View Poll Results: Which type of s4 has the best fuel consumption?
Voters
567. You may not vote on this poll
  • Project Big 1
    47 8.29%
  • Ver S
    199 35.10%
  • Ver R
    12 2.12%
  • Spec 1
    105 18.52%
  • Spec 2
    40 7.05%
  • Spec 3
    139 24.51%
  • Super Bol'dor
    25 4.41%
Page 52 of 52 FirstFirst ... 2424849505152
Results 2,551 to 2,562 of 2562
Thread: [Discussion] Technical - Fuel Consumption
  1. #2551
    awkward
    L Plate
    Oct 2014
    Location
    Lion City
    4
    Quote Originally Posted by HaiR1 View Post
    Possible reason for bad fuel consumption :
    -Airfilter (Dirty/ Clogged up)
    -Spocket (Worn out/ Not standard size)
    -Chain (Not lube/ Chain too slack/ tightened)
    -Tyre (Worn out/ Incorrect Pressure) ( Wrong size)
    -Tyre Valve (Leaking air)
    -Wheel bearing (Not in good condition)
    -Engine Oil (Wrong grade/ Due for change/ Too much)
    -Carburetor (Air/ Fuel not balanced) (Jetting not stock)
    -Fuel (Contaminated/ Low grade)
    -Fuel line/ filter (Clogged)
    -Meter (Inaccurate/ offset)
    -Rider (MotoGP mood/ Fuel-conscious type)
    -Clutch (Clutch plate/ spring worn out)
    -Header Gasket (Worn out)
    -Weight (Heavy luggage/ pillion/ rider)
    -Idling (Too High/ low)
    -Engine braking (Too much)
    -Abrupt braking
    -Hard acceleration
    -Engine condition (TOO much to explain)
    -Brake Caliper/ Brake pad (Brake Caliper piston jammed?/ not free)
    -Improper suspension set-up (Too hard/ Too soft)
    -Servicing (Do on time, dnt overdue)
    -Idle too long (Waste petrol/ Engine hotter/ coolant affected unnecessary/ WaterPump work harder to maintain temperature)
    Tats all I can think off, for now.
    I think that's all that can be contributed.. Lol.
    My Spec 1 FC is also very bad, considering that my bike is fully stocked and I'm only 43 kg -.-
    16km/l. Piang
  2. #2552
    syapek
    P Plate
    Jan 2010
    75
    Does S4 version s have fuel filter? Where is it? Tried googling but nothing much is said about it. Is there anyway to check if it's clogged? And what's the cost to change and any recommende shop?
  3. #2553
    jtzx
    busy man
    SBF Phantom Knights jtzx's Avatar
    Jan 2009
    Location
    B I S H A N
    6,248
    8 (90%)
    18 Post(s)
    2 Thread(s)
    Quote Originally Posted by syapek View Post
    Only have oil filter bro..
  4. #2554
    Siphon
    is a ridiver
    Class 2B
    Sep 2012
    Location
    Sillypore
    412
    5 Post(s)
    Quote Originally Posted by Baal View Post
    yep I heard about that too. Not just bikes or revo, even for cars. When fuel sensor cant sense.....= problem. Just matter of big or not so big $ spent. Not to mention fuels at low levels, heats & stresses the fuel pump for EFI also. When that goes.....also big $. For my car with 45 litre tank, I usually try to pump when theres balance of 1/3 tank. Leave 15L inside to cool & not stress the pump. For bikes unless u NSH going straight line, u will lean here & there when u make a turn/corner. hence if ur fuel level is low, imo would increase the chance of "fuel sensor/pump/injector" issues.
    For S4 with 18 litre tank, imo best not wait till reserve. balance 2 bar I will pump liao. I assume 1 bar approx. 3 litre. So 2 bar = 6 litre ( balance of 1/3 tank).
    Think its total of 6 bars for the 18 litre tank?
    I hit the E with a balance of 3 liters in tank... cause i can only manage to pump in 14.8L... hehe cannot squeeze anymore in...
    so its as advertise. Reserve is 3 liters.
  5. #2555
    gpan
    Class 2B
    Apr 2012
    202
    3 Post(s)
    Been riding my Spec 3 for 6 months. Can get about 320km per tank with 1 bar left on fuel indicator.
    Fill up till full from 1 bar would be 14 liters.
    FC 23km/l.
    I'm a slow rider, mostly upshift at 4/5000 rpm and mainly no pillion and predominately highway riding.
  6. #2556
    ahcaibiker
    loves MV Agusta
    TeePee ahcaibiker's Avatar
    Jan 2009
    Location
    Caucasian Bridge
    2,033
    6 Post(s)
    2 Thread(s)
    been getting 280-290km with the meter just outside of the reserve part of the fuel gauge. riding style pretty heavy on throttle like acceleration. only change to final gear after 80kmh/5000 rpm
    Class 2B - 26/03/2009
    Class 2A - 01/06/2010
    Class 3 - 10/07/2009
    Rides(s)
    1) Honda TA150 - 20/04/2009 to 31/08/2014
    2) Honda CB400 Ver S - 12/07/2014 to ???
  7. #2557
    Siphon
    is a ridiver
    Class 2B
    Sep 2012
    Location
    Sillypore
    412
    5 Post(s)
    Fuel brand and grade plays a part too.
    I know i get really bad FC with caltex. But more responsive. Vpower & Vpower Racing as well... not as good FC but more responsive.
    Day to day i use shell 98. Seems like a good balance. Smooth and good FC.
    Getting about 300 before reaching the 1 bar. 14liters.
    About 22-23Km. mixed road riding. about 40% street and 60% highway daily.
    5/6k rpm change gear. usually cruise at 95 on highway. and 70 on street. With the occasional "clear exhaust" dragging of 3rd gear to 9-10k rpm to work the VTEC.
  8. #2558
    VtecYo
    L Plate
    Jul 2013
    Location
    Singapore
    4
    I'm using Esso Extra (5000) petrol
    Rode for 245km before hitting reserve, I think my fuel consumption is pretty bad. Barely open VTEC and always shift at 5000RPM..
    13 JULY '14 - HONDA NSR 150 SP
    22 JULY '15 - HONDA CB400 Super 4 VTEC III
    Ride defensively.
  9. #2559
    736cc
    Rocking on the road
    SBF Lacer 736cc's Avatar
    Jun 2003
    Location
    woodlands
    7,642
    17 Post(s)
    Quote Originally Posted by VtecYo View Post
    You should get it check.
    Sent from my Mi 4i using Tapatalk
    Current Ride:
    W650 Cafe Racer
    FXSTC Softail Custom
    TW200 Tracker
    Zephyr ZII Custom
    CB750K
    CB400four
  10. #2560
    vtec88
    TRUST nothin but the BEST for his Bike--> BROQUET Fuel Charger !!!
    SBF Lacer vtec88's Avatar
    Mar 2005
    Location
    SillyPore
    8,814
    128 (99%)
    3 Post(s)
    Yo Bros,
    Try BROQUET Fuel charger to get better power and FC
    Super4 Bikers user reviews at my sales thread below.
    http://www.singaporebikes.com/forums...lize?highlight=
    https://www.facebook.com/pages/Vtec8...15899711838681
    Do take a look and thanks in advance ;-)
  11. #2561
    WISEASS
    L Plate WISEASS's Avatar
    May 2016
    Location
    Shanghai
    5
    how accurate are the 2002-2003 fuel gauges?
    i've filled it full and its already hovering between 50%-60% after 50km.
    anyone else experience something similar?
  12. #2562
    Xyphriel
    P Plate
    Sep 2009
    Location
    East
    65
    1 (100%)
    If anybody's cb400 tank cap / fuel cap is jammed and need a quick solution / replacement, can contact me at 91901007. Got a few spare tank caps (local) to let go. Brand new.
