Hi guys,
i think my coolant container have a crack, cos everytime i pour water inside, after 1 hour the whole container become empty -.-
may i know how does a coolant and air filter play a part in the bike? riding SP btw.. how much and where to replace the container?
5 June 08 -> Pass 2B
8 June 08 -> NSR150 SP FU***S
  • Replies 11
Hi guys,
go scarp yard and get one very cheap. dont waste money to get a new one from motor diam as they eat ur money.
Class2B>TP on 22 May -Passed
Class 4>? start by 2009
Hi guys,
Why don't you take it out and pour water in it to check whether it leak. It may be due to overheating. Just my 0.001 cent advice
Hello, are you there......
Guest stages
good in drinking water... might be good sometime.....
Hi guys,
i think my coolant container have a crack, cos everytime i pour water inside, after 1 hour the whole container become empty -.- Check that its indeed cracked. If yes, buy suitable sealer to patch it up.
Coolant: used to conduct away heat from the cylinders and cooled down via the radiators. Do not run without it or your engine WILL SEIZE from overheating.
Air filter: to filter out particulate dust that might cause wear and tear if its sucked into the combustion chamber. Clean or replace it as per your owner's manual for optimum performance.
Thanks guys
any method to clean or check the air filter? i'm still very new to this.
hmm how do you take out the coolant container?
haha.. where's scarp yard?
Actually u will need to really check, everytime water disappear may not be due to crack in radiator...you can also try to see if the hoses are in gd condition cos over the years the hoses may had dried up till there is a cracked and tis will cause the water to sip out. It will sip out during riding as water pressure is high at tis moment.
_________________________________
Past rides:-
Cagiva Mito, Hexagon 150, KTM 125EXC,
Shadow 400, Ducati Monster 400, CBR 400RL,
Yamaha R1, Honda Goldwing1500
Present ride:-
Honda Deauville NT700
:gun: :bouncefire:
hmm already pour in water alot of times b4, i even left my bike overnight untouch and next morning the water inside coolant no more alr.. sigh.
u top up the container and nv ride it.. but the coolant level will drop after some times??
most prob the container or the tube link the container and the radiator is leaking..
yep.. what's the solution to it? =/
u can get a 2nd hand ones from scrap yard like the rest hav say..
but beware of the quality as the container may left for too long and crack too..
if u noe how to replace it, u can go to parts shop like FJT, chong aik or eversuccess to get the container..
as for the tube, u can go to any hardware shop and ask for the rite diameter of hi temp hose.. is black in colour usually..
thank for the advice =)
hmm anyone know where's scrap yard? FJT sell honda bike part but they dun fix it for you rite?
