  • Replies 2
Get a new tank. And make sure you fill up your tank FULL every time so often to prevent rust as moisture gets into the tank in this humid envirnoment.
All the methods so offered will be costly and not complete. Short of cutting up your tank , clean it inside out, treat the surface and re-weld it which probably will cost you more.
But if you stick on and use a rusted tank, you be in for more nasty and costly surprise.
New tank = repaint. No acid bath? electrolysis?
