Hi guys... I need help here... I realise that a while after parking, oil starts to drip from the carb.. I know that it is somehow normal, but the rate it is dripping at is not... it is dripping at almost 1 drop per sec...
I just had my bike serviced yesterday, where the mech took out the carb and cleaned it... somehow the bike performance is good now, but then came the dripping problem. please advise me on the above.
  • Replies 10
i got this problem, urs is 2t bike right?
few days ago, mine dripping non-stop, within 1 min, the whole oil tank dripped dry and the 2t oil was all over the floor. worried that the piston might jam if i ride to mechanic, i called towing.
then mechanic says, my 2t was overflowing LOLS. because it's a old scooter, the cap is not tight, so what he does is using white tape to tape around the inner of the cap at the reserve tank to seal it tightly. now no more dripping.. not even a drop.
you can ask ur mechanic to check ur tank cap lor.. especially for old bikes.
i guess is dripping gas from the carb?
it could be from the float needle that is not sealing the orifice properly
use the back of a screw driver to lightly tap on the bottom of the carb and see if it helps, if not, pls go back to ya mechanic.
:cool:
prev i got this prob oso got my frene to do it for mi le.. my gasket cause oil to drip alot..
2002-2003 -->aprilia Rs125
2002-2005 -->honda Ta200
2003-2008 -->aprilia Rs250
2006-2008 -->honda ta150
15 jan2008 - 5 Apr 2012 --> x8 400ie
5 Apr 2012 - now --> busa the falcon..
its might be the black rubber in the carb.. cos the rubber is realli sensitive if the petrol touches the rubber it will expand than need bout 1day for it to totally contract into its original size...after it dries up...
so check the rubber..bring it back to ur mech i;m sure its gonna be FOC cos its his fault...
if he say must change whole carb i guess he's going to carrot u liao.. just tell him to change the rubber would not cost more than 10bucks..
just my 2 cents..
cheers
skazuz
Honda CRM 125-2004-2006
Yamaha X-1(Red)-2004-2009
Yamaha Y125Z-2006-2008
mine is a 4t bike... hahaha hmm... tank cap... will get my mech to check...
thanks for your advice!!
just my 2 cents..
cheers
skazuz
thanks skazuz ... will do that...
yup... its dripping from the overflow vault...
  • 3 months later...
Hiz,
How's your bike now?
My Dream Car, see who wants to cut my lane and tail-gate me......
http://i229.photobucket.com/albums/ee218/mika14cyanide14/MyDreamCar.jpg
Hiz,
wow.. almost 4 months u still ask. u r a caring bro :cheeky:
