nid help. my engine make diz hissing sound wen i rev or on the move.
a bit sound lyke got sand inside the rotary.
performance wise no difference, will it lead to future problems.??
btw i riding a rxz.
  • Replies 8
hissing sound is a good sound... means that all the stuff inside are well lubricated, your piston, block n valves are good
if you hear ticking or knocking sound, then that's bad
:giddy: :giddy: really lidat one meh ? Lol
i got knocking sound when on higher rpm, whats wrong then?
are you using open pod filter or the "trumpet" ?
They produce hissing sound when you throttle as it takes in more air then using the airbox, hope this helps!
ur con rod shaking...
go check wit mech, limit2 need to overhaul.:bouncefire:
gay gay gay gay!!!!
http://photos.friendster.com/photos/46/20/40990264/1_767627069l.jpg
