Page 8 of 8 FirstFirst ... 45678
Results 351 to 363 of 363
Thread: [Discussion] ~ Brakes Related Issue
  1. #351
    Shazarul
    L Plate
    Dec 2011
    Location
    Singapore
    5
    Quote Originally Posted by MrLau View Post
    The rear brake is always less "efficience" for few reasons :
    1) During braking, the bike weight will shift to front. The rear brake has less effect.
    Under hard braking, the effect is more obvious. Until a point that, the rear wheel will lift up and lost contact from tarmac.
    2) Rear brake 'too' efficient will cause wheel lock.
    Thats why most of the bike (even for cars) has bigger disc brake at front but small (single disc or drum brake) at the rear.
    Very well explained. Thanks even with my aftermarket hose(hel) + bleed n new brake pad(rear), the efficiency increase by a small %..
  2. #352
    KnightDragon
    P Plate
    Aug 2008
    154
    Quote Originally Posted by LXY View Post
    Did you just change new tyre and balancing of rim? If yes, then maybe the pad still remember the pattern of yr disc.
    Some time alittle misaligned of disc can cause the jerking effect during braking.
    I also facing this problem after new front tyre changed, before that is okie. What should i do now? Change brake pad?
  3. #353
    fadzhil
    L Plate
    Jan 2014
    4
    Hi guys I need you advise... I just changed my front disc to arashi and also service my brakes and change the brake pads. Upon changing, I realized that there is this clicking sound at the right side of my front brake everytime I move off. Quite to explain it in words but anyone had similiar experience before? any recommendations on which workshop to go? I do not wanna go back to the shop first... I just need a second opinion...
  4. #354
    HaiR1
    TeePee
    Jul 2007
    Location
    Lion City
    4,794
    18 (100%)
    11 Post(s)
    Quote Originally Posted by fadzhil View Post
    Very subjective eh.. Need to see your bike personally before can conclude
    Dnt tell me your right side brake disc revert is loose
  5. #355
    snowfox85
    L Plate
    Dec 2010
    10
    hi guys
    just want to ask is it normal for new brake pads to screech while braking? need some time for it to run in? cos I just changed brake hose and brake pads. before the change was alright, but after change, while tapping on my rear brakes to slow down, will have the screeching sound.
    I tried spinning the wheels manually and realise only a specific section will have this sound. if the brake pads are "more seasoned", will the sound go away or its just due to my disc rotor uneven surface?
    having these questions in my mind, need some enlightenment. =)
  6. #356
    stkoh78
    P Plate
    Jan 2006
    154
    HI guys ..
    Today while inspection my front brake pads , i realized that one of pads (inner one) required a need for replacement real soon . The other 3 brake pads are still a relative new.
    Each time when i change the front brake pads, the bike shop mechanic changed all 4 front pads . The other time when the mechanic changed the pads , the other 3 pads are still new. It looks like the brake system didn't use all brake pads equally during braking .
    is it necessary to change all 4 pads ? Need advise
  7. #357
    ticks
    is learning supermoto
    TeePee ticks's Avatar
    May 2011
    Location
    West
    2,356
    15 Post(s)
    The problem u need sorting now is not just the pads. Those aren't the problem despite needing placement.
    What's intriguing is why that particular pad is getting worn out way faster than the opposite side of the same caliper, and also the other caliper..
    You can try to check if you have brake drag. This can be done by lifting up the front wheels (by some means) and rotating the wheel by hand or some similar methods.
    Ride fast..ride safe..don't crash...
  8. #358
    Tachnicolour
    SBF Lacer Tachnicolour's Avatar
    Jun 2010
    569
    4 (100%)
    2 Post(s)
    Quote Originally Posted by stkoh78 View Post
    HI guys ..
    As ticks mentioned, check for brake drag. It could be a case of the pistons not retracting properly. Could be the pistons have gunk build up which is preventing it from retracting properly. The square caliper seals deflect when you brake and the piston moves out. When the brakes are released, the seals recover and pull the piston back ever so slightly. If there's too much junk between piston / exterior part of caliper bore, can prevent the seals from pulling the piston back. Deformed pistons can have the same effect, but.......I imagine it'd be kinda hard for that to happen. Usually a caliper rebuild will do the trick. Just replace the seals and clean the pistons/bores.
  9. #359
    Hydher
    Is selling his GSXR1000
    SBF Phantom Knights Hydher's Avatar
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    service your brake pistons
  10. #360
    exwhyzee
    doesnt need a status.
    Class 2B exwhyzee's Avatar
    Feb 2012
    Location
    Woodbridge
    345
    A piece of Brembo 16mm Brake Master Cylinder for sale!
    -brembo brake master cylinder (+lever +mirror mount +evotech bolts) bought for $300++
    -rizoma brake reservoir [retail price $170]
    -rizoma bracket [retail price $75]
    Dekit frm my super4...will sell the whole damn thing for S$300!!!
    leave a PM or watsapp/sms me at 9two3five400one
    Attachment 320298 Attachment 320299
    '97 CB400 F3V (NC31)
  11. #361
    manoraaju
    L Plate
    Feb 2011
    38
    Default Electronics
    Lol. I think i know what is it. Its the relay 'click' sound of ur brake. Front brake lever is to the right and when u squeeze them, the electro-mechanical relay closes and the brake light is on. When u release, the relay releases as well with a click sound and the brake light is off. Electronics dude! Haha
  12. #362
    HaiR1
    TeePee
    Jul 2007
    Location
    Lion City
    4,794
    18 (100%)
    11 Post(s)
    Quote Originally Posted by manoraaju View Post
    Its brake switch dude
  13. #363
    Hayabusa Sniper
    Deviily Angel
    SBF Lacer Hayabusa Sniper's Avatar
    May 2003
    Location
    Sniper in the Woods
    10,992
    Which brand of front brake disc rotor do you guys recommend to change for a spec 3 when the stock disc rotor is uneven and worn off? Where and how much to change it?
    Know The Rules Before You Play The Game,
    Beat It If You Can't Afford To Lose.
