hey fellow spark riders !
i wanna find out the best chain and sprocket for spark ..
best means, can last long, the chain also never get loose easily, takes quite some time for it to wear and tear .. in addition, price must also be good lah . heheh , cheap cheap good good .
at the moment, i am using 415. evrytime change mus pay $65 for 1 set,chain + sprockets.. chain everytime get loose easily and i oso get worried unnecessarily.
hope you guys can enlighten me with some useful information and knowledge ..
thanks lots . ride safe play safe stay safe ! =))
  • Replies 36
hmm.... Chain gets loose easily because of the way you maintain it and your riding style....
if you everytime move off you whack sure loose fast wan... Weekly regime off oiling your chain does help also... So far i use 428 chain heavy duty enough already... 415 too thin... If you always pillion, 415 is not the way to go...
Price wise... lets see... i got my sprockets for $12... chain 428 DID Heavy Duty $23.... you do the math aite....
Shoya, on the track and beyond,
we will always follow your lines.
http://www.motovation-accessory.com.sg/images/article/20/sp_tadao.gif
quite true actually uh. like to whack whenever i send order . hmmm .. 415 they say for pick up . but come to think about it, long lasting chain is much better, can save some more .. thats a gd price u got uh compared to my $65 package. hah. anw, for sprockets, i believe there is also the size, i mean my rear i using the sprocket gt 39teeth one .. actually im not too sure about sprockets actualli ...
thanks for sharing too .. realli appreciate it . =DD
No problem bro... So its correct that you like to whack huh...hehehe
Ok this is the basic fundamentals of sprockets... The bigger the rear size, the more power you will feel.... aka like more pick up... The more smaller it is, you will feel less pick up... but the speed will go higher....
So its your choice to get the exact size for the pick up and speed you will get... Diff mods need diff size... so end of the day... its up to you on what size to get... 39 rear is stock size if i am not mistaken... hmmmm
hehehe . most of the time i whack oso, when im werking, i mean, u can see for urself, how mcd riders, pizza hut riders ride, they like dont care llike that ...
anw, back to the topic discussed, i take it that 428 is the preferable choice for longer lastin chain. now, whats nex, is to survey the best reliable price .=) once again thanks lotzZz = DD
bros, what's the difference between heavy duty chain, O ring chain and X ring chain? Haha. wanted to change my chain then the mechanic asked me what chain of the 3 i need. Help much appreciated. :)
**Wherever there's a need, there's always the highway!**
heavy duty is just normal chain but with better lifespan if well maintained.... o ring chain, if i am not wrong is... within every link,there is an o ring in it which holds the lubricant within it... x ring i dunno... maybe got 2 o ring??? hehehe....
kupchai use heavy duty can liao... o ring for me is too ex and a bit heavy... my 2 cents of coz...
hey bro, good thing that you brought it up, i oso face the same situation as you and i was puzzled. i just tell the mechanic, as long as cheap can liao .. heh
actually most of my frens oso using heavy duty ... you mentioned well maintained, what do u mean by that?, my 415 oso i lube it evry 2 weeks, and after rain.but maybe its becos of the way i ride lor that made my chain evrytime loose ... =))
Maybe x ring got 'x' ring in every link. hahaha! anyways, thanks for the info. your 2 cents worth 2 dollars for me. ^^
Kewl.... what does an x ring look like??? hehehe.... wow 2 buckaroos...
Ride safe guys...
X ring chain have an X ing in the link. Its supposedly is better than o ring as it is more durable than a regular o ring seal. But it still does the same job. If you are not sure of the sprocket combination its better to leave it as stock. And sometimes you chain loosened is not because the chain gets stretched. Sometimes the mechanic that tightened the rear axle of your chain is just too weak. :lol:
KRGT-1
Ride safe guys...
from what i see, x ring and o ring like very hard to differentiate. Don't know how to judge which is which. Haha! And i read that both x ring and o ring don't need to lubricate because it has already been lube in the inside. How cool is that. Can save money. :lol:
Where did you read that from? As with all metal components that rubs on another metal will always need to be lubricated. Your sprocket is in contact with the chain. Just like sex. Unless you like it raw. No lubrication needed. :lol:
KRGT-1
hmmmm, so, wat is the best sprocket combination ? i want the stock combination for sprockets and chain ? =))
stock should be 15-39 rite for spark?? Chain 428...
Stock already...
if u enjoy cruising 100km-120km anywhere,use front 15 rear 38 bro..ppl says makes ur engine stress free..shiokness..im currently using it..
Glad you like that sprocket set up.
oh i see, maybe i shud try . the word shiokness make me feel like tryin it. furthermore, no harm tryin rite? .. thanks to all for sharing ... =DD
oh... so those $50 did chain set is heavy duty chain ah? not even o ring? gua sudah kena con..
who gets summoned for not signalling? i did..
dumb luck? maybe...
nak nene mandi air bunga...
wah you buy so ex ah... next time you wanna get tell me..*i sell you 40... whahaha
i also last time kena before.... until i found a better offer... hehehe...
You got check your links to see whether your o ring hiding or not??? hehehehe
  jjames said:
Where u get chain and sprockets so cheap bro?
Sprockets Malaysia, Chain Japan... whahahaha
but seriously how to physically check oring or normal chain? at least can get the right type of lubricant..
dumb luck? maybe...
