A week back, I accidentally let the 2T oil reservoir get low. The low oil indicator light for my bike isn't working.
I only noticed it when the rpm gets so low that it stalls when the bike is idling.
So after I topped up the 2T and revving it abit, the bike went back to normal, or so I thought.
2 days later, the same problem occurs. And when I checked the reservoir, it was really low, which was weird considering that it was just 2 days ago.
Thought it was because of the 1st time, so I let it be.
Then again, it happened. Can anyone tell me if its a leak in the reservoir or some engine problem that i caused the 1st time I let it run low?
Thanks.
  • Replies 3
Sounds like a leak. Do you see any oil stains below your bike every time you park your bike overnight?
Class 3 02/06/2011
Class 2B 13/06/2012
NSR150SP FBD2**G June 2012 - October 2012
Phantom TA200 FW6**6A October 2012 -
Thanks.
check your spark plug...see whether it is foul up...
if it is,,indicating excessive 2t in fuel mix..your 2t pump adjustment may be screwed up
i think pump or container leaking .. cannot be 2 days no more, if u top up whole bottle,
unles u tell me in 2 days u travel 800km
