MOTUL PERFORMANCE MOTOR OILS
Motul 300V Factoryline 10W40 & 15W50
http://www.motul.com.sg/product_line_up/4stroke/images/product_images/300V_4T_FACTORYLINE_10W40.jpghttp://www.motul.com.sg/product_line_up/4stroke/images/product_images/300V_4T_FACTORYLINE_15W50.jpg
"Double Ester Technology for Motorcycle Engine".
This technology made possible to spur on an optimum output by reducing the friction of the oil film while maintaining stable oil pressure.
On the other hand, the slippage of the clutch system is minimized by the increased friction between the clutch plates, this then enables the power output to be increased at the rear tire.
Improved power output and more reliability at the same time.
10W40 is for race engines qualifying engines running at high temperature over a wide rpm range. SuperSport, SuperBike, endurance, MX etc.
15W50 is for race engines running at very high temperature & rpm, speed/endurance/motocross, optimum performance during the race.
Motul 5100 10w40 & 15w50
http://www.motul.com.sg/product_line_up/4stroke/images/product_images/5100_4T_15W50_1L_A.jpghttp://www.motul.com.sg/product_line_up/4stroke/images/product_images/5100_4T_10W40_1L.jpg
Suitable for European vehicles where 15W-50 viscosity index is indicated. Containing ester, 5100 ESTER 15W-50 is suitable for engines that require simultaneous lubrication with its transmission applications.
5100 ESTER 15W-50 guarantees efficient wet clutch performance as well as gearbox longevity.
Specially developed for engines that require simultaneous lubrication with its transmission applications, 5100 ESTER 10W-40 maintains stability and ensures less friction even at extreme temperatures or under heavy loads.
With its extreme pressure additives, gear shifts are enhanced. 5100 ESTER 10W-40 guarantees efficient wet clutch performance as well as gearbox longevity.
Motul 3100 GOLD 4T
http://www.motul.com.sg/product_line_up/4stroke/images/product_images/3100_4T_GOLD_15W50_1L.jpg
Oil for 4 stroke motorcycle engine
Technosynthese
Excellent anti-oxidation preventing premature oil thickening and ageing due to high temperature stress.
High lubricating properties which decrease friction and wear and increase engine life.
Motul Dot 5.1 Brake Fluid
http://www.motul.com.sg/product_line_up/fork_brake_others/images/product_images/DOT_51_BRAKE_FLUID_500ML.jpg
Non-silicone based, long life and 100% synthetic, DOT 5.1 BRAKE FLUID conforms to the highest standards in brake fluid performance.
DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS).
With a high dry boiling point of 270°C and a high wet boiling point of 185°C, DOT 5.1 delivers the best brake performance
Motul Fork Oil Expert
http://www.motul.com.sg/product_line_up/fork_brake_others/images/product_images/FORKOIL_EXPERT_20W.jpg
Fork Oil Expert is Technosynthese (semi-synthetic), hydraulic fluids for any type of telescopic Forks. Four viscosities: Light, Medium, Medium-Heavy, Heavy.
Contains an ANTI-FRICTION additive specially developed by MOTUL, making easier sliding, avoiding drag in the fork.
Stable absorbing in an extended range of temperature, thanks to the base stocks.
Protection of seals : excellent oil / elastomer compatibility.
Anti wear, anti corrosion, anti foaming.
MOTUL Fork Oil Expert can be mixed to obtain the required absorbing.
Use the exact quantity recommended by the fork manufacturer.
Links to Unique Motorsports's Servicing Packages
Servicing Packages for Class 2B Bikes
Servicing Packages for Honda CB400 Super 4/Vtec/Revo
Servicing Packages for Suzuki GSR400/600
Servicing Packages for Class 2A/2 Bikes
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 52
Kelvin, How much is 1 btl of Motul 300V Factoryline 10W40 & 15W50 and Honda oil filter..?? I'm riding a CBR 1000 RR...
"去哪兒???" ("Go where???")
http://i242.photobucket.com/albums/ff190/aceboles/Girls%20and%20Bikes/pic31.jpg
Straight roads differentiate the rich and the poor
Corners differentiate the boys and the men
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  dnt said:
Want to ask how much is 3 bottles 300V plus yamaha oil filter package?
Prices for Maxima Extra/Ultra too.
Thanks!
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  devourbyvermin said:
boss my time for servicing is coming up can u quote me price for gsxr1000 k8 changing of mtul 300v 15w-50(3 bottle) spark plug (ngk or denso)4 peice and suzuki oil filter.. or juz the motul 300v and oil filter
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Best Regards
Kelvin 87178999
WL: Zul 84818999
Which Motul EO is recommended for RXZ? Thanks.
Class 3
26.04.2007
Class 2B
26.07.2007
Yamaha RXZ135 (FD****X)
12.02.2008 - *******
http://i265.photobucket.com/albums/ii207/hotbladerz/231020083385.jpg
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  emarkie_82 said:
Hello sir...may i know what is recommended motul oil for X1R?
thanks ar..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  rustykarma said:
Hi, can u recommend me which motul EO is most suited for my KR? Planning to get it change soon. And i'll like to know the price too. Thanks.
You have a PM.
  moto_fly said:
kelvin...got 5w40 300V??? tomoro going down to collect coolant n make payment for hel thinking of getting EO as well...
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
The following range of Motul Performance Motor Oils are now available at Unique Motorsports!
This technology made possible to spur on an optimum output by reducing the friction of the oil film while maintaining stable oil pressure. On the other hand, the slippage of the clutch system is minimized by the increased friction between the clutch plates, this then enables the power output to be increased at the rear tire. Improved power output and more reliability at the same time.
Motul 5100 15W50 & 10W40
Suitable for European vehicles where 15W-50 viscosity index is indicated. Containing ester, 5100 ESTER 15W-50 is suitable for engines that require simultaneous lubrication with its transmission applications. 5100 ESTER 15W-50 guarantees efficient wet clutch performance as well as gearbox longevity.
Specially developed for engines that require simultaneous lubrication with its transmission applications, 5100 ESTER 10W-40 maintains stability and ensures less friction even at extreme temperatures or under heavy loads. With its extreme pressure additives, gear shifts are enhanced. 5100 ESTER 10W-40 guarantees efficient wet clutch performance as well as gearbox longevity.
Non-silicone based, long life and 100% synthetic, DOT 5.1 BRAKE FLUID conforms to the highest standards in brake fluid performance. DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS). With a high dry boiling point of 270°C and a high wet boiling point of 185°C, DOT 5.1 delivers the best brake performance
MOTUL PERFORMANCE MOTOR OILS ARE NOW AVAILABLE AT UNIQUE MOTORSPORTS!
Unique Motorsports (Eunos)
Blk 1039 Eunos Ave 3
#01-104 Singapore 409846
Tel: 68446378 Fax: 68446379
Unique Motorsports (Defu)
Blk 6 Defu Lane 10
#01-554 Singapore 539187
Tel: 62834878 Fax: 62832750
hi sir, what is the price for each bottle (300v 10w-4- and 15w-50)?
thanks
thanks
Motul 300V is retailing at $30 each.
Do check out our servicing packages for value bundles.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  ivanmania_10 said:
Hi,
Able to pm me the package price with 4 X normal spark plug for Fz1s ?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  mfaisaln said:
how much is the Motul 300V Factoryline 10W40 cost?i need 4 bottle.
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  ah_vic81* said:
i need do change E.O, Oil filter and spark plug. cant seem to find the $128 package... for FZ1s gen2
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
how much is the Motul 300V Factoryline 10W40 for rvf ??
Don't Challenge the Leader. It won't change the Loser.
2003-2005 = SUBARU WRX-STI (SOLD)
2006-2007 = NSR 150 SP PRO-ARM * FS 5427Z (SOLD)
2007-2009 = My Most Beloved RVF NC35 FN 7792G (SOLD)
2009-???? = YZF R1
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
