Results 1 to 10 of 10
Thread: Need help for 2A - Fig 8, Crank Course, Slalom
  1. #1
    ahmad0410
    P Plate
    Jun 2008
    Location
    Marsiling
    83
    Default Need help for 2A - Fig 8, Crank Course, Slalom
    Hi guys, I passed my 2B six years ago and havent rode at all since passing. Now I'm taking 2A at SSDC and have problem with these courses.
    Figure 8: I'm getting better at this after the previous revision, but all this while I tried to keep my body as upright as possible and not use the foot brake at all, as I thought that was the way to do it. Until an instructor pointed out that I have to lean with the bike as much as I can. So I tried leaning the bike and use foot brake most of the way, and it felt more stable, not sure if it's any faster though. So which is better?
    I'm also very afraid if I lean too much my feet will touch the ground, or the crash bar hit the kerb. Will it happen?
    Crank Course: This one is really bad. I find it hard to enter the course smoothly with first gear, it's either to fast, or too jerky. When on the first line after entry, when I close throttle to change to 2nd gear, the engine braking is so strong that I cannot concentrate on changing to second gear.
    I managed to do it properly once, but the engine was so close to stalling. I didn't use any foot brake. May I know what's the best technique to do the crank course - eg braking, leaning, gear changing.
    Slalom: I haven't manage to hit any cones before, but I think it was all luck and my technique is wrong. How do you guys do it? Should I throttle when coming out from each cone? Or maintain throttle all the way but make use of footbrake?
    All tips will be taken when I take my next revision. Thanks guys!
    Enrolled 2B: 11 Apr 2009
    Passed Prac 1: 6 May 2009
    Passed Prac 2: 15 June 2009
    Passed Prac 3: 14 July 2009
    Passed Prac 4: 3 August 2009
    Passed Prac 5: 15 August 2009
    Passed Prac 6: 17 September 2009
    Passed Prac 7: 12 October 2009
    Passed Prac 8: 19 October 2009
    Passed TP: 3 December 2009
  2. #2
    Palladium
    L Plate
    Feb 2015
    11
    Just some tips as a 2A learner waiting for TP, YMMV:
    Figure 8: You have to lean inward with the bike when you hit the curve, maintain the throttle where your bike is smooth throughout the 8 and doesn't wobble and your eyepoint need to be about 3~5 meters in front of the bike's path. If speed too high gentle decrease throttle, but do not release it fully. Try not to use the rear brake at all until the end.
    Crank Course: I think it's your acceleration isn't hard enough in 1st gear when moving off from stop. By the time I change 2nd gear in the first corner I don't need to apply any throttle anymore to the end. It's quite normal for the bike to jerk a bit after 2nd gear is released fully IMO.
    Slalom: When you want to go left push the left handlebar down, same for the right side...The front wheel will automatically turn in the same direction. Make sure your body is upright and not leaning forward. Eyepoint I usually see 2 cones in front of me.
  3. #3
    ahmad0410
    P Plate
    Jun 2008
    Location
    Marsiling
    83
    Thank you Palladium! I will use your advise for my revision tonight.
    Is it possible to lean to much until the crash bar touch the ground/kerb?
    Will tapping on rear brake while leaning cause the wheels to lock?
  4. #4
    Genius
    P Plate Genius's Avatar
    Nov 2010
    191
    2 Post(s)
    I have a problem. class 2A bike quite powerful. For pylon, I always stall after changing into 2nd gear. From gear 1 to gear 2, if speed too slow will stall if go abit faster, too fast to go through. How to correct arh???
  5. #5
    KILROY68
    Class 2B KILROY68's Avatar
    Oct 2005
    Location
    BY THE RIVER
    212
    Quote Originally Posted by Genius View Post
    Once second gear, no need to use much throttle, its clutch play.
    Need more speed, release clutch.
    Need less speed, press the clutch and/or use only rear brake.
    You need to master low speed control by playing with the friction zone or the contact point of your clutch.
    Maneuvering anywhere in that speed then becomes secondary.
    https://youtu.be/HwQ8kndW-yc
    Sent from my SM-J5007 using Tapatalk
    19xx - SUZUKI GTO110, HONDA MBX125, SUZUKI RG250, KAWASAKI EN400, KAWASAKI NINJA400, YAMAHA RD350 (YPVS)
    2012-14 - R1
    2014-16 - S1000R
    2014-PRESENT - EXC525 (2005)
    2016-PRESENT - TMAX530 (2016)
    WISHLIST - XDIAVEL S
  6. #6
    Genius
    Nov 2010
    191
    2 Post(s)
    But then in second gear cannot touch clutch already
  7. #7
    ahmad0410
    P Plate
    Jun 2008
    Location
    Marsiling
    83
    This one not a problem for me. I just throttle more before the yellow line. Try change second gear before yellow line. Then let go the throttle. Then just play with the throttle to go thru the course.
  8. #8
    ahmad0410
    P Plate
    Jun 2008
    Location
    Marsiling
    83
    Quote Originally Posted by KILROY68 View Post
    You sure clutch play? I remember we are not allowed to play clutch. Only throttle and footbrake.
  9. #9
    KILROY68
    Oct 2005
    Location
    BY THE RIVER
    212
    Quote Originally Posted by ahmad0410 View Post
    You gonna hv a lot of knocking going slow speed in second gear without clutch involved thars what i think.
    2012-14 - R1
    2014-16 - S1000R
  10. #10
    nsr1980
    Class 2B
    Mar 2014
    234
    4 Post(s)
    eyes look at direction that u going, grip fuel tank with thigh, lean posture, 2nd gear no brake if needed rear brake to slow down speed, don't press clutch.
