Page 2 of 36 FirstFirst 12345612 ... LastLast
Results 51 to 100 of 1784
Thread: [Technical] Possible Solutions to your Phantom's Problem
  1. #51
    jB
    has 4 and counting! :D
    SBF Lacer jB's Avatar
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by SNapEl View Post
    Put limit on who can start a new thread lor... sa like post counts >50 or maybe >100... at least it gives them 50 or 100 posts to learn before starting their own threads, and their participation being limited to the many many many threads of wide varieties should not be a problem. In fact even if you lao jiao in PK forum also no need to start new thread sia... everything all have liao. zzz
    would be good, try posting this in Feedback thread to Admin
    Quote Originally Posted by kmax View Post
    that's not upto PK's moderator's power i guess.
    anyway, it's great forum and friendly people... just we bull$h!t alot
    you said it
    Quote Originally Posted by joekoh View Post
    hmmm i suggest u all change the title la.. like' see here for ur phantom problem' don't put possible la.. very blur for new rider.. but this is a good post la.. help alot of new rider.. so thumbs up for u guys..
    well I tried to make it not too singlish and comprehensible to everybody already. Any suggestions? I used 'possible' because it might not be 100% accurate
    Click below link or copy+paste for good deals!
    http://www.singaporebikes.com/forums/showthread.php/417915-WTS-Shoei-XR-1100-Diabolic-Cimmerian-Mint-Condition-L-Size-CHEAP!-9-8-10?p=8191458#post8191458
    http://www.singaporebikes.com/forums/showthread.php/406472-WTS-Blaupunkt-Style-Headphones-Unopened-BNIB!
  2. #52
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    <UPDATED Oct 1st 08>
    Solution: Its normal.
    Problem 2: Engine stalls in heavy rain and unable to start.
    Reason: Air fuel mixture may be too rich.
    Reason: Fuse may be blown.
    Solution: Obvious.
    Reason: Water in petrol
    Others:
    - Check magneto coil.
    Solution:
    - Send to bikeshop.
    Solution:
    - 67474740 Tiko cheong.
    - 64560018 Wing Yap.
    Reason: Gasket Spoilt.
    Reason: Speedo spoilt.
    Solution: Bike shop.
    Solution: Retune the carb.
    Reason: Clutch is worn
    Solution:Change new bearings.
    Problem 20: Sound emitting from front/rear wheel when braking
    Reason: Brake pads worn out
    Solution: Change
  3. #53
    Zhi Ming
    rides a TA200
    Class 2A Zhi Ming's Avatar
    Jun 2008
    Location
    Singapore North
    543
    4 (100%)
    1 Thread(s)
    upz for good info.
    Quote Originally Posted by jB View Post
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
    Solution: Change
  4. #54
    Hydher
    Is selling his GSXR1000
    SBF Phantom Knights Hydher's Avatar
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
    Solution: Change
    [B][U][COLOR=#00ff00]Problem 20: Pop pop sound whenever you close your throttle(harley like sound)
    Reason: Valve/Air vacuum faulty.
    Solution: Get it replaced (honda original. Planet motors $65)
  5. #55
    Skull_Angel
    TeePee Skull_Angel's Avatar
    Oct 2008
    Location
    Punggol End
    2,735
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
    Class2B - 11 Dec 08
    Past - Honda Wave 125S
    Current - Kawasaki KRR 150
    Class3 - 26/09/09
    Current - Lancer GLX 1.6
    One Life, Treasure It
    Future - YZF R6
  6. #56
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    how come we're back at problem 15?
  7. #57
    shiro
    Class 2B
    Jan 2005
    228
    hey guys, i used to have problem kicking the gear to neutral from either gear 1/2...but after oil change normally the problem is resolve...but now...it is the oppsite....have problem kicking to gear 1 to neutral ,now tap a bit only can go neutral...cannot go to gear 1...normally when gear 1 cannot kick down anymore...but now can continue to kick and kick but still cannot gear 1...then when move off sometime auto netural...from the "gear 1"...any bros here know wat is wrong with it?.....thanks in advance for any replies...
  8. #58
    st_gtti
    Class 2B st_gtti's Avatar
    Jun 2008
    Location
    Hougang
    350
    1 (100%)
    Quote Originally Posted by shiro View Post
    Bro i used to have tis issue, if ur bike keep on skip gear by itself i think mayb its the clutch prob, wat i would suggest is go planet n look for Mr Chong to quote for u just to b safe.
  9. #59
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    its either eo or clutch plate.
  10. #60
    Yat-
    P Plate Yat-'s Avatar
    Sep 2003
    Location
    HDB Flat
    191
    try kick down in half clutch. thats what cdc instructor taught me when i took 2A. the problem happened with their bike, and after that my phantom. but then again, best to check with bike shop
  11. #61
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by rehdyh View Post
    take note, it could also be biting point
    Quote Originally Posted by Yat- View Post
    yup, best to let bike shop (recommended is planet) to have a look w/out worries of any aftermath.
  12. #62
    lawbah
    Class 2 lawbah's Avatar
    May 2008
    1,267
    <UPDATED November 5th 08>
    Reason:
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
    Problem 21: Weak Battery.
    B]Reason: [/B] There is a knob for adjustment, it might be loose
  13. #63
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    alright updated and thanks to Lawbah
  14. #64
    lawbah
    May 2008
    1,267
    upz for newbie reference.
  15. #65
    yob rekib
    L Plate
    Aug 2004
    35
    Hi may i know TA200 carb setting how many turns? Mine @ 2.5 turns having lots of backfire.
  16. #66
    SNapEl
    wants to go for a looong ride~!!
    TeePee SNapEl's Avatar
    Aug 2007
    2,399
    Reduce it to 2 turns. You mixture may be too lean.
  17. #67
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    There's no fixed setting, every vehicle has a different setting suit/catered to different users.. Try adjusting slowly over time to cater to yourself or let the mechanics do the job. FOC.
  18. #68
    yob rekib
    L Plate
    Aug 2004
    35
    Hi SNapEl, managed to rectify my backfire problem. My mech say its a exhaust gasket issue. After change exhaust gasket, the backfire seems to have lessen alot but not completely gone (once in a while have a pop sound). My mech said TA200 standard carb settin is 2.5 turn. Just wanna to confirm this with u guys. Anyway, i have yet to try reducing to 2 turns. Is there any other way to check if our setting is rich or lean apart from spark plug appearance? Now my bike feels throttle response is better a bit, but once reach 90`100 feels a bit heavier to pull away..
  19. #69
    chuan.z
    Class 2 chuan.z's Avatar
    Jun 2007
    Location
    SG,SG
    1,282
    Solution: Obvious.
    i kena this one this morning... pushed all the way 2nd floor to 1st floor of MSCP also cannot start... took out spark plug to check spark, wondering how come no spark... try with spare plug also no spark... then i saw the kill switch....................
    last night itchy hands la go use kill switch to stop engine...
  20. #70
    lawbah
    May 2008
    1,267
    hahahah i also kenna this a few times liao.. if not then is start liao then kick gear 1 engine die off.... forget to kick up side stand... lol
  21. #71
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    keyhole stuck =.= cannot turn. spray wd40 =.=
  22. #72
    SNapEl
    Aug 2007
    2,399
    Quote Originally Posted by chuan.z View Post
    Solution: Obvious.
    Quote Originally Posted by lawbah View Post
    haha lol chuanz you all the way sia... take out spark plug summore..
    Once i just crank starter motor, crank crank crank dun start, siao liao... den notice kill switch. Heng ar...
  23. #73
    SNapEl
    Aug 2007
    2,399
    piang eh forum cmi double post
  24. #74
    thenation
    TeePee thenation's Avatar
    Nov 2007
    Location
    Hougang
    2,615
    1 (100%)
    2 Post(s)
    Heh, lucky mine doesn't have a kill switch
  25. #75
    kraikk
    P Plate
    Apr 2008
    172
    Hi I had problem 18 and had the cam chain tensioner changed. That was only about 500km ago. Now the sound is back. Should I change the tensioner again or are there any other possible reasons?
  26. #76
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    What I heard is that its a common thing, I hope other riders can assist in sharing their method of preventing it. Do consult the mechanic where you had it changed. I do wish to know who did it also
  27. #77
    SNapEl
    Aug 2007
    2,399
    Actually we all like to know who change for you and why also haha.
  28. #78
    mepkoh
    Deregistered
    Feb 2008
    2,520
    i thought rich mixture have more chances of ... back fire ..????? so i am so blur now...,,
  29. #79
    kraikk
    P Plate
    Apr 2008
    172
    I changed at Planet for $55. That was not long after I took over the bike. I went there because of the generally positive feedback on this forum. Any particular reason why?
    The sound is only there when idling. Soft ticking, about 4 beats a second. I notice that it disappears or becomes very soft after riding.
  30. #80
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    exhaust expanding?
  31. #81
    SNapEl
    Aug 2007
    2,399
    LOL mine also got soft ticking when idling ah chong says its ok. If its chain tensioner he say it will sound very apparent. If you really not sure go back to ah chong one more time and see what he says.
  32. #82
    SNapEl
    Aug 2007
    2,399
    Quote Originally Posted by mepkoh View Post
    Too lean or too rich it will backfire. Dun confuse, very simple one.
  33. #83
    lawbah
    May 2008
    1,267
    hmmm heard from some more experienced people, they also say too lean will backfire... so maybe... cannot too lean nor too rich... must be just nice... haha...
    Quote Originally Posted by kraikk View Post
    not very sure but izzit something called cam chain tensioner or something?? hmm
  34. #84
    kraikk
    P Plate
    Apr 2008
    172
    Yes that's what I changed on his advice, I had actually gone to change tyres. Apparently if it is left unchecked for too long the piston will hit something causing the engine to break down.
  35. #85
    lawbah
    May 2008
    1,267
    hmmm icic... i think that is a very common niggling problem... the tick tick or jiji sound... most prob is something to do with chain or something ... so ok la ... if he ask you to change sure got his reasons, he wun anyhow chop one...
    Actually.... my TA also got tick tick sound liao.... =_=
    Are you local by the way..? just curious...
  36. #86
    mepkoh
    Deregistered
    Feb 2008
    2,520
    yeah u r right...
    too lean..when bike unable to combust.eg, during start up or running miss a combustion stroke(s)..fuel mix in exhaust can back fire..
  37. #87
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    too much air = fart, too much petrol = diarrhoea
  38. #88
    SNapEl
    Aug 2007
    2,399
    yeah u r right...
    To be a bit more detailed,
    When its too lean, the fuel has not completely finish burning during the combustion stroke as there is not enough fuel to carry the flame around the chamber fast enough. So the fuel continues burning as it exits into the exhaust and backfires.
    When its too rich, there is unburnt fuel left after all the oxygen in the chamber is burnt off which get ejected into the exhaust. When the fuel is released at the mouth of the end can, the heat of the exhaust and the fresh air causes it to combust and backfire.
  39. #89
    kraikk
    P Plate
    Apr 2008
    172
    Yes I'm local. Why do you ask?
    One more question, what is the maximum TA200 can go without changing engine oil? I would like to know (1) the maximum recommended, ie not ideal but the engine still can take it and (2) the maximum anyone has tried and what happened.
  40. #90
    lawbah
    May 2008
    1,267
    I asked if you are local cos IMO bike shop usually chop foreigners... ie. ang moh...
    Some people say max 5000km then change, Mr. Chong says 5000km can change engine liao.
    I think max is 3000km.
    Ideal is 1500km - 2000km. (2k is my max)
    My advice is, one bottle of say, Maxima EO maybe 16 - 26 bucks, why want to save and kenna problems? Wait here spoil there spoil even more expensive liao.
    Do take into consideration that you might need to top up the EO if you plan not to change for sometime. This is because, somehow, the EO will get eaten by engine etc etc. Better run with full but dirty EO than no EO at all right?
  41. #91
    kraikk
    P Plate
    Apr 2008
    172
    I don't understand how EO will be used up. Isn't it supposed to have a very high boiling point so that it will not evaporate? If not the EO itself will ignite in the heat of the engine which would be very dangerous.
  42. #92
    lawbah
    May 2008
    1,267
    Im not sure about high boiling point for EO. I only know coolent have higher boiling point. I dunno why EO will get eaten / used up but trust me it will. This issue has been discussed before, if u really need to know, then search for it. Otherwise be like me, accept the fact. I have seen mine when it was drained out.... definitely less than what i put in. so yeah, u decide.
  43. #93
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    If u talk about high bp, it has to do with ur ratings right? faulty engine and parts= eat up eo =)
  44. #94
    lawbah
    May 2008
    1,267
    Read up some stuff, if keeps drying up then have to check gasket, but generally, TA200 is known to eat EO. If i am not wrong, it is because TA200 is a very hot bike, it is air cooled unlike TA150 which has a radiator... if dont eat alot should be normal ... well ... if alot then gotta check liaoz...
    Hmmm rehdyh, your bike wont eat EO arh?? >.<" So good~!!
  45. #95
    lawbah
    May 2008
    1,267
    This might solve some questions...
    Engine Oil Loss
  46. #96
    derosis
    Class 2B
    May 2008
    474
    hi everyone, i riding a TA200 and yesterday after i went jb to pump petrol(i pump till the brim(caltex gold techron)) then on the way back on the causeway,i at gear 6.. riding at 60km/h suddenly the bike like going to stall then i throttle but no power.so i drop 1 gear then i throttle..then also same. then after that the bike suddenly engine stall.then i roll to the side and stop.the feeling is like no petrol like that. then i tried everything.push start/ keep press the electric start but engine not starting,then suddenly after many tries,i manage to get the engine started by pressing the electric start .Also it was drizzling.
    anyone know whats the problem? is it pump petrol too full?
    thanks
  47. #97
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    It might be a case of it being too full, Thatone1 encountered this before and Ah Chong said it was too full. It might also be the rain. Might be something else.
  48. #98
    oktray
    SBF Fazers oktray's Avatar
    Aug 2007
    Location
    North-east
    432
    4 Post(s)
    When I open throttle to accelerate then suddenly the rev become very loud but the bike seem to 'lag' in response to the throttle (pick up speed very slowly) What could be the cause? Is it very likely due to the clutch plate being worn off already?
    Work to ride and ride to work
  49. #99
    derosis
    Class 2B
    May 2008
    474
    Should be ur clutch plate wearing off already.. u can get it changed at planet motor for less than $100.. clutch plate + gasket. i also having this problem, then chong told me that i need to change my clutch plate.
  50. #100
    mepkoh
    Deregistered
    Feb 2008
    2,520
    Quote Originally Posted by derosis View Post
    thanks
    if it is raining..then electrical/spark leakages most likely..
    other reason could be just plain bad fuel. or petrol is not flowing , choke petrol/air filter etc..
