunlop Alpha 10: $310 (R150)
    Dunlop Alpha 10: $320 (R160)
    Michelin Pilot Power: $350 (R150)
    Michelin Pilot Power: $370 (R160)
    Brakes
    EBC brake pad: $155
    just asking, the tyres includes the front one for the price listed?
    the EBC brake pad is $155 for front n rear?
    Yamaha RXZ, Kawasaki ZX KR150, Yamaha Spark135, Honda CB400 REVO NC42, Suzuki DRZ400SMK8, Aprilia RS125, Suzuki GSXR600K9
    Facebook HONDA CB400 REVO
  3. #3
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Tyres stated are for front and rear.
    EBC for Suzuki DRZ400SM: $55 each. Front and Rear: $110.
    Regards
    Sales Team Unique
  4. #4
    SparkerS1
    is not the only
    Jan 2007
    Location
    Northeast
    12,200
    3 (100%)
    34 Post(s)
    1 Thread(s)
    thanks to unique.
    brake hose n air filter done
    still got a long list to go
  5. #5
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    thanks to unique.
    Thank you for your support and feedback.
    Regards
    Sales Team Unique
  6. #6
    fiz
    L Plate fiz's Avatar
    Feb 2007
    41
    2 Post(s)
    i have change to a full system pipe, how much it cost for TUNING??
    & how much it cost for checking my alignment, braking, clutch cable etc.??
    thanx..
  7. #7
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by fiz View Post
    thanx..
    You have a PM.
    Regards
    Sales Team Unique
  8. #8
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    We are proud to introduce you the outstanding range of Samco Sport, direct replacement, high-performance silicone coolant hose kits for motorcycles. The Samco Sport hose kits are designed as a direct replacement for a wide range of motorcycles both in motorsport and fast road use. Superb integrity and superior performance reduces the risk of component failure and enables higher temperatures and pressures to be maintained with complete confidence when it matters, under pressure!
    With superlative quality proven on the race and rally circuits worldwide, Samco Sport silicone hoses are the first choice of engineers demanding total reliability under competition and fast road conditions. They are available in 7 high gloss colours; Red, Blue, Black, Green, Yellow, Purple and Orange. They can either be matched to bike colour, add a custom look or ordered in black to keep an authentic appearance. All Samco products are manufactured in the UK and we are working closely with them to expand their product range. If there is a kit you feel need’s adding to the list sooner rather than later please contact us and we can look into it.
    *Hoses fitted are shown on a Ducati 916
    Colours available: Red, Blue, Black, Green, Yellow, Purple and Orange
    Special Offer (While Stock Last!)
    $348 PACKAGE (Usual Price $480) -
    Samco Sports Silicone Hoses Package for Honda CB400 Vtec I/II/III/Revo:
    - Samco Sport Silicone Hoses x 7
    - Removal of old rubber hoses x 7
    - Installation of Samco Sport hoses x 7
    - Radiator flush
    - Workmanship
    Colours available (Ready stock): Red or Blue
    Other colours (including Ver S/R): To order 4 to 8 weeks for delivery
    $188 PACKAGE (Usual Price $280) -
    Samco Sports Silicone Hoses Package for Suzuki DRZ400 SM:
    - Samco Sport Silicone Hoses x 3
    - Removal of old rubber hoses x 3
    - Installation of Samco Sport hoses x 3
    - Radiator flush
    - Workmanship
    Other colours: To order 4 to 8 weeks for delivery
    Regards
    Sales Team Unique
  9. #9
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Brembo Cast 4 Pad Radial Mount Caliper for Suzuki DRZ400SM
    $650 PACKAGE:
    - Brembo Cast 4 Pad Radial Mount Caliper
    - Brembo Brake Pads
    - Caliper Relocator
    - Motul 5.1 Brake Fluid
    - Installation of Brembo Cast 4 Pad Radial Mount Caliper
    Regards
    Sales Team Unique
  10. #10
    SparkerS1
    is not the only
    Jan 2007
    Location
    Northeast
    12,200
    3 (100%)
    34 Post(s)
    1 Thread(s)
    wow, so many goodies for DRZ, i go see liao more surprised, even more stuffs for DRZ, for u
  11. #11
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Regards
    Sales Team Unique
  12. #12
    h@he
    Class 2A h@he's Avatar
    May 2005
    Location
    East Side
    733
    ready stock for braking rear disc???
  13. #13
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by h@he View Post
    Yup. Ready stock available for DRZ.
    Regards
    Sales Team Unique
  14. #14
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    BRAKING BRAKE DISC + BREMBO CALIPER
    DRIVEN BLACK SPROCKET + EK RED COLOUR X RING CHAIN
    Regards
    Sales Team Unique
  15. #15
    SMD81
    L Plate SMD81's Avatar
    Feb 2009
    32
    Hi Boss,
    Right now my bike is still in running in period..this will be my first oil change...
    so since i need to use only mineral oil during running in ...which package do u recommend?...just wanna change mineral oil n oil filter btw...
    thanx...if can i wanna come by later aft work..
  16. #16
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by SMD81 View Post
    Hi Boss,
    You have a PM.
    Regards
    Sales Team Unique
  17. #17
    SMD81
    Feb 2009
    32
    You have a PM.
    Very prompt reply...ok den...i will come down to ur defu lane branch later this evening...
    THANX!
  18. #18
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    THANX!
    Sure. Cya.
    Regards
    Sales Team Unique
  19. #19
    SMD81
    Feb 2009
    32
    went yesterday evening to Defu Lane Branch to change mineral oil & oil filter..
    quite happy with the service given...
    Thanx Alex...
  20. #20
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Thanx Alex...
    Regards
    Sales Team Unique
  21. #21
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Promotion ended.
    Regards
    Sales Team Unique
  22. #22
    kurarensu
    is cute ^^
    SBF CB400s kurarensu's Avatar
    Jul 2006
    Location
    Planet Earth
    9,039
    2 (100%)
    got no yoshi for drz??
    Lousy Noob Rider
  23. #23
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by kurarensu View Post
    Yes, there are.
    Regards
    Sales Team Unique
  24. #24
    Blackbeauty69
    SBF Lady Riders Blackbeauty69's Avatar
    Mar 2007
    Location
    Khatib & Toa Payoh
    1,171
    any package for drz wit iridium spark plug??
    My Motard make wonders
  25. #25
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by Blackbeauty69 View Post
    You have a PM.
    Regards
    Sales Team Unique
  26. #26
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    $160 - Cash & carry
    Main Jets included
    Spare Needle Clip
    Dyno Tested
    Regards
    Sales Team Unique
  27. #27
    norishimu
    TeePee norishimu's Avatar
    Dec 2004
    Location
    Pasir Ris
    3,084
    u hv aftermarket tail light fr drz?
  28. #28
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by norishimu View Post
    Yes we do.
    Regards
    Sales Team Unique
  29. #29
    norishimu
    Dec 2004
    Location
    Pasir Ris
    3,084
    noted.. will b dropping by wed.. btw do u do 3x3 air box mod with JD jettings? as well as PAIR removal..
  30. #30
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    You have a PM.
    Regards
    Sales Team Unique
  31. #31
    norishimu
    Dec 2004
    Location
    Pasir Ris
    3,084
    can u install MCCT(manual cam chain tensioner) for drz? I have the mcct in hand to replace acct.
  32. #32
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Sure. Do drop by when free.
    Regards
    Sales Team Unique
  33. #33
    mach49
    L Plate
    Apr 2006
    Location
    Woodlands
    29
    My DRZ's total mileage is 8000km, what kind of servicing do you recommend? Price? thank you very much.
  34. #34
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by mach49 View Post
    You have a PM.
    Regards
    Sales Team Unique
  35. #35
    biting_point
    is not getting paid as
    SBF Moderator biting_point's Avatar
    Oct 2003
    Location
    สิงคโปร์, EW5
    7,424
    6 (100%)
    6 Post(s)
  36. #36
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Thank you for your feedback.
    Regards
    Sales Team Unique
  37. #37
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    - Speedometer
    - Tachometer
    - Temperature
    - Distance
    - Clock
    - Power
    - More Features
    Pricing:
    Vapor Kit - DRZ400SM: $320 with installation (Speedometer/ RPM etc)
    Motorcycle Endurance Kit: $210 with installation (Speedometer only)
    Regards
    Sales Team Unique
  38. #38
    SparkerS1
    is not the only
    Jan 2007
    Location
    Northeast
    12,200
    3 (100%)
    34 Post(s)
    1 Thread(s)
    with it, your DRZ will not run lean after you install aftermarket exhaust and no more backfiring...
  39. #39
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Regards
    Sales Team Unique
  40. #40
    nastyash7
    P Plate
    Feb 2004
    56
    im getting my drz sm k9 this coming fri.....thinking of changing to lv slip on , aftmarket tailight , hel brake line , sliders......do u have them in stock and the price if possible?? do u guys do pair removal??
    thanks
    Skinny man with skinny bike!!!!
  41. #41
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by nastyash7 View Post
    thanks
    You have a PM.
    Regards
    Sales Team Unique
  42. #42
    PeRiLoUs
    TeePee PeRiLoUs's Avatar
    May 2007
    Location
    Tampines
    2,638
    1 (100%)
    if i install the JD jetting, i have to install the JD JETTING HIGH PERFORMANCE KIT as well?
    or installing the JD jetting enough?
    Looking for FBC plate superstock rxz 135 to to trade with my FBC plate nouvo elegance, tip top condition. PM me.
  43. #43
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by PeRiLoUs View Post
    You have a PM.
    Regards
    Sales Team Unique
  44. #44
    adamant1988
    bored
    Class 2 adamant1988's Avatar
    Aug 2007
    1,461
    1 (100%)
    1 Post(s)
    today drop by ur defu branch to do the jd kits, well was nt a very good experience. tuning wise, so-so only.
    one last kiss before i go.
  45. #45
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by adamant1988 View Post
    Regards
    Sales Team Unique
  46. #46
    yoimen
    Class 2B yoimen's Avatar
    Jan 2008
    Location
    Up North
    254
    Hi how much wud it b if jus to purchase the Keintech Fuel Screw for Suzuki DRZ400S/SM #86? tks...
  47. #47
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by yoimen View Post
    You have a PM.
    Regards
    Sales Team Unique
  48. #48
    zeEbra
    L Plate
    Jan 2009
    6
    hey there,do u sell radiator shield for drz?and if i wanna include samco radiator hoses,how much for everything?thx!!
  49. #49
    Unique_Motorsports
    is online!
    Apr 2007
    Location
    13,210
    1 Post(s)
    Quote Originally Posted by zeEbra View Post
    You have a PM.
    Regards
    Sales Team Unique
  50. #50
    Pyro1505
    L Plate
    Aug 2009
    24
    how much additional cost i have to pay to upgrade to iridium spark plug?
Tags for this Thread
