ELECTROMEM HF150 Electronic Battery Charger (Retail Price: $170.00)
http://i562.photobucket.com/albums/ss69/uniquemotor2/HF150.jpg
They are ideal for all types of Wet cell lead batteries, with liquid electrolyte, or Dry cell lead batteries, with immobilized electrolyte (for example, sealed batteries type Gel, Agm and Mf).
All the charging parameters are set using charge function keys on the control panel.
- Mains Voltage 50/60Hz 1 ph Volt : 230
- Power Watt : 20
- Output Voltage Volt : 6/12
- Charge Current Amp : 1
- Battery Selection Type : Gel, Dry, Wet
- Nominal Capacity to refer to Ah min-max : 2,3-30
- Size : 150x65x36mm
- Weight : 0,4KG
The battery chargers are also equipped with led and acoustic indicators, which trigger alarms if the polarity is reversed, if the battery is faulty and if the voltage is wrong.
They are made of insulating material and can be wall-mounted.
They have a high level of protection against external agents and are safeguarded against overheating and short-circuits.
They are equipped with clamps, plus a complete set of charging accessories.
The control and fulfilment of the charge cycle is managed by a microprocessor. Each charge cycle is implemented in four phases: one diagnosis phase and three charge phases
Price: $170.00
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 0
