hi guys i need you help..my r6 2000 model keeps dying at gear 1 when clutch in but at neutral ok can start and idle..i checked the clutch cable its okay..i was wondering whether the cause is lack of engine oil? i open the e/o cap and looks like used up?..could that be the problem?..previous owner said change 3 months back but looks like more longer than that after opening it..hope to hear from you guys need your help badly!..thanks bros...
  • Replies 13
does ur bike have a side stand sensor?
meaning if u kick to gear one but have not released ur side stand, the bike dies as a precatutionary measure...
Previous Rides:
:2004: HONDA NSR SP 150
:2005: HONDA NC 35 RVF
:2006: YAMAHA YZF R1
:2008: YAMAHA X1 R
:2009: Honda S4 VTEC III
:2012: Honda NC 700X
better to push into a reputable bikeshop n let them check the prob.. =)
n also let them advise u..
Suck it n ride!
http://i305.photobucket.com/albums/nn224/ervinchua_wl/633520157058579273-SignatureCelebra.jpg
side-stand sensor? idle timing too low?? try opening throttle slightly and ut to gear 1...if never die then ur timing might be out....
1993-Yamaha LC, TZR
1994-Licence Revoke
1995- Honda MBX, RXZ
1996- Vespa
1997- RXK, TZM
2002- Phantom 200
2008- Toyota Axio(Car)
2009- Toyota Axio(Car) & S4 Vtec 2
2010(current)- Fazer FZ1N & Toyota Axio(Car)
when in Neutral gear, idling is ok ...
Previous Rides:
:2008: YAMAHA X1 R
what bike?
r6 2000
Previous Rides:
:2008: YAMAHA X1 R
Diagnose the kill switch first. As what piggy said, use WD40 to clear the grease and road grime from the switch. After that, do a step-by-step diagnostic such as kicking the gear up to Gear 2 from Neutral and check whether the same thing happens.
Get back here with the results.
For the certainty of death and the knowledge of life's fragility, makes it worth living.
if kick up already then clean the safety switch with wd40 located at your side stand there. usually this problem is cos of that side stand safety switch.
it could be due to ur side stand sensor .... If really got problem, ur bike will not be even able to start up or even if start up, u will hear weird sound or it wont be a smooth start up.... so have ur side stand sensor checked :) .
Motivation is what gets you started. Habit is what keeps you going.
I am Disciplined, BUT sometimes I have Wild sides
