hi bros out there
i kinda got a question and dun mind if any of you can enlighten me.
Currently riding an SP .. and i m having some engine problems
and i found another SP to exchange engine with.
I called LTA today and they refered me to the engineering department but called me to call again tmr as the dept is not open.
wad am i suppose to do ? and is there an issue if i switch the engine in Msia ?
thanks in advance
http://i10.photobucket.com/albums/a137/l0st_boi/hks_s15_0011.jpg
http://i30.tinypic.com/28tzyac.jpg
  • Replies 4
hi bros out there
thanks in advance
The internals? Or the whole thing? Coz if I'm not wrong there is a serial number for the engine just as there is for the frame..:cheeky:
09/07/2009 - Passed 2B TP (10th attempt)
I have tried to see things from your point of view..But no matter how hard I try..Or what I do..I just can't get my head that far up my butt..
hi bros out there
thanks in advance
If you want to know the legality, yes, it is legal to re-engine.
Extracted from LTA :
LTA allows changing of engines provided that it is of the same type as the original one. Therefore, LTA would require the following to be submitted for evaluation:
New or reconditioned engines
a) Invoice or bill of sales from the supplier of the replacement engine.
b) Certification from vehicle manufacturer or the local sole agent stating that the replacement is of the same type as the original one.
Swapping of engines
a) Swapping of engines between two registered vehicles is allowed, provided that both engines are of the same type and engine capacity.
b) After the swap, one of the vehicles must be scrapped immediately while the other must be produced for inspection at LTA.
http://www.onemotoring.com.sg/publish/onemotoring/en/lta_information_guidelines/modification_guide/modification_allowed_lta.html#MainPar_0003
Swapping of engines
then any idea if exchange engine only ?
both bikes engine still workin leh ...
the scrap immediately wah lau .. tats terrible
lolz
lost what happen to ur engine?
no lar .. nothing.. its kinda juz helpping a friend to ask
