I have installed this voltmeter thus everything ok except when bike move to 2nd gear the voltmeter reading is gone but whenever the clutch is depressed the reading is back again(just a flash cos gear changing)...Once I slow down to lower gear or stop the reading is back...
Start reading - 12.3v-12.7v
Idling reading - 13.2v-13.5v
Moving reading - 13.9v-14.6v
Background during installation:
set comes with 3 wires;
Black - to the batt -ve pt
Blue - to the batt +ve pt
Red - to the ignition fuse so that only bike started than this will power up...
I am riding a FZ16, there is only a fuse for all like lighting & ignition as such I just tuck in the wire into the ignition connector than close back the cover...
Any bros can advise on this technical issue...
Very much appreciated...
Thank you
  • Replies 0
