Been having a problem with my EO lately.
Seem to disappear & I have been topping up every week for the past month.
No leakage or anything since I've found out about this problem & been checking the level daily.
Mech can't figure out the problem & I can't just go on topping up EO on a weekly basis.
Anyone had experience this before?
Stress?!!
http://inlinethumb53.webshots.com/3764/2121541870101300495S425x425Q85.jpg
  • Replies 12
What is your bike, maybe you can provide more details.
Is there smoke from your exhaust?
Pulsar UG3 (Mar 07 -> 21 Jan 2009)
S4 Ver S. (Scrapped May 2010)
S4 Revo (05 Aug 2010 -> current)
what is the colour of ur smoke?
i believe its time for u to change ur gaskets or seal.
Facebook HONDA CB400 REVO
Am riding a TW200.
My mech has also asked me too if there's any white smoke but none whatsoever.
No leakage on engine or on the floor too.
Am riding a TW200.
There are only 2 possible reasons why oil disappears in 4 stroke engine, disregarding massive leakage...
1. Worn valve stem seals
2. Worn piston rings
Anyways, you need to do a top overhaul.
Stress?!!
Have you recently changed to another type of EO which is too "thin" for your bike?
Or in another words, is the EO the correct rating for your bike?
If everything is correct, then the mostly likely problem(s) will be what ulysses_sc has mentioned...
Steps to do a proper KNNBCCB with middle finger.
1. Bow down slightly, looking intensely at objective
2. Like a raging bull, hop and jog slowly towards objective
3. Take your left palm and slap it hard on the right mid-arm with a SLAP!
4. With charisma, raise right arm, whilst showing middle finger (with left palm trapped in bend right arm)
5. Shout! KNNBCCB
EO...do not burn...
they do not disaapear into no where..
only way for EO to get out of engine is..leakages==u will see it on the floor
or through the exhaust..
suggest u try to ram your engine at high rpm...i am not surprise u see all sort of smoke coming out....
I just did an overhaul about a month back.
Then this problem came up, never did before. o_O
EO...do not burn...
Did all those you mentioned, that's why am totally dumbfounded.
Nothing of the sort since I do check my engine & exhaust often especially when this thing occurred, the checks get more frequent.
Been using the same EO all this time
is your engine runs very hot??
presumed everythings r ok, there r not leakage n just overhauled engine.
carb r set very lean, engine will run extremely hot.
extreme heat will coz engine oil to vapourise.
solution: set carb richer.
check your spark plug colouration when tuning carb.
from lean to rich,
electrode end should have colour
from white (lean) > brown (ok) > grey (ok) > black (rich).
try changing to a thicker oil.. see if the problem still occurs..
are u very sure there is no smoke from ur exhaust? hrmphs.. it doesnt dissappear just like that..
http://i15.photobucket.com/albums/a387/gabriel06/Rxk2_edit.jpg
danger is no stranger to a lonely ranger
