my cbr will give out hissing sound whenever after use...on the fan a while thn the hissing sound stops, flush and top up coolant but still the same.my friend say its the pipe that burst 3 pipe 1 burst....haiss...any kind soul here that can help mi rectify the fault and tell mi what sort of repair i should seek and where..really appreciate it man..thanks and happy new year
  • Replies 6
there is snake inside ur bike? :lol:
ok, to start with, u r riding which model of cbr? cbr125? cbr150? cbr400? cbr600? cbr1000?
also, hissing sound came out from where? radiator? headers? engine block?
other than hissing sound, is there anything visible like smoke or water leaking?
and also, did the coolant in your radiator or spare reservoir tank(under ur seat) becomes lesser in volume?
Inherited Will.
The Age of the Destiny and The Dreams of the People,
These are the things that will not be stopped.
As long as people continue to pursue the meaning of freedom,
These things will never cease to be!
How old is the bike?
The liquid cooling system on the bike works on a pressurised system. When the coolant gets heated up, it expands and builds up pressure in the hoses and the radiator. When pressure is increased, the boiling point is raised..this prevents the coolant from boiling so that it can transfer heat away from the engine to the radiator.
There is a leak somewhere, that is the hissing sound you are hearing... its allowing the pressurised coolant or air space to leak out... you need to trace it down. It can be from a loose hose clamp, a punctured radiator hose or punctured radiator core.
When you turned on the fan, the coolant is cooled down and will contract and the pressure within the cooling system is reduced thats why the hissing stops.
You can change the coolant 1000 times... you have still not solved the leak.
Hoses are not that expensive but the radiator is going to cost a quite a bit... depending on what kind of bike you are riding... you said CBR... CBR150 or CBR1000???
i really hope is not the radiator core....pray hard that its the hose or sumting...thanks guys..any ideal place for my bike to be repair at a reasonable and affordable workshop?
i have the same problem today. haha. haven go and solve it.
But asked a bike shop. it mention that either the radiator cap loose / tank cap / oil pump.
i not sure is which but he asked me to try to see.
Hope you can solve ur problem soon!
:angel::sian:
