HI,
I faced this problem of neutral light not lit when on switch. When I throttle then the light appear. I faced this problem b4 and have changed both battery and rectifier. After i change battery still got problem. then I change rect. Bingo. Problem was solved back then.
Now I face this problem again. But dun wish to change both. Izzit possible to
trace wether the problem is due to weak batt or the rectifier spoilt?
Still can ride. Just no horn.
Please advise. Thanks.
  • Replies 12
HI,
use a multimeter to check..
if the rect is ok, while the engine is running, the value is abt 13v.. higher rpm will give higher reading..
if batt spoil, the reading will be lower than 12v when u switch on the ign, engine not running..
Engine running meaning throttling?
If batt spoil, the reading less than 12V when switch on, less than 12V mean around where? 11+V?
Btw, u haven being call up for ICT yet?
maybe yr fuse blow .
D437S Gi-pro Dynamx volt RCS 19 Gianelli W custom SK silencer BMC air filt H&BJr 40L Scottoiler Bridgesport L valve HID Ventura headl PR3 Custom made radiator guard 3M Carbon IU Ohlins YA-041 BMW grips Motovation front fork & rear axle slider Barend slider Titax adjustable clutch Crampbuster Ram Mount W Aquabox USB charger Custom made Sargent Inspired seats@eugene saddlery
check on your neutral sensor..sometimes false neutral can result in the above symptoms..
I got about 12.85V when my engine running.
I got around 11.40V to 11.65V when I switch on ign, engine not running.
So meaning my rect is ok, but my batt is weak. Btw last changed is 1 year plus ago.
ya..
the batt seem like cannot hold charges le..
most prob yr batt is goner..
engine running mean idling rpm..
when u throttle abit more like from 1k to 2.5k rpm,
the reading should increase.. but the max charging is at 15v. anything more than that can consider over charging..
i got a letter say i transfer to HQ. no need ict at the moment..
:p
try changing ur magnetic coil and c.d.i...cheers!
cdi spoil will cause irregular timing of spark fire or even no firing..
in this cause, is not cdi fault at all..
as for magnetic coil, i dun think is a problem since he mention the value is at the charging range..
is ok to share advise but not anyhow trial and error..
I have my bike re wire. Now ok liao. Was told that it was my wiring problem.
Now is ok oreadi. Thanks alot for all ur advises.
you are welcome:cheeky:
:goodluck:
Class 2b passed
Class 2a passed
Class 3 currently learning
  • 4 years later...
Hi Guys, I have two used Vulcan 1500A rectifier /regulator to let go at RM250-00 each excluding shipping. My vulcan had problem starting up even after a long ride and initially I thought was a faulty battery. After doing some reading on the forum, I realised that the fault lies in the rectifier/regulator as the battery was not being charged even when I was riding ...that drains the battery and caused the difficulty in starting up after even stopping for fuel.
The rectifier/regulator may fit other Vulcan models like VN750 as well but you need to check first.
PM me if you are interested.
Ride safe.............
