Hi,
Anyone can advise what's the requirement/specifications of the tubing used in our petrol lines, oil (2T) or hydraulic (brake fluid container to brake pump)lines?
Are the clear type (PVC) of tubing found in commmon hardware shop safe to use?
If not, where to buy such rubber tubing? I need to cut my own length for some modifications.
Tks!
hansen
Email guay_hansen @hotmail.com
My blog at snowparang.blogdrive.com
http://www.pbase.com/snowparang/image/79866156/medium.jpg http://www.pbase.com/snowparang/image/95749015/original.jpg
  • Replies 9
Should use only those suitable for oil and petrol products. Can be brought from motor spare parts shops along Sim Meng road. They are usually black in color. Cut in length either in feet or metre.
You mean the industrial estates near LTA?
Is it the same material for hoses used for compressed air?
no. you have to get those rated safe for petrol usage.
War is Peace.
Freedom is Slavery.
Ignorance is Strength.
I see...I guess so too cos when I put petrol in those spray or use normal PVC tube to blled my brakes, the tubing deterioate quite fast.
problem is where to get them...
Bought some black carb hoses from the suzuki dealer across the bus stop near Regina. Confirm can tahan petrol, think it was $8 for 1~2m packet.
My Dream bike ~ ~ ~ ~ http://i17.photobucket.com/albums/b54/Spenx75/mospeada3.jpg
KS motor? Yet to check them out. Hope they have thicker ones cos mine is almost 1 cm in diameter.
