My front brake pump seems to be leaking, brake fluid leaking and brake feels sponge ..
Wats needs replacement ? is it the o-rings or seals or need to change brake pump ?? Cost $$ how much
KAWASAKI KIPS F* XX *
KAWASAKI ZX-10R FY3946Z (26 Oct 07 - 23 Jan 10)
YAMAHA RD350LC FS4160Z
1996 Honda Civic SiR EK4
1993 Honda Civic Vti EG6 SBZ2065P 1993 Honda Civic Vti EG9 SBX9073E 2002 MB E200 SDT6931X
1991 MB 200E SBT2703M
1986 MB 280SE EZ8138M 1992 Toyota Cressida SBU1756L
1992 MB 280SE SBU6143Y
http://w1.bikepics.com/pics/2006/05/16/bikepics-589321-full.jpg
  • Replies 1
Try to find out where is it leaking from, if its leaking from the master cylinder, open it, put the rubber seal properly in place, put back the reservoir cap and tighten. If its not leaking anymore den try rebleed the front brakes, cos brake feel spongy maybe bcos brake hose inside got air go in due to brake fluid leaking. Otherwise, check ur brake hose see if it has expanded, may need to replace (steel braided hose is good). If still doesn't work, get ur brake calipers checked, serviced.
