Anyone can suggest a good engine cleaner? What brand? How much?
The one you can spray on the block and then water rinse off?
Thanks.
Better And Better
  • Replies 7
get engine degreaser..
at mustafa
- Yamaha FZ150I
-Yamaha FZ150I
yep..tried it.. useful not only to degrease block.. chain also
- Yamaha FZ150I
-Yamaha FZ150I
can use engine degreaser to clean chain ar :confused:
care to share wat brand u use :confused:
..Trials and Tribulations are Tests to shape ones path in Life..
..nobody plan to fail but many failed to plan..
..make e right mOve & u're made for Life..
try not to use those strong degreaser on O/X/Z-ring chains..the chemical agent in the degreaser will cause the rings to decay..
rien d'autre que le max.
Originally posted by ZzGaNgStErzZ@April 28, 2007 03:32 pm
GT 85 ?
I've tried GT85 on the chain but have felt guilty when I went online and did some Google research on using degreasers.
I'm worried that a chain treated with GT85 would fling off any chain lube that I apply onto it...so it's back to the petrol and kerosene method of cleaning my chain.
That is...until I get reassurance that GT85 does its job as a mild degreaser and can be washed off (the can doesn't say so though)
By the way, what's the name of the engine degreaser ah?
Biker nerd • Windows • Apple Mac • Android user
"Kick up your sidestand bro, let's ride..."
