Page 1 of 36 1234511 ... LastLast
Results 1 to 50 of 1784
Thread: [Technical] Possible Solutions to your Phantom's Problem
  1. #1
    jB
    has 4 and counting! :D
    SBF Lacer jB's Avatar
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Default [Technical] Possible Solutions to your Phantom's Problem
    Think almost everyone is seeing a new thread now & then asking for help to a problem from someone new to SBF. Some might get harsh on them( Inclusive of myself at times, I apologise). So I was thinking we might as well start a list that will continue down what we should look out for in/on our bike if something were to fail and we try to rectify it. Moderators please feedback on this if it ain't appropriate or clashes with other existing threads.
    Please copy the template and add on your recommendations with smiles
    jB :]
    For eg.
    Problem <1> - Exhaust emitting white smoke
    Solution :
    - Your bike is a 2 stroker, Ta 150
    - Engine Oil mixing with your petrol ; piston ring worn out?
    - your third solution/suggestion here
    Problem <2> - Your problem here
    Solution :
    Click below link or copy+paste for good deals!
    http://www.singaporebikes.com/forums/showthread.php/417915-WTS-Shoei-XR-1100-Diabolic-Cimmerian-Mint-Condition-L-Size-CHEAP!-9-8-10?p=8191458#post8191458
    http://www.singaporebikes.com/forums/showthread.php/406472-WTS-Blaupunkt-Style-Headphones-Unopened-BNIB!
  2. #2
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    jB recommends Planet Motorcycles if you need to diagnose/fix your bike
    Planet Motor's address:
    3007 Ubi Rd 1
    #01-430 Singapore 408701
    Tel/Hp : 67474740
    UPDATED by jB <23 Nov 2011>
    Solution: Its normal.
    Turning the screw clockwise to enrich the mixture. (once again, tune in 1/4 or 1/2 turns of the air correction screw, located on the LEFT side of the carb)
    Bike tends to rev rapidly but have poor acceleration if lean, and if too rich, will have "spongy" / slow throttle response at high speeds.
    If in need of advise / demonstration sms pandora's kitten at 93270801 (advice/demo given is FOC)
    Reason: Air leakages.
    Reason: Air filter clogged.
    Solution : Get your air filter changed. You are advised to inspect the air filter every 4000 or so kms and change it at 10k (Honda warranty service manual)
    Solution 2: Buy a can of fix a flat from Carrefour or petrol stations, put it in your box.
    Reason: Fuse may be blown.
    Solution: Obvious.
    Reason: Water in petrol
    Others:
    - Check magneto coil.
    Solution: If you have very poor acceleration when throttle is opened, you are running lean. Enrich mixture by 1/2 to 1 turn of the air correction screw.
    Solution: If you are using spray on chain lube, dirt and grease may be thrown off the chain during normal operation. When a lot of grease accumulates on the chain tensioner (rubber cylinder) and swingarm protector (rubber bar) the chain will emit a loud sound as though running through sand. Scrape and wipe away the excess grease and enjoy the quietness.
    Solution:
    - Send to bikeshop.
    Solution:
    - 67474740 Tiko cheong.
    - 64560018 Wing Yap.
    Reason: Gasket Spoilt.
    Reason: Speedo spoilt.
    Solution: Bike shop.
    Reason: Clutch is worn
    Solution: Fuel/air mixture too lean giving poor acceleration and a hot engine
    Solution:Change new bearings.
    Problem 21: Weak Battery.
    Problem 23: IU Spoilt.
    Solution: Fuel-air mixture likely too rich. Backfires when throttle is closed, due to residual fuel afterburning in the exhaust header. This is bad for the valves and the catalytic converter.
    Solution: Do DIY exhaust wrap. Reduced backpressure = faster heat evacuation, leading to high speed silent running and silent cooldown after engine off. (Pandora's Kitten :3)
    Solution: Gear box dying.
    Solution: Engine is overheated. (Running too lean/ Not enough engine oil. An overheating engine may cause excessive oil consumption, especially when using less tolerant mineral oil)
    Problem 27: Handlebar position is not centered (while riding). Handlebars are "straight" but wheel points to one side.
    Solution: Lock the wheel, grab the handlebars firmly and twist the bars until straightened. The risers are flexible to some degree, due to the vibration damping rubber washers. (Demonstrated by Planet Motors)
    Solution: If your steering lock is spoilt, put the wheel against a pillar or a wall.
    Problem 28: Bike hard to U-turn. Riding position not comfortable as handlebars too high up.
    Solution: Adjust the angle of the handlebars. Loosen the bottom two screws of the risers, pull back the bars so they "rise" towards your face. This will give you a more relaxed riding posture and you are able to enjoy a greater turning angle at low speeds. If your handlebars are set to rise straight upwards forcing you to stretch forward and upwards to steer, your elbows will prevent you from turning easily at low speeds.
  3. #3
    Jax
    P Plate Jax's Avatar
    Jul 2008
    185
    Solution :
    Problem <2> - Engine stalls in heavy rain
    Solution :
    - change plug cap
  4. #4
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    jB :]
    Solution :
    Solution :
    - change plug cap
    - spark plug could be wet, remove it to "dry" and try again.
  5. #5
    lawbah
    Class 2 lawbah's Avatar
    May 2008
    1,267
    Solution :
    Solution :
    - Change plug cap
    - Spark plug could be wet, remove it to "dry" and try again.
    - Might need to tune carb.
    Problem <3> - Flat / Punctured Tyres
    - Try to inflate tyre with portable pump / bicycle pump then go bike or tyre shop. DO NOT ride on flat tyres as they may damage your tyre or wheel.
    - Use tyre repair kit, plug and pump = good to go. Kit can be bought at LAB.
    Problem <3> - Cannot / Hard to start bike
    - Push Start.
    - Check Fuse. Fuse is located on right side of bike. Remove chrome cover under the seat and see. look out for the centre of the fuse if its broken then FUSED lor. change new one.
    - Make sure bike is in neutral, Kill switch is not depressed, key is turned after inserted. If its none of these check if battery is working.
    - Rectifier issue / battery issue- very common for phantom ta200 . get your mechanic to check with a voltage meter. ah chong has one.
    - Petrol topped up too full - dont laugh. the petrol is not meant to be filled to the brim. but rather with some space for air.
    - Water in petrol - could be the problem too
    Problem <4> - Cant go more den 80 km/h
    - TA200 have 6 gears. Make sure you are already at top gear.
    - Ensure that the correct amount of EO is put in.
    - If confirm no 6th gear, go bikeshop check gearbox.
    Problem <4> - Weird sound on my bike
    - Might be battery low.
    - If sound is on gearbox side, check your chain tension 1st.. should be bout 2 to 3cm slack, tested at the center of the bottom span of the chain. Anything more, get it tightened.
    Problem <5> - Exhaust Header got holes. Can repair?
    - Got one specific hole which is ok. If otherwise, post some pictures.
    Problem <6> - Engine oil Dip stick broken (Broken part might be in engine)
    - Send to bikeshop.
    Problem <7> - I have tried everything but to no avail. Any tow numbers please?
    Problem <8> - Engine Part Leaking Oil
    - Gasket Spoilt.
    - Cam chain tensioner spoilt.
    Problem <9> - When riding, bike lean to one side. Let go of handlebar, steering was shaky and wobbling
    - Might be steering cone problem.
    - Might be bearings spoilt.
    - Wheel alignment might have problem.
    Problem <10> - Speedo is not working
    - The cable, or the gear at the end of the cable is spoilt or loose.
    - Speedo spoilt.
    Problem <11> - My exhaust pipe got so sound (Backfire)
    - Retune the carb.
    Problem <12> - I lost my bike Key!!! What to do??
    - Go find keysmiths.
    - If want to change ignition, look for Ah Chong (Planet) or scrapyard.
    I merely compiled all the useful comments into point form. Credits goes to those who helped to answer these questions.
  6. #6
    Jax
    Jul 2008
    185
    Solution :
    Solution :
    - Change plug cap
    - Push Start.
    - Send to bikeshop.
    - Gasket Spoilt.
    - Speedo spoilt.
    - Retune the carb.
    Problem <13> - Bike pickup super slow. even slower than cars.
    - change ur clutch plates.
  7. #7
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    good compilation job Lawbah but I wonder whats the max limit of words we can compile in one post.
  8. #8
    SNapEl
    wants to go for a looong ride~!!
    TeePee SNapEl's Avatar
    Aug 2007
    2,398
    Problem 2: Engine stalls in heavy rain and unable to start.
    Reason: Air fuel mixture may be too rich.
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
  9. #9
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by SNapEl View Post
    Solution:
    this is a nice one, really got me laughing out loud. nice effort
    SNapEl
  10. #10
    lawbah
    May 2008
    1,267
    Well... i think someone did a better job... nice one SNapEl...
  11. #11
    SNapEl
    Aug 2007
    2,398
    Lol thx it was nothing. You guys provided the info, i just do some re-organising. Actually if can copy, edit and paste on to first post will be better. lol jB gotta keep updating his first post liao like that lol. Mod sticky can? lol
  12. #12
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    thats why my 2nd post was put as Reserved Post but I forgot to create a few more just in case the max limit for one Post is reached.
    Arghhh! don't sticky it so soon because I realised I myself hardly notice the sticky threads side myself so I suppose some others won't too.. unless the sticky threads are much attractice and not so dull
    anyway thanks for the contributions.
  13. #13
    daWizard
    L Plate
    Jun 2008
    16
    Well done bros...great post...
    I have one...heh heh...problem, not solution...perhaps you guys can figure it out...
    Today, when I was riding...something felt wrong between 2nd and 4th gears...when I shift down, the engine roared like the gear is too low...but when I shift up, the engine whines like the gear is too high...only when I hit 5th gear and up does it sound normal again...but when I reach the next light...the same thing happens again...fine at 1st gear too...but 2nd 3rd and 4th gears all sounded off...what could be wrong??
    Will bring it to a mech tomorrow...but for now, anyone care to diagnose??
    There is no charge for awesomeness...
  14. #14
    tangys
    P Plate tangys's Avatar
    Oct 2007
    Location
    Jurong West
    191
    bike after using for a few months feels like
    getting less and less power (acceleration,
    6th gear speed, etc.) how ah?
    is it need to clean the air filter and spark
    plug?
  15. #15
    SNapEl
    Aug 2007
    2,398
    Quote Originally Posted by daWizard View Post
    Probably your gearbox is whacked.. which mech you bringing to? careful dun kanna carrot. Best is if the mech can go a round with your bike then tell you whats wrong rather than just hear what you say.
  16. #16
    SNapEl
    Aug 2007
    2,398
    Quote Originally Posted by tangys View Post
    plug?
    When is the last time you changed engine oil, air filter and plug?
    Basic maintenance:
    Change EO every 2000km
    Change Spark Plug every 4 EO changes
    Clean air filter every 2 EO changes and change every 10000km
    If basic maintenance is done, check chain if loose, tyre pressure, tyres not more than 5 years old.
  17. #17
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    hmm I don't have a solution to that but I'm thinking
    1) throttle cable gone haywire? over rev by itself?
    2) you're not at the right gear, somehow?
    3) airbox? need some tuning?
    4) problem with your gears?
    plug?
    you didn't change your EO/Air Filter/Spark plug? pump Tyre Pressure?
    Basic maintenance:
    I used to change monthly EO w/out hitting 2k at times
    spark plug change every 2 EO change and filter per 2-3x EO change. Actually tyres shouldn't be more than 1 or 2 year old usage
  18. #18
    daWizard
    L Plate
    Jun 2008
    16
    Thanks bros for your answers...
    Brought to a small shop mech, near my place...he rev rev engine, didn't even ride around...says no problem...
    I rode around after...yeah, not as bad as before...anyway...since don't seem serious, maybe leave it till tomorrow...if have time maybe go to planet...
    Thanks again...
  19. #19
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    solution 5) maybe it was just your mind playing tricks on you
    if you have any more fear about engine and all, ah chong from planet motors would help you loads but he's not god though, don't expect 100% cure
  20. #20
    \\StaN//
    Slow Rider.
    SBF Lacer \\StaN//'s Avatar
    Oct 2004
    Location
    Where There is Water.
    5,956
    Thanks again...
    how old is ur bike?
    when in 1st gear n fully clutch in does it felt like it wans to move off?
    my suggest possible clutch plates worn out.
    go get it checked.
    Riding is Like Fine Wine,It Gets Better With Age
    Riding is a Passion That Glows n Never Will Fade
    Riding is Like an Eternal Flame,Burning Passion Till The Very Last Days
  21. #21
    daWizard
    L Plate
    Jun 2008
    16
    Quote Originally Posted by Haya^Busa View Post
    how old is ur bike?
    go get it checked.
    No bro...nothing like that...anyway, didn't get off work till very late, so no chance to go to planet...next week first....
    Thanks
  22. #22
    lawbah
    May 2008
    1,267
    <UPDATED JULY 23RD>
    Reason:
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
  23. #23
    lawbah
    May 2008
    1,267
    <UPDATED JULY 23RD>
    Reason:
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
  24. #24
    Zhi Ming
    rides a TA200
    Class 2A Zhi Ming's Avatar
    Jun 2008
    Location
    Singapore North
    543
    4 (100%)
    1 Thread(s)
    Unhappy
    Guys need help please, just now i was coming back home, bike was ok when weather still held...then the rain came...then my bike died when i stopped at traffic light at adams,after repeated tries still couldnt start so i called my friend, he say drizzling shouldnt stall bike but wait awhile then restart...it worked then after awhile at thomson it again died..did the same trick then died again at marymount before finally dying at bishan and then reach home AMK...all the times it died was when i stopped at traffic lights.
    I have been riding the bike for 6weeks, never had this problem before, can the idle speed change by itself? or was it just the spark plug getting wet even though it was only a drizzle? i am taking bus to work tmr liaoz...sianz
  25. #25
    SNapEl
    Aug 2007
    2,398
    Don't you think your issue is very similar to that as stated in Problem 2? zzz the answer is there! If your bike can start tml morning you can be doubly sure liao. zzzz. If you totally not sure or dun wanna think, pay $ tow to a mech and pay tuition fee lor
  26. #26
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Hey dude, I doubt its the 好兄弟 pulling pranks on you at junctions
    Anyway jokes aside, try tightening your spark plug or go with problem 2. Idling shouldn't change or change much due to riding vibration; I know our bikes vibrate alot.
    you remind me that I've forgotten to go down to AMK to view someone's bike condition
  27. #27
    Zhi Ming
    rides a TA200
    Jun 2008
    Location
    Singapore North
    543
    4 (100%)
    1 Thread(s)
    Quote Originally Posted by jB View Post
    Hey, my bike is fine today already, guess its really the sparkplug + rain...anyway will go play around with the idling also..think its a little too slow...thanks for the suggestions !
  28. #28
    Jax
    Jul 2008
    185
    bro i had the problem too... even a drop of water can stall ur bike.. i changed my plug cap and the problem nv come back again..
  29. #29
    thenation
    TeePee thenation's Avatar
    Nov 2007
    Location
    Hougang
    2,615
    1 (100%)
    2 Post(s)
    Bringing up thread for the new guys.
  30. #30
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    Quote Originally Posted by thenation View Post
    thanks mate, any solutions to contribute?
  31. #31
    thenation
    Nov 2007
    Location
    Hougang
    2,615
    1 (100%)
    2 Post(s)
    Unfortunately, none to contribute because fortunately, there haven't been problems with my phantom recently
  32. #32
    djkhemical
    P Plate
    Nov 2007
    Location
    On the road
    194
    1 (100%)
    i have the same probs when rainning, haven`t had time to change the cap yet. But my bike also back fires alot, where is the screw to tune the mixture??
  33. #33
    joekoh
    P Plate
    Apr 2007
    69
    hmmm think something wrong with my break, no tension when i squeeze in, is it the brake fluid low??? hmm cause the previous owner, go and respray and spray the thing black also can't see.. so my front brake not working now
  34. #34
    chuan.z
    Class 2 chuan.z's Avatar
    Jun 2007
    Location
    SG,SG
    1,282
    Quote Originally Posted by joekoh View Post
    very good guess... either low or ur brakes are leaking fluid liao... u can check the brake fluid level by opening the two screws on the square box (brake fluid reservoir)... careful not to let any brake fluid drip on ur paintwork... wipe off immediately and rinse with water if kena... if low, can bring to mech or DIY top-up...
  35. #35
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    I mean those solutions you've seen or offered to others which is not in this list dude
    Quote Originally Posted by djkhemical View Post
    its on the left side of your bike, don't have a picture for you though. Or you can try meddling with your idling knob first to try? checked your air filter recently?
    Quote Originally Posted by chuan.z View Post
    best to put a thick towel on tank with the handle bar locked to left. Else let a mechanic do it as he might also have to change brake pads(could be worn out or not properly installed)
  36. #36
    djkhemical
    P Plate
    Nov 2007
    Location
    On the road
    194
    1 (100%)
    [QUOTE=jB;4614360]I mean those solutions you've seen or offered to others which is not in this list dude
    i`ve changed the air filter bout 2 mths ago. after i changed the spark plug i notice the bike dying in the rain and the back fire
  37. #37
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    whats the spark plug change like? check if its screwed in properly
  38. #38
    Zhi Ming
    rides a TA200
    Jun 2008
    Location
    Singapore North
    543
    4 (100%)
    1 Thread(s)
    joe no tension at all might mean the brake lever unit spoilt...change the hwole thing roughly 80-85 at ah chong. i did it before so u better let him see if its the problem.
  39. #39
    joekoh
    P Plate
    Apr 2007
    69
    wahaha.. thanks for all the info, got it fix already, was the brake lever unti spoil and also my brake disc is out of shap, but the strange thing is i never knock into anything or fall down, so also don't noe why out of shape, total damage is 110, the brake dis is second hand de.. wahaha painful man.. cheers.. but cannot save on the brake man can save out life
  40. #40
    Zhi Ming
    rides a TA200
    Jun 2008
    Location
    Singapore North
    543
    4 (100%)
    1 Thread(s)
    haha glad to hear your problem solved..ride safe
  41. #41
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    jB :]
    <UPDATED August 4TH 08>
    Reason:
    Solution: Obvious.
    Others:
    Solution:
    - Send to bikeshop.
    Solution:
  42. #42
    lawbah
    May 2008
    1,267
    up for those people who dont know the existence of this thread.
  43. #43
    vincekam
    SBF Moderator vincekam's Avatar
    Aug 2004
    Location
    Pasir Ris
    3,778
    16 (100%)
    7 Post(s)
    1 Thread(s)
    Hey, do you guys think this thread is worth to be sticky?
    PM to let me know so I can put glue to it.
    Cheers!
    Women will never be as successful as men because they have no wives to advise them.
  44. #44
    kmax
    rides bicycle
    SBF Cruisers kmax's Avatar
    Aug 2006
    Location
    valle d'or
    11,349
    7 (100%)
    43 Post(s)
    well, not much people will read thru sticky but happy open new thread...
  45. #45
    vincekam
    Aug 2004
    Location
    Pasir Ris
    3,778
    16 (100%)
    7 Post(s)
    1 Thread(s)
    So we gotta decide what we should be about it:
    1. shall we beats them up for opening new threads without doing a search?
    2. Close their thread?
    3. Argue with them and get into trouble?
    4. Drive them out of this forum?
    We all were once a newbie before and I believe I am still one now.
    Some learn from their mistakes and some find it hard to swallow their ego and fight back.
    So, when there is a issue, we need to find the root cause and get ride of it. So far I haven't got any solution for this.
    I wanna hear your thoughts on this.
    Oh man, I think jB really did put a good effort on this thread and I thought it'll serve good purpose for those who open new thread all over.
    Damn.. looks like I have to delete many un-necessary post we created here. heh heh
    Psst.. heard you clear meter eh.. wipe it real clean okie, so you can watch what speed you're riding.
    Cheers!
    Quote Originally Posted by kmax View Post
  46. #46
    jB
    Jan 2007
    Location
    a place w/out ERP
    18,119
    4 Post(s)
    1 Thread(s)
    1. well I'd still say the search function ain't idiot proof like yahoo yet
    2. would be good to pm them before/after you lock it and guide them.
    3. We were once soldiers too
    4. not nice to shoo others away
    I don't know if it should be a sticky or not let the others decide..
    sometimes I find that not everyone will pay attention to sticky or realise that its there because its not outstanding enough.
  47. #47
    kmax
    rides bicycle
    Aug 2006
    Location
    valle d'or
    11,349
    7 (100%)
    43 Post(s)
    Quote Originally Posted by vincekam View Post
    well, uncle vince... this is very informative thread indeed... but again i ask people around here (in PK forum, how many people browse through sticky section with many informative links and notes before posting new thread).
    i really miss kiamh's PK directory thread.
    since moderator is voluntary basic, we do not wish to burden u with loads of unnecessary moving and cleaning too.
    if u see the thread needs to exist, just let it be... or if u think they fall under same category (like newbie questions, chit char corner) please feel free to do so as it is..
    people come and go, so do threads...
    after all it's free forum and we are free to post here
  48. #48
    SNapEl
    Aug 2007
    2,398
    Put limit on who can start a new thread lor... sa like post counts >50 or maybe >100... at least it gives them 50 or 100 posts to learn before starting their own threads, and their participation being limited to the many many many threads of wide varieties should not be a problem. In fact even if you lao jiao in PK forum also no need to start new thread sia... everything all have liao. zzz
  49. #49
    kmax
    rides bicycle
    Aug 2006
    Location
    valle d'or
    11,349
    7 (100%)
    43 Post(s)
    that's not upto PK's moderator's power i guess.
    anyway, it's great forum and friendly people... just we bull$h!t alot
  50. #50
    joekoh
    P Plate
    Apr 2007
    69
    hmmm i suggest u all change the title la.. like' see here for ur phantom problem' don't put possible la.. very blur for new rider.. but this is a good post la.. help alot of new rider.. so thumbs up for u guys..
