i'm having difficulities starting my bike when my engine is cold.need damn alot of kick start to wake up my bike.when i'm frustrated i juz pulled my choke but its juz not normal for a bike to be like tiz.i sent my bike for servicing last month,told the mechanic bout my bike prob.he said need to open up engine n check.ended up doing overhaul changing piston,timing chain etc..spend quite sum of $ n the mech said my bike should hv no prob now.heres the bad news,jz ride it for a month n the prob comes again..:cry: does any have tiz prob before?or anyone here maybe knows wat is the root cause of my bike prob?Need some advise before sending back to bike shop.ur reply will be greatly appreciated.thanks:clap:
  • Replies 10
I tot pulling the choke to start in the morning is normal............ i have been doing this for 5 years - there is no starting problem until once when the battery is kaput. Haahaaa sometimes i forgot to push the choke back while riding off - then the bike died, but it will start up again easily.
HP: 93891138 :angel:
I'm experiencing the same problems these few days. These rainy weathers make the engine turn cold fast...
Try increasing your bike idling speed a little bit :)
Computer generated. No Signature required.
i had the same problem 1 half yr ago when i bought my x1, every single morning, kick start until leg wobbly. but i've never open choke before. and well, after some time, the problem went away already.
the only maintenance i do is eo monthly & spark plug every 3 mth. have yet to service carb because when my mech says not required for now.
so maybe, just give it more time, it'll probably go away?
hey ho, let's go.
before i did full service for my bike last month,i'm having tiz prob for quite sometime.after a month tiz prob came back.funny thing is jz after service when the carb is clean,its easy to start my bike.it last only a month..is my carb prob??
The choke is there for a reason.. it helps the bike to start in cold weather.. using the choke to start ure bike dosent do it any harm.. else why would they put it there?
a choke valve is a valve that modifies the air pressure in the intake manifold of an internal combustion engine, and thereby modifies the ratio of fuel and air quantity entering the engine. Choke valves are generally used in engines with carburetors, to supply a richer fuel mixture during engine start than at other times. Most choke valves in engines are actually butterfly valves that are mounted in the manifold above the carburetor jet, to produce a higher partial vacuum and thereby draw more fuel into the intake stream.
My Rides
Dec 2006 -Aug 2008 : kawasaki krr150
Aug 2008: Honda CB400 Super 4 Spec 1
27-29 JUNE 2009 - Hatyai (Thailand)
14-17 NOV 2009 - KL/Fraser Hill/Malacca
