Hello Friends!
I have a very fail SP.
to reach 110km/h, i need to rev to RPM 8.
wasn't like that awhile ago
my friends SP will have made 150 with RPM8.
I got a buncha speculations.
I'm thinking worn out clutch plate or busted valve.
Any way to check/confirm is the clutch plates worn?
Approx how much to change?
busted valve=top service?
Seperate issue, anyone know approx price to change rear wheel bearing?
You guys are the experts, kindly adivse.
Thank you friends.
"it's about time they killed Osama"
  • Replies 8
To check for worn clutch plates, start off your bike at a slow speed, say 15km/h. Kick up to 3rd or 4th gear, and open the throttle full. If the RPM revs up without the speed increasing, your plates are worn.
To check for worn valves, you'll need to do a compression test. Yes, if your valve is leaking, you'll need to overhaul the top-end. It could also be bad rings.
Either those stated above or maybe you are slipping your clutch while riding?? Is your clutch fully released when you whack up to 8k?
~~ WhEn AnGeL DeSerVeS tO diE ~~
~~ SearChinG FoR My LoSt SouL ~~
~~ To LiVe AnD LeT DiE ~~
~~ EveryOnE WaS BorN tO SerVe a PurPoSe ~~
06 Nov 2006 = Kawasaki KRR 150 //
03 Jun 2008 = Suzuki GSXR 400 //
12 Jan 2009 = Honda Wave 125 //
21 Aug 2010 = Honda Super 4 Spec 1 //
Or when you hit your top speed, does your tachymeter blip its rpm reading? Ie, from rpm 8k to 5k, back and forth.
Hopefully its just your clutch plates.
Bajaj Pulsar 180 - UG3 (2007 - )
Suzuki GSXR-400 (2008 - 2009)
Piaggio Vespa GT 200L (2009 - 2011)
Yamaha YBX 125 (2010 - )
Yamaha FZ S1 '05 (2011 - )
hey i advise u bring ur bike to shop to check for everything
bike shop that i recommend would be
BIKEWORKZ at kakit bukit shun li indus park
planet at ubi
just to share....i gt the same prob as u...after i my bike gt piston seizure...at tat time..the mechanic repairing says the bike still can go( make the 2t bigger)..coz i bz wif exams, after my exam, ask my mechanic to open up..hav to change piston n block..
:) cooling off day
i have the same problem as well
Gear 6 cant rev pass 4k and speed keeps on decreasing
even though i throttle more/full throttle the speed still decrease and rev stuck at 4k
only after maintaining for a long time in gear 6 den it can rev till 8k and can only maintain speed above 100
anything below 100 rpm and speed will drop alot
In gear 5 rev till 4k can travel faster den gear 6
is my gear 6 worn out?
Dun pm me as i cant seem to receive and sent pm
sounds like a slipping clutch.
