hi guys .. riding Nsr150sp here .. my bike's left hand side engine tends to leak EO .. to be exact, its at the bottom of my left hand side engine .. any1 knows wat r the possible reasons to cause tat ???
  • Replies 16
quite common for the Drain Plug was leak:)
http://img.photobucket.com/albums/v205/fx110/motor/Open/label/TO1.jpg
http://img.photobucket.com/albums/v205/fx110/motor/Open/label/TO2.jpg
hope u wont kena like mine, the crank case leak(coz of gasket, require to overhual):cry: :cry: :cry:
For NSR, which running less EO
http://img.photobucket.com/albums/v205/fx110/spareparts/20080416001.jpg
http://img.photobucket.com/albums/v205/fx110/spareparts/20080416.jpg
i was exprience want i was touring:cry: :cry: :cry:
if over top up? cause what damage if never put exact 0.7l. maybe like 0.8l and never bother make it 0.7?
http://images3.wikia.nocookie.net/__cb20111128075727/xanthe/nl/images/1/1f/Asian-Troll-Face.jpg
http://i140.photobucket.com/albums/r3/iewgnail/LW2.jpg
ma0ma0z maybe it's also like what he said? crankcase gasket worn. thus leaking?
Overtop up will feel like the bike less pickup,
for this case, is recomanded put 1L:)
went down to bikeshop few days back .. mech says tat its not leaking frm the center of the engine, so shudnt be gasket .. at first he said tat the screw of the engine cover was quite loose .. he tighten it back .. however, frm wat i observe tis few days, it stil leaks .. not alot .. but juz a few drops ..
one more place is the gear shaft oil seal:)
i thought SP is 0.7L only? how come recommended 1L?
i tink i go dwn again tis few days to let him chk .. thnx alot anyway .. hope it isnt any serious problem .. btw .. heard frm my fren tat, maybe is my block got hole, tats y it leaks EO .. issit possible ???
for bike w/o leaking oil, 0.7L was standard volume
for bike leaking oil,
fill-up 1L just make sure the Transmission Oil the enough
too much EO would cause more pressure on crankcase gaskets and seals(leaks and whatnot), the result of EO expansion when hot.
might be happen on 4 stroke bike, just my little thinking.:cheeky:
happened to me before,it leaks bit by bit like drops by drops and sticks to ur fairings right?
drop ur bike at Planet Motor and tell ah chong about it,im sure its the Gasket Seal which i got it changed for $25 at planet.
upzzzzzzzzz for planet
The pain of discipline is nothing like the pain of disappointment
yeap .. tats wat happen .. thnx alot !!! hahah
was the above the solution to your persistent problem?
Class 2B: 11 May 2001 | Class 2A: 06 Oct 2009 | Class 2: 21 Dec 2010
Class 3 : 26 Sep 2003 | Forklift Licence: 06 Dec 2005
2001-2001 : Honda NSR SP 150
2002-2002 : Honda XR 200
2005-2005 : Honda Wave 125S
2006-2006 : Honda TA200
2008-2010 : Gilera VXR 200
2011-2014 : Honda Cbr 600
2014-Current: Yamaha FZ1S
2010-Current: Kia Picanto OPC
