hi, i sometimes have this ticking sound. i think its coming from my exhaust area. can hear it clearly when i stop the bike. is this a problem?
chain tensioner if im not wrong.
hi there, i jus changed my clutch plate at pla**t last week, my weak accera problem is solved, but uprise another problem now.
i having very very hard time tapping into gear1 from nuetral & i keep hearing metal hitting metal sound *cling cling* at left side near gearbox region during riding.
any possible solutions?any serious problem with that mah?
Try adjusting your clutch cable.
åƒé‡‘难买早知é“.......
sometimes when you clutch in too much it would be difficult or impossible to engage gear 1... try clutching in halfway or 3/4... :cheers:
den i reply ur question with another question?
hahaha.. wats the difference between FI and carb?
The answer is...
in my mind :]
Yahoo it dude! :p
so is there anything i can do about it? replace the chain tensioner? is it necessary?
Got bike must ride!
SYM Maxsym 400i - 09/11/12 to current
Phantom TA200 - 07/08/09 to 09/11/12
the adjusting part is it the screw like thing near the clutch lever?
clockwise or anti-clockwise is should be?
release your clutch lever..yes adjust that knurled screw like thing..until there is a free play 3 to 5 mm on your lever at rest...
sometimes the cable is stuck/jam somewhere..and u find that the free play is different everytime u cltuch in and release
..if thats the case time to change it.(bike will be reacting to it resulting in eractic acceleration )...
if problem still exist after the adjustment...time to consult your mech.
Hi guys,
Wanna ask, Everytime I start my bike, it will idle for like 2sec then die off. Then I'll need to start again. Normally I start and accelerate it at the same time then the engine will be alive. Any idea what problem is this?
Two ways, a blakc knob for your idling on right side, can DIY with your fingers. The left side for tuning, leave it to mechanics. We don't know if its your spark plug, can't see it or your usage. :lol:
UPZ FOR GREAT INFO.
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
hey guys, i have this issue i encountered today. when riding, with a pillion and without a pillion, a loud bang could be heard once on each occasion in the middle of my journey. it sounded like it came from the rear, either the exhaust of the tire. i checked the tire, it was fine (i think). but im guessing the sound came from the exhaust, would it be the carb as mentioned in problem 13, because mine is not that regular u see. i will continue to monitor my tire and exhuast. please advise anyways. thanks in advance!
it is probably a backfire... it would sound like an explosion... caused by exploding petrol in your exhaust pipe...
try tuning your carb leaner, and avoid closing the throttle abruptly... :smile:
yes yes, it sounded exactly like an explosion or some sort and there were always "small bangs" when i release clutch.
anyway, thanks for the help. will update again.
followed ur instructions, tuned the carb a little, noticed my "idling" became better (or so i tot - how do you determine it anyway?), also let my go throttle more slowly today. so far so good, no bangs or explosion. thanks for the help! will continue to monitor.
as long as idling increase when you are tuning the carb... it is probably more neutral now that the petrol and air mix is more balanced...
if you feel that your idling is too fast at the moment, you can adjust it at the throttle body, at the right hand of the bike... turn the throttle on the handlebar if you do not know which item is the throttle body... it has one very very long screw... you can adjust the idling speed by turning it...
ok. i think i did not adjust the carb. i adjusted the throttle body instead, the one with the super long screw. hurhur.
lol... ok... well the carb can be adjusted from the left side... the screw itself is not obvious, so you have to ask someone in person to show you...
oh lol i see. damn it. jus now ride out ok. when ride back heard 2 loud bangs again. grr. maybe tmr go down to ah chong see what he say. sigh.
lol dun worry too much about it... yea dr chong should be able to help you with that :cheers:
i dont know if its a common problem. but my headlight is spoiling way too often in my opinion. i just changed the socket 1-2 mths back. and today i had to change it again because the contact on the socket has "become flat". The bikeshop ppl tell me phantom's bulb frequently blows. is this true?
Got bike must ride!
contact on socket become flat...? doesn't make sense... between the bulb and the socket there should be a spring... is it there...?
anyway, I haven't experience my headlight blowing since getting it in february... try a stanley bulb...?
:cheers:
i dont think there's a spring. should get it checked the next time i go down to ahchong. stanley bulb.. does planet has it? i just changed the socket and a new bulb. so i'll see how this last.
will probably have to go at a time when planet is less busy, so ah chong can do a nice check for me.
Got bike must ride!
