Got carbonfibre,need help on how to mould it.what do i need.
  • Replies 15
u wana diy CF parts arh? cool man..... erm. i duno much but i tink u nid a mould of the part which u wana make.... apply the resin on it. then lay 1 layer of CF, then repeat step 1 again. duno got heat anot. anybody can help?
http://i25.photobucket.com/albums/c98/red_rider_1979/aaa-1.jpg
how to make mould.from what.
what kind of resin...where to get those.
duno got heat anot.
You can use either epoxy or resin. Apply heat will speed up the curing process. However DIY method will not get you strength and rigidity as those from factory.
Mould can be made from cardboard, plywood, wire-mesh. Fabrics are laid in the cross-ply manner for added strength. The more important part is to remove the air-bubbles which the factory will use the vacuum chamber to extract all air so to achieve 100% bonding between layers.
Carbon Fiber (CF) fabrics are very expensive, so to learn with CF is a very costly. For beginners, you should experiment with Fiber-glass, as the process is almost identical, and it's much cheaper to fool around with.
Some CF parts are fibre-glass based, with only CF at the top layer. So that's another method.
any links you send me too?thanks
what links do you want ?
web-link on the process.
i think ill be more difficult to get the epoxy here.
dont know where to start...sigh
On the process, just goggle it. It's not difficult, just very messy. Certain level of PPE is essential, and a zero-wind but well ventilation facility is necessary.
Where to get the stuff here, that's easy :
http://www.weeteetong.com/compa-right.html
thanks a zillion
omg is that a HD?
D437S Gi-pro Dynamx volt RCS 19 Gianelli W custom SK silencer BMC air filt H&BJr 40L Scottoiler Bridgesport L valve HID Ventura headl PR3 Custom made radiator guard 3M Carbon IU Ohlins YA-041 BMW grips Motovation front fork & rear axle slider Barend slider Titax adjustable clutch Crampbuster Ram Mount W Aquabox USB charger Custom made Sargent Inspired seats@eugene saddlery
hi, where did u get the carbon fibre mat from?
bro, airplane model shops.. ermm.. honglim.. level 1 and 2 also have..
http://i15.photobucket.com/albums/a387/gabriel06/Rxk2_edit.jpg
danger is no stranger to a lonely ranger
my company got some lying around
i came across books on carbon fibre before.. but inside too technical, canot understand.
it say carbon fibre need to be weaved together.
in d case of cf mat is it aredi weaved and juz need to be done like normal fibre?
i guess u wud need resin + hardener n make a mould
where to get this resin?
