i want to know is there a special charger for a battery for bikes?
my battery is getting flat, sometimes on the road the engine dies itself.
the battery indicator is also on whenever i wanna start the bike, in the morning before i go out also on.
i read on the batt that it will charge itself, but i dont think its enough to charge by itself. i read that we can get charger at eg. mustafa to charge the batt, but i scared will overcharge it, becos once overcharge the batt will be useless already rite? and on the batt also got warning say 'never overcharge'.
so if i wanna charge, how would i know if its full so tat i wont overcharge it. and where can i get this charger?
thks and sorry for being lengthy. :)
  • Replies 45
If your engine dies halfway, it has nuthin to do with your battery.
Here's what a weak battery does :-
1. It doesn't allow your bike to crank
2. No lights. Zilch.
The battery supplies current to charge your starter motor to provide that initial crank, to start your bike.
Thereafter, it will just supplies electricity to your lights, horns etc.
It recharges itself when you're on the move.
If it dies, it only meant you're better off changing to a new battery as the old one is dying.
Also, a weak battery after few months of changing meant, your bike is not recharging the battery at an optimum level.
Last but not least, if you had reason to believe you wanna charge your bike separately, just charge it before you go to sleep and remove the trickle charger when you wake up to go to work.
Fer everyday...
is an adventure...
when you're astride...
a green monster..
tanks bro for the info.
anw, if the engine dies halfway, i had to turn the key to off and on it back cos when the engine dies, i electric start it, no cranking sound. wat may be the problem?
where u stay?Maybe i can help u.
1998- Yamaha RX-Z(FR****K)
2002-2003(Oct)- Honda Super 4 Vtec II(FV***C)
2006 to 2010(June)- Honda ST1100(FQ****M)
2006 - 2010(June)... Honda Super 4 Vtec II(FW****U)
just change a new battery...easy process..just make sure ITS BATTERY prob...not rectifier or coil issues..dats all
http://i4.photobucket.com/albums/y117/nebulaz/KTM-Pink-1.jpg
HUA Hua hua....WADEVER..AR you STOOPID OR WAD? HUA hua hua version 2.....
Your problem may not be the battery alone, sounds like your bike charging system (alternator/rectifier) not charging. Your best solution is to charge up yr current battery & see wat happen over the next few days, if flat again then it is your charging system. If u change to a new battery & yr charging system dun charge u r back to square 1.
HP: 93891138 :angel:
hmm. what if the charging system is the problem. how much would it cost?
If looking for a battery charger, buy one which is auto charge, meaning when batt is full, it will charge anymore.
http://img285.imageshack.us/img285/9274/saniboyburn0ui.gifhttp://img.photobucket.com/albums/v220/saniboy/Ride/style.jpg
hi got the same prob as u too..
but i think mine is due to the ignition problem....
halfway AT TIMES will just off ( no lights, engine off for like 2 to 4 secs and on again )...
D437S Gi-pro Dynamx volt RCS 19 Gianelli W custom SK silencer BMC air filt H&BJr 40L Scottoiler Bridgesport L valve HID Ventura headl PR3 Custom made radiator guard 3M Carbon IU Ohlins YA-041 BMW grips Motovation front fork & rear axle slider Barend slider Titax adjustable clutch Crampbuster Ram Mount W Aquabox USB charger Custom made Sargent Inspired seats@eugene saddlery
u riding wat bike? now mine ok can charge i think bcos of the rain the water got go in. but the engine will die sometime at traffic light?
but auto scooter have idling setting? could it be rpm too low? i need to throttle abit at traffic light tomaintain the engine to keep running.
comet 125.
but its not too much of a hindrance to me. as it only happened twice only..
An usual bike's battery is rated 12V. when bike is running, voltmeter shows 14V to 14.8V ---- means battery is charging, right?
My question is, can i charge my 12V battery if i have an adapter which outputs 17V (unsure of the current rating) when plugged into our household socket?
take note, the battery is sitting in my room, already taken out from bike
No more regrets.
using a output of 17v to charge a 12v can melt the cables or cause fire. An electrical overload is a situation where the wiring to or within a machine or system is subjected to a greater electric current load than it was designed to carry, leading to excessive heating of the wires and a possibility of fire. This excessive current load can be a result of electrical insulation failure ( a short circuit) or human error.
You need a lead acid automatic charger. Your 17V power supply will over charged the batt & will explode, very danger. :(
http://i96.photobucket.com/albums/l184/PKLeong/Bike/BukitBaring.jpg
bro. so if auto charger will stop charging once it detect the battery is full lar?
i heard mustafa got isit? how much anyway?? :)
good battery chargers are expensive.. cheap ones aint good.. and yes~! batteries may explode.. so if your not sure, please dont try it..
http://i15.photobucket.com/albums/a387/gabriel06/Rxk2_edit.jpg
danger is no stranger to a lonely ranger
Get electronic charger laaaaaaaa watch yahoo auction for 2nd hand ones ...... some ctek buyers of XS800 are thinking of upgrading .... :angel:
Sorry, out of curiosity, can a charger save a completely flat battery? How about an almost flat battery if you detect it in time with a voltmeter? I'm thinking of bringing one of these on tours as backup power alternative in the event of faulty rectifier/coil. Is this idea feasible?
P-plate should be an attitude to safety and riding. There's always more to learn.
10417710_10152885054228332_2597706433133321618_n.jpg?oh=a3e4c65165b15e5d659161c304211563&oe=54FB0965
Still can save flat battery but the ability to hold the charge for a long time will diminish. From there, have to recondition the battery so that the ability to hold charge will be restored.
Edited to add: I brought the XS3600 for my North Thailand trip. If I didn't bring it along, I can't charge the battery for my riding buddy at night in the guest house.
