Page 3 of 36 FirstFirst 123456713 ... LastLast
Results 101 to 150 of 1784
Thread: [Technical] Possible Solutions to your Phantom's Problem
  1. #101
    mepkoh
    Deregistered
    Feb 2008
    2,520
    Quote Originally Posted by kraikk View Post
    I don't understand how EO will be used up. Isn't it supposed to have a very high boiling point so that it will not evaporate? If not the EO itself will ignite in the heat of the engine which would be very dangerous.
    hey..EO do not burn...even in the the firing chamber...
    the most likely reason why engine eat EO is leakages...
    EO will get eaten by leaking engine ..small drips of EO found on engine or floor..leak through cylinder and out through the exhaust..
    sometimes u even find EO increase in your engine...hahahaha
    couldn figure out?....suggest u do a bit of research..u will be surprise..
  2. #102
    wet_market
    P Plate wet_market's Avatar
    Mar 2005
    131
    Reason: Wheel/Rim alignment might have problem.
    Solution: Bike shop, change front tyre and flatten rim.
    Reason: Suspension too soft. Makes tiak tiak sound when depressed.
    Solution: Refill of suspension oil.
    I've encounter this problem few months ago. managed to get it solved today by changing ALL above mentioned solutions. Damaged is $330. and 4 hrs of repair time.
  3. #103
    lawbah
    Class 2 lawbah's Avatar
    May 2008
    1,267
    Quote Originally Posted by wet_market View Post
    You go where to do wor?? Change all the above?? All spoil together?????!!?!?
    hmmm.. its a possibility but its very small....
  4. #104
    jB
    has 4 and counting! :D
    SBF Lacer jB's Avatar
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by lawbah View Post
    Free to help update the list?
    Click below link or copy+paste for good deals!
    http://www.singaporebikes.com/forums/showthread.php/417915-WTS-Shoei-XR-1100-Diabolic-Cimmerian-Mint-Condition-L-Size-CHEAP!-9-8-10?p=8191458#post8191458
    http://www.singaporebikes.com/forums/showthread.php/406472-WTS-Blaupunkt-Style-Headphones-Unopened-BNIB!
  5. #105
    lawbah
    May 2008
    1,267
    update when i free lor hahahaha~!!
  6. #106
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Alright, thanks in advance anyway. I don't know where you went to source so much of the probs and solutions also
  7. #107
    wet_market
    Mar 2005
    131
    Not all spoil together, but all is inter-link. If I rmb correctly, they told me is when your rim alignment is out, it stress your steering cone causing it to wear faster. With a damaged steering cone, it puts on pressure to your suspension and the tyre will take the rest of the impact after the suspension.
    When you changed your front tyre, you know it's time to change your rear..
    Almost forgot, went to H L Cycle to change them.
  8. #108
    lawbah
    May 2008
    1,267
    <UPDATED : BOXING DAY 08>
    Reason:
    Engine oil is leaking into your chamber.
    Solution: Its normal.
    Reason: Air leakages.
    Reason: Fuse may be blown.
    Solution: Obvious.
    Reason: Water in petrol
    Others:
    - Check magneto coil.
    Solution:
    - Send to bikeshop.
    Solution:
    - 67474740 Tiko cheong.
    - 64560018 Wing Yap.
    Reason: Gasket Spoilt.
    Reason: Speedo spoilt.
    Solution: Bike shop.
    Solution: Retune the carb.
    Reason: Clutch is worn
    Solution:Change new bearings.
    Problem 21: Weak Battery.
    Problem 23: IU Spoilt.
    Problem 24: Where to get visor / assesories after 6.30pm.
    Solution: Lim Ah Boy (Kelantan Lane around Jalan besar Hawker centre).
    Problem 25: Can Phantom change headlights?
    Reason: No reason in particular / cosmetics.
    Solution: Yes. Can change and it all depends on your DIY / mech's skill.
    Solution: www.pinkphantom.com - (Source to get nice headlights)
    Solution: LAB - (Source to get nice headlights)
    Problem 26: Can TA150 / TA200 use 92?
    Solution: Yes. And i think it all boils down to personal preference but strictly no diesel hor....
  9. #109
    Hydher
    Is selling his GSXR1000
    SBF Phantom Knights Hydher's Avatar
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    my tyre kena nail, removed and repaired by planet for $5.
  10. #110
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    with a worm? thats only a temp solution. You might want to consider a new one after some time of it wearing out a lil more.
  11. #111
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    yeah. got quoted around $90 =( why temp?
  12. #112
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Your balloon has a hole in it, you use scotch tape to cover the hole. It will satisfy you for now but it will still leak and leak. Picture that ;]
  13. #113
    mepkoh
    Deregistered
    Feb 2008
    2,520
    Quote Originally Posted by rehdyh View Post
    it will last a long time..thats my experience with car tyre....at the end of day cannot remember it was wormed..
  14. #114
    danchen
    P Plate
    Apr 2007
    95
    Hey guys, hope to get a second opinion from the "old-bird" phantom riders.
    I'm a new rider on a Phantom TA200.
    Encountering a cluttering sound from the engine area.
    The noise only start when going faster, i.e. past 50km/h
    No noise when idling or low throttle.
    Problem only appear on Monday after going to Pl***t MotorCycle to:
    1) Change Air Filter
    2) Change spark plug
    3) change O-ring
    4) Chain tighten
    5) other minor stuff, e.g. clutch cable adjust, IV bracket, brakepad, etc....
    Chong test ride my bike, say its because my rear suspension is "illegal" one, too high. So after his mechanic tighten the chain, chain become too tight when I sit on the bike and cause that noise.
    He did some chain adjustments for me, it now sound better, but the sound still appear when going at higher speed.
    He tell me must change the suspension to original one then can solve the problem.
    Hope to get second opinion from you guys.
    Is it really a problem with the suspension and chain ?
    How come I never have this sound before even though using the same suspension ?
    Could this actually be Engine Knocking (Spark Knock) or Pre-ignition ?
    Maybe because using of the new spark plug ? ($5 spark plug, cheap stuff...)
  15. #115
    emilsee
    has NC700S. How abt you?
    Class 2B emilsee's Avatar
    Mar 2004
    Location
    BuKiT pAnJaNg
    368
    Dear all,
    Have anyone experienced repetitive sqeaking sound coming from somewhere behind or in the middle of your bike while riding?
    It seems to happen to me when i have a pillion. When i ride alone, it only happens sometimes, especially when i try to negotiate a corner.
    Any idea what could be the problem?
    Is it wheel bearings or wheel shaft.
    My bike already 5yr old.
    Dec 2003 - July 2010
    Honda Phantom TA 200
    July 2010 - July 2012
    Honda Super Four Revo
    July 2012 - Current
    Honda NC700S ABS
  16. #116
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by danchen View Post
    3) change O-ring
    4) Chain tighten
    since you are new, have you tried oiling/lubricating your chain? Try with your engine NOT running, press/sit down on your seat and stand. Repeat that to confirm if sound is from suspension.
    Quote Originally Posted by emilsee View Post
    Dear all,
    Might be rear wheel bearing if noise from rear. Or your suspension? Try and follow what I mentioned above to the other dude.
  17. #117
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    3) change O-ring
    4) Chain tighten
    I would trust ah chong =)
  18. #118
    lawbah
    May 2008
    1,267
    Yeah i would trust Ah Chong too... dun think it is the plug.... i used their plugs, those $5 ones... so far so good also... go back and ask him again lor...
    btw, which mech do for you ??
  19. #119
    danchen
    P Plate
    Apr 2007
    95
    Dun know the name - The crew cut guy, quite tanned, look like in his 40s one...
    Yeah, i went back to ah chong again today.
    Been there 3 times this week, Mon + Tues + Today...
    One of his mechanic tell me, "hey, how come i everyday see you here ?"
    (i was thinking, "of course bike got problem lor. if not what, think i got a crush on Ah Chong ah ? everyday come here and stalk him...." )
    anyways, got Ah Chong to test again. Re-describe the problem to him, turns out he was hearing a different sound from me when he told me it was a chain issue...
    I was talking about a cluck-cluck knocking sound from the engine/front area, while he was hearing a tick-tick sound from the chain.
    told him have to wack the engine harder to hear the sound...
    so Chong went out and wack my phantom till 100+.
    Now he tell me its my front suspension casing knocking against the fork. (previous owner installed a steel plating/casing around the front suspension.)
    I kind of believe him... Maybe because when i wack the engine hard, there is more vibration, so the sound come out.
    any other bro got similar steel casing around the front fork ?
    any such problem ?
    Ah chong say can remove the casing for $20 fee... but i kinda reluctant to remove, cos it looks so nice and shiny....
    Any other solution ?
  20. #120
    SNapEl
    wants to go for a looong ride~!!
    TeePee SNapEl's Avatar
    Aug 2007
    2,398
    See if you can dampen the knocking lor... Stuff paper in the gaps? lol
  21. #121
    lawbah
    May 2008
    1,267
    any such problem ?
    Answer to your first question is Silent Hunter.... he has some sort of casing too.... can check with him...
    Answer to your 2nd question, since not much of a technical problem or whatsoever, live with the noise.
    Cheers!!
  22. #122
    danchen
    P Plate
    Apr 2007
    95
    Thanks for the info SNapEI & Lawbah...
    Good idea. I'll try find something to stuff into the casing first.
  23. #123
    protecter1
    P Plate protecter1's Avatar
    Aug 2008
    87
    It is quite chilly in these two days. My TA200 suddently become hard to start.
    Now I need to hold the throttle for 1~2 minute to warm it up. Or by tuning the idle speed high.
    My choke does not work. It is strange. The engine cannot keep runing if I pull the choke out. Had to increase the idle speed.
    After running for 10 minutes, I have to tune the idle down.
    Anyone got the same problem? The problem comes from spark plug? Or carb?
    The pickup speed is still ok, similar to before.
    TA200 now.
  24. #124
    armani123sg
    TeePee armani123sg's Avatar
    Feb 2008
    Location
    Woodlands
    2,833
    10 (100%)
    6 Post(s)
    1 Thread(s)
    hi guys, i got a ta 200, can i check, if ur engine oil is too much, meaning more than the "xxx" marking on the dipstick, will it give out smoke at exhaust? thanks guys.
  25. #125
    FD1976
    L Plate
    Feb 2006
    35
    Just wanna highlight my case to some new pk's here;
    To check regularly the wear n tear on ur front tyre according to manual. Cos steering cone replaced yest due to "below-limit" front tyre and of cos not to forget a new front tyre. So total damaged is $70 front tyre + $65 steering cone = $135. image top up another 15 can change both front n rear. So dun save abit n pay more like me... also, safety is an issue with botak tyres..
  26. #126
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by armani123sg View Post
    Too much of good things will be bad, but in this case it won't lead to black/white smoke emitting from exhaust. Too much would cost you a leaking gasket if I didn't remember wrongly. White smoke is because of EO + petrol, which also means piston ring area leaked it in.
  27. #127
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    any such problem ?
    does it spoil anything to leave it there? if yes, change. of no dun change lor. ask ah chong if it will spoil anything.
  28. #128
    armani123sg
    Feb 2008
    Location
    Woodlands
    2,833
    10 (100%)
    6 Post(s)
    1 Thread(s)
    Quote Originally Posted by jB View Post
    icic. so even with extra EO, there wont be white smoke ya? only if got a gasket or piston problem then will have white smoke ya?
    in this case, i think mine got a piston problem, cause got a weird sound at the front of engine. think nd to overhaul and change it. thanks bro. really appreciate it.
    anyone knows the price of just changing piston and whats the fastest time it will take to finish repair? thanks guys.
  29. #129
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    your gasket spoil, you'll see leaking EO I think, on the left side of bike. Piston problem maybe, let planet motors diagnose and give you the best quotation. Find the pricing in the thread Typical Pricing for something something lol.. Happy CNY
  30. #130
    danchen
    P Plate
    Apr 2007
    95
    this thread very useful... can self let a noob like me self-diagnose abit.
    My TA200 suddenly having problem going faster than 100km/h.
    Usually very easily can hit 110km/h on expressway,
    but this few days, I throttle hard on 6th gear, engine rev high & loud, but speed like stuck at 90+ only. What's more, I've been finding it hard to kick some gears.
    So, i guess the problem is this....
  31. #131
    sh3rman
    Class 2 sh3rman's Avatar
    Feb 2009
    Location
    Woodlands
    948
    Solution: Retune the carb..
    how much would retuning the carb be??
    my ta200 once in awhile got minor 'bang'
    sometimes BIG BIG 'bang' until both my pillion and i will jump
  32. #132
    breadman
    TeePee breadman's Avatar
    May 2008
    Location
    Bt Panjang
    1,627
    1 (100%)
    5 Post(s)
    wow nice thread
  33. #133
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    thats the purpose of me creating this thread dude Glad that it helped you in a way or another.
    Quote Originally Posted by sh3rman View Post
    Some places are FOC when you buy or do something with them Some don't even need anything to do it for you
  34. #134
    sh3rman
    Feb 2009
    Location
    Woodlands
    948
    thanks alot..
  35. #135
    munch
    P Plate
    Dec 2004
    109
    For curious folks like me...
    Planet Motor's address:
    3007 Ubi Rd 1
    #01-430 Singapore 408701
    Tel/Hp : 67474740
  36. #136
    Alvin88
    Class 2B
    Aug 2007
    275
    Hi guys.. Recently i encounter a problem and hope to hear from all of you. I have difficult changing gear. especially when just finish washing my bike. it's like so rough and i need to use lot of strength to kick up the gear, ok in another word it means not smooth. what could be the solution?
    It's Just A Matter of Want it or Need It?
  37. #137
    DragonLee
    SBF Phantom Knights DragonLee's Avatar
    Oct 2003
    Location
    central
    1,088
    4 (100%)
    Quote Originally Posted by Alvin88 View Post
    its either it's time to change your engine oil or maybe you can juz spray some lub onto the linkage of the gear lever. if the prob still there, then maybe the clutch plate gotto be replace.
    "Respect All Others Until They Disrespect You."
  38. #138
    Alvin88
    Class 2B
    Aug 2007
    275
    ok thanks a lot bro.. !
  39. #139
    edwinteo
    L Plate
    Mar 2008
    13
    Hi, I am ta150 rider. Recently, I had this problem:
    Morning when going to work, still dark, my bike was OK.
    But afternoon (3pm-6pm) when comming back from work, my bike will stall after riding for about 30min. This happen when slowing down at traffic light, just before stopping. Then after that cannot start, have to wait about 15min before can carry on home, bike will stall after 1km, then have to wait again.(normal trip-40min, now 1hr+ to reach home). At night or morning, bike can star with 1 kick.Have been having this problem for 1 week already. Anyone got this problem before? Kindly advice please...........
    Just change plug 1 week ago.
  40. #140
    Hydher
    May 2008
    3,551
    1 (100%)
    32 Post(s)
    1 Thread(s)
    Quote Originally Posted by edwinteo View Post
    suggest that you get your bike checked.
  41. #141
    mepkoh
    Deregistered
    Feb 2008
    2,520
    check for spark....remove spark plug from engine..connect plug to your plug cap..place spark plug against engine and kick start engine..u should see spark jumping across the electrodes..(this is to confirm u have a good plug or reuse your old plug to confirm plug bad /good.)
    but if engine keeps on cutting off...CDI could be the culprit..IMHO..
    if it is..the engine cut off will be more frequent..
    bad petrol could also an issue...drain your petrol to look out for water/sediments etc.
    the
  42. #142
    SNapEl
    Aug 2007
    2,398
    Fuel mixture too lean? get mech to check and tune carburetor air fuel ratio screw.
  43. #143
    edwinteo
    L Plate
    Mar 2008
    13
    Quote Originally Posted by mepkoh View Post
    the
    Thks, mepkoh. Will try to drain petrol this weekend, just in case have to take bus to work on monday!!!!
    I (with friend's help) tried taking out the carb but seem ok(shining and no scratches). I also spraied some oil(like WD40) into carb.
    By the way, what is CDI? Where is this CDI, may be I can take it out to see any problem.
    One more thing, do you know what is the container for?(under rider seat, between battery housing & chain, in front of rear wheel) It seem to be empty with some tubes(looks like liquid tubing) connected to it. It is white in colour (just like 2T container type of plastic).
  44. #144
    edwinteo
    L Plate
    Mar 2008
    13
    Quote Originally Posted by SNapEl View Post
    Thks SNapEl, but I tried to increase the engine rev by turing the knot cloclwise (1 round). The engine seems roaring very loud then I open chok then the rev seems to come down. I thought this may be too much then adjust back (1 round) to where it was, then increase slightly 1/4 turn clockwise. Manage to get further (1 time of stalling to reach home) this time.
  45. #145
    SNapEl
    Aug 2007
    2,398
    .... bro are you tuning the idle speed knob on the right side of the bike? the air fuel ratio screw will require a screw driver to tune. Did you use that? its on the left side of the bike
  46. #146
    mepkoh
    Deregistered
    Feb 2008
    2,520
    please do not ever put wd40 into carb....this carb is very sensitive to fluids with low evaporating volatility...there is such stuff as carb cleaner.suggest u reclean the carb..
    the container with an outlet cap..reach it via removing the plastic chrome cover on the right of the seat..is the overflow tub for the radiator fluid..
    CDI=condensor discharge ignition ...this is the electronics that control the spark discharge (after a pulse from the alternator is received)..at the moment have no idea how to test it...understand there is no easy way to test. unfortunately not sure where is it located...i suppose if u trace the pulse cable u will able to find it..this is most likely a black box with 2 connectors...sorry. the cdi is not cheap..maybe more than $100...
  47. #147
    mepkoh
    Deregistered
    Feb 2008
    2,520
    if u experience stalling of engine when engine is hot..and stall while idling ..like at traffic lights.junction etc...thses are signs of lean mix...
    causes fuel mixture too lean..
    leakages of air into the combustion chamber via leaking vlaves, carburettor ,joints etc..
    symptoms: bike stalling when engine is hot, spark plug electrodes will be whitish and very dry..
    normal coloour is brown..
    if black and wet looking this i either too rich or from EO contamination..
    if after adjusting the fuel mix jets and the problem still occurs..it is time for a check and repair at the mech..
  48. #148
    edwinteo
    L Plate
    Mar 2008
    13
    hi mepkoh, the fuel mix jets you mentioned, is next to idling speed adjustable knot right? It is like bronze in colour right? Which way am I suppose to turn? Is it Clockwise for richer mix & anti-clockwise for leaner mix right?
    Anyway, just got oil change, battery change, bearing change today but still have to stop once before reaching home. The mech told me it is the CDI that is giving me prob. If need to change will cost $200. Any recommendation about the price or good mech for the CDI? So far had spent about $150 these few days already.
    Going to eat grass liao!!!!!
    hai!!!!!!! hopefully will have better luck after this!!!!!!!!
  49. #149
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    You head down to Planet Motorcycles in Ubi, you ask them to diagnose. They say change what, you change, they don't say, you don't change. Darn hard to spend unnecessary down there dude
  50. #150
    MrKan
    Class 2 MrKan's Avatar
    Oct 2006
    Location
    marshall islands
    985
    hi, sorry ah. my friend engine spoil how?
    Gilera Runner 06` 04/07 - 11/07
    Toyota Axio- 11/07 - 02/08
    Mitsubishi Lancer Ex - Current to ??/??
    Honda Cb400 Vtec 1 06/08 - 02/09
    CBR600RR '08 12/09 to ????
