Results 1 to 23 of 23
Thread: Amsoil Fully Synthetic Engine Oil
  1. #1
    uberstore
    Advertiser uberstore's Avatar
    Oct 2006
    Location
    Singapore Bikes Forum
    275
    1 Post(s)
    AMSOIL Applauded for Extended Drain Technology
    AMSOIL founder A.J. Amatuzio coined the phrase "extended drain intervals" back in 1972 with the introduction of AMSOIL 10W-40 Synthetic Motor Oil, formulated for 25,000-mile/one-year drain intervals. Not only was AMSOIL motor oil the first synthetic oil to pass American Petroleum Institute (API) service requirements, AMSOIL INC. was the only motor oil company promoting oil drains beyond 3,000 miles.
    Today, motorists are still bombarded with propaganda from the major oil companies promoting 3,000-mile oil changes. However, the industry is slowly but surely coming around. Vehicle manufacturers typically suggest 5,000- to 7,500-mile intervals in their owners manuals, and many manufacturers have also started incorporating oil life monitors into their vehicles, allowing motorists to safely extend drain intervals by monitoring oil life and alerting drivers when the oil needs changing. Competing oil companies have also begun marketing their own synthetics, some claiming service lives extending beyond 3,000 miles.
    Lubes-n-Greases Automotive Editor David McFall, once with the American Petroleum Institute recently tackled the issue of extended drain intervals in his March column, criticizing the standard 3,000-mile oil change and referring to the American motor oil market as "shackled."
    "In Europe the average engine oil drain interval for current gasoline-fueled cars is about 10,000 miles," explains McFall. "In the United States, indicates the Automotive Oil Change Association, the average drain interval followed by most drivers is somewhat less than 5,000 miles?one-half of Europe's.
    "Every year in the United States, this too-short drain interval results in the unneeded production of 300 million to 400 million gallons of engine oil; excess consumer expenditures of around $1.5 billion; and tens of millions of unnecessary oil changes."
    Not only are these unnecessary oil changes an expense to consumers, explains McFall, but they have an environmental cost as well. "The added environmental cost of having an average 5,000-mile oil drain interval (instead of 10,000 miles, as in Europe) may be nearly 100 million gallons of engine oil being dumped, untreated, into the U.S. environment annually."
    McFall's examination of Mobil 1, Shell and AMSOIL demonstrates the differences among companies who are shackled to the current system and one who isn't.
    According to an ExxonMobil spokesperson, "Car owners should follow the oil change intervals specified by the manufacturer. We believe it is inappropriate to recommend drain intervals that may conflict with those set forth by the car manufacturer's specifications."
    "Here, in a nutshell," says McFall, "is this observer's take on ExxonMobil's and the oil industry's 'owner's manual' position: It is designed solely to increase motor oil sales." He backs it up by mentioning that Mobil 1 SuperSyn motor oil claims to meet European ACEA A5 and B5-02 specifications, two specifications intended to extend oil drain intervals. "If the oil can be used in Europe for extended drain intervals, why doesn't ExxonMobil notify U.S. consumers of that capability?" asks McFall.
    Although Shell Oil Products, owner of Pennzoil-Quaker State, has broken through the shackles enough to offer an API unlicensed oil specially formulated for higher mileage engines, they make no mention of a recommended drain interval, preferring instead to avoid the issue and keep consumers in the dark.
    McFall marvels at the success of the independent motor oil company that offers drain intervals up to 11 times longer than the standard interval offered by conventional oils, saying, "Purists can sniff that AMSOIL's data isn't derived from a controlled field study, but the sheer mountain of vehicle miles over three decades, and the absence of any confirmed performance, wear or maintenance issues, speaks volumes."
    McFall sums up his column by highlighting the true value of AMSOIL Synthetic Motor Oil, stating the cost may be "two to three times higher than most retail conventional oils but if you can securely count on a 15,000- to 25,000-mile drain interval, it's a flat-out bargain, not to mention providing a clear environmental bonus."
    So, what is it that allows AMSOIL motor oils to be used for extended drain intervals, while other oils must be changed significantly sooner? First, the synthetic base stocks with which AMSOIL motor oils are formulated are worlds apart in quality compared with conventional base stocks. The synthetic molecules are uniform in size and shape, resisting the vaporization that boils off the smaller molecules of conventional motor oils and leaves behind a thicker, higher viscosity oil that compromises engine protection. AMSOIL motor oils surpass even the most stringent European volatility standards, providing superior protection for extended drain intervals.
    Second, AMSOIL spares no expense when it comes to additives, selecting the most robust additive packages on the market. These additives keep AMSOIL motor oils shear stable, resist the degrading effects of varnish and sludge, keep engine components clean and deposit-free and effectively resist rust, corrosion and foaming.
    By using only the highest quality synthetic base stocks and additives available, AMSOIL motor oils are capable of extended drain intervals, all while maintaining performance, providing long-term wear protection and fuel economy, keeping engines clean and deposit-free, providing cold weather starts and protecting against rust and corrosion.
    For a copy of David McFall's column on AMSOIL, contact Lubes-n-Greases at (703) 536-0800 or see it below in read-only PDF format.
    Lubes 'n' Greases logo is a Registered Trademark of LNG Publishing Company, Inc.
    The following articles are presented for online viewing only.
    Read The Articles:
    Lubes N Greases Article March 2003 (157k PDF)
  2. #2
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    AMSOIL Synthetic Motorcycle Oils have been reformulated with new high performance additive technology that provides even greater multi-functional benefits for the special requirements of motorcycle applications. These independent and exclusive new AMSOIL formulations provide second-to-none viscosity protection for hot-running American and foreign motorcycle engines, transmissions and primary chaincases. Performance specifications include:
    Performance Formulated
    AMSOIL Synthetic Motorcycle Oils contain a robust dispersant/detergent package, making them ideal for use in high-stress motorcycle engines. The dispersant/detergent additive packages allow them to stay serviceable longer than other oils.
    Wear Protection
    AMSOIL Synthetic Motorcycle Oils are specially formulated with high levels of zinc and phosphorous for superior protection of cam lobes and other high pressure components. In fact, AMSOIL Synthetic Motorcycle Oils contain more zinc and phosphorous than other popular motorcycle oils (see graph). AMSOIL Synthetic Motorcycle Oils leave a wear scar up to 40 percent smaller than the scars left by other popular brands in the ATM D4172 Four-Ball Wear Test.
    Some motorcycle and ATV transmissions and engines share an oil sump, so the engine oil also provides wear protection to the transmission gears. AMSOIL offers superior wear protection to transmission gears, which are often subject to high surface pressure and rotation speed. It also promotes proper wet clutch performance
    Friction Modifier Free
    AMSOIL Synthetic Motorcycle Oils contain no friction modifiers, making them ideal for motorcycle and ATV engines. The friction modifier free formulation of AMSOIL ensures dependable starting, smooth running, good fuel efficiency, desirable stall speeds and clutch compatibility.
    Temperature and Performance
    AMSOIL High Performance Synthetic Motorcycle Oils provide superior performance. Their outstanding low temperature fluidity ensures easy cranking, dependable starting and fast post-startup protection. The superior high-temperature protection ensures the formation of a clean, protective film of oil between working parts during high-temperature, high-stress operations.
    High-temperature operations often lead to the thermal degradation and oxidation of conventional oils, which leads to the formation of deposits, sludge and varnish. AMSOIL withstands thermal degradation and oxidation at higher temperatures than conventional oils do, ensuring clean, dependable performance in high-stress, high-temperature operations. Especially in air-cooled engines.
  3. #3
    ashenZ
    SBF CB400s ashenZ's Avatar
    Jan 2003
    Location
    ~Sillypore~
    3,546
    i tink u need to provide us with the pricing for each grade
    '01 - Honda Repsol
    '09 - Vespa GTS300 Super
    '12 - Yamaha FZ1-N
  4. #4
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    For your reading pleasure
    Silly Myth about Synthetic Oil.
    An Article by Ed Newman First Published in "National Oil and Lube News"
    IT'S A FACT OF LIFE that behavior is strongly influenced by what people believe, whether true or not. Numerous examples from history bear this out. For example, sailors were once fearful of sailing outside the sight of land less they would fall off the edge of the world. In the early 19th century, the train was considered dangerous because it was believed that if you traveled faster than 25 miles per hour, you would be traveling too fast to breathe. At a later date, the New York Times warned that electric light may cause blindness. Microwave ovens, automobiles and airplanes have had equally vociferous opponents.
    Looking back, it is easy to laugh at some of these things people so firmly believed. But these people were not stupid. They were simply misinformed. In many instances they had simply drawn conclusions before all the facts were in. How easy it is to make the same mistake today. In our own time, synthetic motor oils have been the object of many misconceptions held by the general public. Many people, including some mechanics who ought to know better, have been misled by persistent myths that need to be addressed.
    Parameters of the Debate
    Synthetic lubricants are fuel efficient, extended life lubricants manufactured from select basestocks and special purpose additives. In contrast to petroleum oils which are pumped from the earth and refined, synthetics are custom-designed in the laboratory, with each phase of their molecular construction programmed to produce, in effect, the ideal lubricant.
    In responding to objections most commonly raised against synthetics it is important to establish the parameters of the debate. When speaking of synthetic motor oils, this article is defending the synthetic lubricants which have been formulated to meet the performance standards set by the American Petroleum Institute (API). (The first such synthetic motor oil to meet these industry-accepted tests for defining engine oil properties and performance characteristics was AMSOIL 100% Synthetic 10W-40 in 1972.)
    Many people with questions about synthetics haven't known where to turn to get correct information. Is it super oil or snake oil? Some enthusiasts will swear that synthetics are capable of raising your specialty car from the dead. On the other hand, the next fellow asserts that synthetics will send your beloved car to an early grave. Where's the truth in all this?
    In an effort to set the record straight, we've assembled ten of the more persistent myths about synthetic motor oils to see how they stack up against the facts.
    Myth #1: Synthetic Motor Oils Damage Seals.
    Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
    Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
    Myth #2: Synthetics Are Too Thin To Stay In The Engine.
    Untrue. In order for a lubricant to be classified in any SAE grade (10W-30, 10W-40, etc) it has to meet certain guidelines with regard to viscosity ("thickness").
    For example, it makes no difference whether it is 10W-40 petroleum or 10W-40 synthetic, at -25 degrees centigrade (-13F) and 100 degrees centigrade (212 degrees F) that oil has to maintain a standardized viscosity or it can't be rated a 10W-40.
    Myth #3: Synthetics Cause Cars To Use More Oil.
    Untrue. Synthetic motor oils are intended to use in mechanically sound engines, that is, engines that don't leak. In such engines oil consumption will actually be reduced. First, because of the lower volatility of synlubes. Second, because of the better sealing characteristics between piston rings and cylinder walls. And finally, because of the superior oxidation stability (i.e. resistance of synthetics against reacting with oxygen at high temperatures.)
    Myth #4: Synthetic Lubricants Are Not Compatible With Petroleum.
    Untrue. The synthesized hydrocarbons, polyalphaolefins, diesters and other materials that form the base stocks of high quality name brand synthetics are fully compatible with petroleum oils. In the old days, some companies used untested ingredients that were not compatible, causing quality synlubes to suffer a bum rap. Fortunately, those days are long gone.
    Compatibility is something to keep in mind, however, whether using petroleum oils or synthetics. It is usually best to use the same oil for topping off that you have been running in the engine. That is, it is preferable to not mix your oils, even if it is Valvoline or Quaker State you are using. The reason is this: the functions of additives blended for specific characteristics can be offset when oils with different additive packages are put together. For optimal performance, it is better to use the same oil throughout.
    Myth#5: Synthetic Lubricants Are Not Readily Available.
    Untrue. This may have been the case two decades ago when AMSOIL and Mobil1 were the only real choices, but today nearly every major oil company has added a synthetic product to their lines. This in itself is a testament to the value synthetics offer. But, beware, many of the other "synthetics" are not true PAO (Polyalphaolefin) synthetics (ie: Castrol Syntec, Penzoil, etc...) they are hydroisomerized petroleum oil or an ester based synthetic blend.
    Myth #6: Synthetic Lubricants Produce Sludge.
    Untrue. In point of fact, synthetic motor oils are more sludge resistant than their petroleum counterparts, resisting the effects of high temperatures and oxidation. In the presence of high temperatures, two things happen. First, an oil's lighter ingredients boil off, making the oil thicker. Second, many of the complex chemicals found naturally in petroleum basestocks begin to react with each other, forming sludges, gums and varnishes. One result is a loss of fluidity at low temperatures, slowing the timely flow of oil to the engine for vital engine protection. Further negative effects of thickened oil include the restriction of oil flow to critical areas, greater wear and loss of fuel economy.
    Because of their higher flash points, and their ability to withstand evaporation loss and oxidation, synthetics are much more resistant to sludge development.
    Two other causes of sludge - ingested dirt and water dilution - can be a problem in any kind of oil, whether petroleum or synthetic. These are problems with the air filtration system and the cooling system respectively, not the oil.
    Myth #7: Synthetics Can't Be Used With Catalytic Converters Or Oxygen Sensors.
    Untrue. There is no difference between synthetic and petroleum oils in regards to these components. Both synthetic and petroleum oils are similar compounds and neither is damaging to catalytic converters or oxygen sensors.
    Myth #8: Synthetics Void Warranties.
    Untrue. No major manufacturer of automobiles specifically bans the use of synthetic lubricants. In point of fact, increasing numbers of high performance cars are arriving on the showroom floors with synthetic motor oils as factory fill.
    New vehicle warranties are based upon the use of oils meeting specific API Service Classifications (for example SG/CE). Synthetic lubricants which meet current API Service requirements are perfectly suited for use in any vehicle without affecting the validity of the new car warranty. In point of fact, in the over 25 years that AMSOIL Synthetic Lubricants have been used in extended service situations, over billions of miles of actual driving, these oils have not been faulted once for voiding an automaker's warranty.
    Myth #9: Synthetics Last Forever.
    Untrue. Although some experts feel that synthetic basestocks themselves can be used forever, it is well known that eventually the additives will falter and cause the oil to require changing. Moisture, fuel dilution and acids (the by-products of combustion) tend to use up additives in an oil, allowing degradation to occur.
    However , by "topping off", additives can be replenished. Through good filtration and periodic oil analysis, synthetic motor oils protect an engine for lengths of time far beyond the capability of non-synthetics.
    Myth #10: Synthetics Are Too Expensive.
    Untrue. Tests and experience have proven that synthetics can greatly extend drain intervals, provide better fuel economy, reduce engine wear and enable vehicles to operate with greater reliability. All these elements combine to make synthetic engine oils more economical that conventional non-synthetics.
    In Europe, synthetics have enjoyed increasing acceptance as car buyers look first to performance and long term value rather than initial price. As more sophisticated technology places greater demands on today's motor oils, we will no doubt see an increasing re-evaluation of oil buying habits in this country as well.
    Conclusions
    Since their inception, manufacturers of synthetic motor oils have sought to educate the public about the facts regarding synthetics, and the need for consumers to make their lubrication purchasing decisions based on quality rather than price. As was the case with microwave ovens or electric lights, a highly technological improvement must often overcome a fair amount of public skepticism and consumer inertia before it is embraced by the general population.
    But the word is getting out as a growing number of motorists worldwide experience the benefits of synthetic lubrication. The wave of the future, in auto lubes, is well under way.
  5. #5
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    The Development of Synthesized Motor Oils:
    A Historical Review
    by Ed Newman
    Marketing & Advertising Coordinator, AMSOIL INC.
    AS THE YEAR 2000 APPROACHES, it is both a time of looking forward, and of looking back. No one a century ago could have foreseen the rapid transformations that science and invention would bring to our world. From rocket ships to microwaves, silicon chips to Dolly the cloned ewe -- it has been an astonishing period of history. I mean, a hundred years ago we didn't even have gas stations. Or highways. Or flat tires.
    One of the transforming developments of our century has been the discovery of the process of organic synthesis, the combining of the raw materials of production into a nearly limitless array of plastics, films, fabrics and fluids. By understanding the geometry of organic compounds, chemists could create customized molecular designs to achieve preconceived objectives. Scientists realized that they could actually improve the characteristics of items found in nature.
    One bi-product of this process has been the development of synthetic motor oil. It is believed that the first synthesized hydrocarbons were created by Friedel & Crafts in 1877 using Aluminum TriChrloride as the catalyst. Yet it wasn't until 1929 that the commercial development of synthesized hydrocarbons was undertaken by Standard Oil of Indiana. Not surprisingly there was a lack of demand for the new product and this first marketplace introduction of synthetic lubricants was commercially unsuccessful. (There is probably no relationship between this event and collapse of stock market later that year.)
    Eight years later the first PAO, a synthetic product using olefin polymerization, was manufactured. 1937 was also year that the Zurich Aviation Congress became interested in ester based lubricant technology. From 1938 to 1944 thousands of esters were evaluated in Germany with excellent results. In our own country ester basestocks were also being developed by the United States Naval Research Laboratory and introduced into military aviation applications during the 1940's.
    During this period scientists were well funded, and the new processes of synthetic creation had some great success. But as is so often the case, the existence of a "better mousetrap" does not always result in its commercial survival.
    It was the space age that helped create a greater appreciation for the benefits of synthetic lubricants. Jet engines raised the bar on what was required of a lubricant. The high speed, high heat and cold temperature performance requirements of modern jets created a demand for a new kind of lubricant.
    Just after the war we saw the first use of diesters by the British in turboprop engines for high temperature performance. And from the late forties to the early seventies various synthetic fluids were developed to meet the demands of new and more efficient high performance engines and machines.
    Because of the self-evident cold weather benefits of synthetic jet engine oil, it would not have been difficult to find a few maverick pilots experimenting with this oil in their cars. The military paid thirty-five dollars a quart for synthetic oil in those days and even the used jet engine oil seemed clean enough for some pilots in Alaska and elsewhere to mix with their motor oil to assist cold winter starts.
    One such experimenter took a more systematic approach. In the mid-1960's, Lt. Col. Albert J. Amatuzio, jet fighter squadron commander at a northern Minnesota airbase, likewise had become familiar with these "extra ordinary" lubricants that protected the engines of the jets he flew. He began a research project that eventually became his life work and second career.
    At first, Amatuzio's efforts were aimed at improving the performance of petroleum oil.
    Eventually, Amatuzio realized the need to begin with a synthetic basetock and build his ideal lubricant from the ground up. His search led him to Monsanto, Drew Chemical Corporation and Hatco. It was Drew Chemical Corporation in Boonton, New Jersey, where the first polyol esters had been developed and patented in conjunction with Mobil Chemical in 1958. Mobil Oil's Jet Engine Oil II was based on the fluids produced at Drew Chemical.
    The truth is, automobiles put even more stress on a lubricant than jet engines because air aspirated car engines must deal with dirt and the messy by-products of combustion. The problem was how to bring the expanded temperature range performance, wear protection and service life of a synthetic into an automotive setting. Amatuzio believed he had found a way.
    According to Jack Arotta, a Duluth Minnesota businessman today, "I was the first guy to put it (a specially formulated 100% synthetic motor oil) in a brand new car, a 1966 Ford Station Wagon. Al was my squadron commander up at the air base, so I always use the joke that since Al was my squadron commander, how could I not put it in when he told me to."
    Actually, for more than a year Jack had been putting a variety of Al's synthetic formulations in his previous cars, so he did not feel that he was putting his vehicle at serious risk. After several more years of fine tuning his formulation, AMZOIL (Amatuzio-oil) was created and became the first 100% synthetic diester based engine oil to pass the API sequence tests and receive API qualification in 1972.
    The following year Mobil Oil began marketing the first PAO based engine oil overseas and in 1975 they began test marketing a synthetic PAO based synthetic in the U.S. called Mobil 1.
    Over time a growing niche of consumers became aware of the performance benefits synthetic offered. As additional products were developed, from synthetic diesel oil to two cycle oils, synthetic transmission fluids and gear lubes, so grew the interest. With growing market opportunity, more companies made contributions in the development of basestock fluids and new technologies, including the Gulf Oil Company (since acquired by Chevron), Chevron Corporation, Amoco, Ethyl Corporation, Exxon, Henkel, Castrol, Uniroyal, Lubrizol, Neste Chemical, and Texaco (additive technology and synfluids since acquired by Ethyl).
    By the mid-nineties nearly every oil company carried a high end synthetic motor oil in its product line, though only a few companies seem truly dedicated to promoting them. Nevertheless, synthetic lubricants are currently the fastest growing segment of the oil industry and they are definitely here for the long haul.
  6. #6
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    10W40 Amsoil available, try the real synthetic experience.
    Call/sms 97678810
  7. #7
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    new shipment of Amsoil 10W40 is available now. place your order before its out of stock.
    Call me at 97678810
  8. #8
    warrior.c.o.n.p
    TeePee warrior.c.o.n.p's Avatar
    Jul 2006
    Location
    Along Pioneer Rd 2 NTU
    3,378
    1 (100%)
    pm me the price for Amsoil 10W40 thnks
    If you only run for cover, it's just a waste of time..
  9. #9
    sihan0110
    Class 2A sihan0110's Avatar
    Apr 2007
    775
    3 (100%)
    Default Amsoil 10W40
    hi what the price for Amsoil 10W40 . do you have 10w50?
  10. #10
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    $18 per bottles
    call me 97678810
  11. #11
    afterlife
    TeePee afterlife's Avatar
    Jan 2008
    2,218
    2 (100%)
    the amsoil 10-40 u r selling is the MCF(for motorcycles) version or normal 10-40 for cars?
  12. #12
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    MCF 10W40 is going for $22
    I carry a full range of Amsoil Engine Oil
  13. #13
    afterlife
    Jan 2008
    2,218
    2 (100%)
    juz confused here, wats the difference between the 10-40 motor oil and the 10-40 mcf? care to explain? thanks..
  14. #14
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    Happy new year...
    While both mcf and amo uses the same group iv PAO base-stock. The difference in prices is due to mcf's newer addictive formulation in wear, anti oxidation and wet clutch uses.
    Do give me a call if you have anymre queries.
    Mobile - 9767 8810
  15. #15
    LeoWai
    P Plate
    Jun 2008
    74
    2 Post(s)
    Can Amsoil 10W40 (S$18/bottle) be used in wet clutch bikes like Honda Super 4? Will clutch slip or not? From the website, it stated it meets JASO MA (Motorcycle) standard.
    http://www.amsoil.com/storefront/amo.aspx
    10-40 mcf (S$22/bottle) last 15,000- to 25,000-mile of drain interval like the S$18/bottle one? As it's not officially indicated in the official website.
  16. #16
    RxzDelux
    is Bored
    TeePee RxzDelux's Avatar
    Jan 2004
    Location
    North Ranger
    3,533
    1 (100%)
    Quote Originally Posted by LeoWai View Post
    Hi i think you missed to READ this paragraph :-
    APPLICATIONS
    AMSOIL Synthetic 10W-40 Motorcycle Oil is recommended for liquid or air-cooled 4-stroke engines. It meets SAE 80W/90, API GL-1 gear oil requirements and is recommended for transmissions on both 4- and 2-stroke motorcycles. AMSOIL MCF is recommended for HONDA®, Kawasaki®, Yamaha®, Suzuki®, BMW®, Husqvarna®, Victory® and other motorcycles where 10W-40 or 20W-40 engine oils or SAE 80W/90, GL-1 gear oils are used. Not recommended where an API GL-4 or GL-5 gear oil is required.
    SERVICE LIFE
    For “on-road” use in engines and transmissions, change AMSOIL MCF and AMSOIL engine oil filter at twice the motorcycle manufacturer change interval or one year, whichever comes first. Change other brand oil filters at standard intervals.
    For “off-road” use in engines and transmissions, change AMSOIL MCF at the standard motorcycle manufacturer change interval.
    For racing or in engines modified from the original factory design, no change interval recommendation is made. Oil changes are at the owner’s discretion.
    Taken from here.
    http://www.amsoil.com/storefront/mcf.aspx
    History n Present ride
  17. #17
    LeoWai
    P Plate
    Jun 2008
    74
    2 Post(s)
    Quote Originally Posted by RxzDelux View Post
    SERVICE LIFE
    OK. However, you did not answer my first question that whether Amsoil 10W40 (S$18/bottle) oil can be used in wet clutch bikes like Honda Super 4? Just curious.
  18. #18
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    Hi there,
    Amsoil 10W40 (AMO) $18/bottle can be use on any other regular motorcycle, example super 4.
    cheerios
  19. #19
    shahrul_azmil3
    go to guy for missuwedding
    TeePee shahrul_azmil3's Avatar
    Jun 2005
    4,849
    1 Post(s)
    any shop selling this ... i'm not good in diy
    Past to present rides
    Honda nsr sp 150 pro arm
    Honda cbr 600 rr
    Aprilia sr max 300 I.e
  20. #20
    molicka molko
    L Plate
    Nov 2009
    18
    I Check Amsoil Website..
    Do You Have The 20w50 Systhetic Motorcycle Oil MCV..?
    How Much..?
    My Bike Manual State A 50 Grade Oil,Running On A Vtwin Engine..
    Not Really Sure Can Run On A 40 Grade Oil..
  21. #21
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    Quote Originally Posted by molicka molko View Post
    How Much..?
    HI Mate, 20W50 is arriving really soon....I am awaiting for the arrival of my new shipment. If yours is a V-Twin engine, yes please use Amsoil MCV 20W50.
    Cheerios
  22. #22
    uberstore
    Oct 2006
    Location
    275
    1 Post(s)
    Quote Originally Posted by shahrul_azmil3 View Post
    Bro,
    you can check out with Hiap Aik at machperson or HL cycle, brilliant service
  23. #23
    honda_lover
    Class 2A honda_lover's Avatar
    Sep 2007
    Location
    Punggol
    698
    Hi boss,
    Me and my friends are planning to diy oil change and we are looking into amsoil.
    We would need your prof knowledge to advice us which type of amsoil oil to use. Also kindly state the price of it.
    Also if u can also provide us the price of oil filter (hi flo/ amsoil/ or any brands) and ngk iridium plugs.
    We have cbr6/ r6/ g6 and s4
    Thank you.
    Sent from my GT-I9100 using Tapatalk
    suuupppaaaa da fooouuurrrrr!
    weetec 1
    Education Status
    Currently Pursuing :
    Masters for Jamming Brake in Tail Gating Management
