  • Replies 9
may i know why my sp when reach 5 RPM the bike is not smooth like sound and the moving?
All SP hv this problem..Do a search..i facing this problem since i got it..after number of motor shop...still cnt able to fix it after i went jb..i saw my mech do proper tunning n setting of curb and the problem is solved..yes there still is little but confirm its 90% better den wat shop here done on my shop :)
http://img.photobucket.com/albums/v519/evilspawnsss/Signature-1.jpg
Class 2B Honda SP (SOLD)
Class 2A (24/08/2010)S4 spec 1(Friend riding)
Class 3(10/2009)Suzuki Swift
ok thank you bro
No problem..go look around which shop to go to for tunning and setting if u not into malaysia jb.. cnt tell u much abt sg de if not wait i tio shoot.. good luck
most of carb bike have a "flat" spot at certain rpm..
the onli way is to tune the carb well to reduce the effect..
u may want to check yr RC valve cable too..
u can try to tune your carb will still have alittle feel of that cause at 5k RPM the valve is opening therefore u need to throttle pass the 5kRpm if u really wanna nice change will be at 5.5k Rpm
the 5-6k RPM range for SP is called the bogging zone... like when the valve about to open that time.... all sp will have this problem....
Cheap + fast = no good
Cheap + good = not fast
Good + fast = not cheap
>>>(wise words from ahduck)<<<
2 stroke bikes are designed to be revved high (think beyond 7k rpm)..
