lol... what shaft you meant?
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
i sent my bike for overhaul again....this time is gear problem
1st n 2nd time - shaft broken :cry::cry::cry:
sigh... well... once your bike seem to start making funny sounds... its best to have a mech to check it out...
How did you get it broken twice in a row? :faint:
Oh man, my engine is leaking oil!! This morning I went down to my bike and noticed a sizeable pool of oil resting below my bike. Highly suspect it to be engine oil. Probably a gasket/camchain tensioner problem as highlighted above?
Class 2B
FW TA200
Safety above all
i think is gasket ;)
wow! u use e word pool, sounds dangerous, like alot leaked out... try to ride slowly to bike shop to have it rectified soon, dun procrastinate at all... :) cause engine oil very important for the engine... :)
i saw this bike..also a phantom...the eo covered amost a square meter on the floor...
later met him the the shop..hahhah a loosen drainage bolt is the cause..
this was loosen i suppose and the oil was dumped on to the floor..
if u are desperate ...use cooking oil..(try not to ride without eo...) this is better than nothing..
i always have a bit of balanced eo after the eo change..this is my standby eo..
for phantom riders i suppose some may not have this stanby eo around
i do keep spares of EO also.. for my Oiler and bike =D 2 in1
Hmmm, a pretty good suggestion bros! Will keep some spare EO too, but do I have to buy a new bottle now? What do you suggest?
Don't do it to others what you don't want others to do to you! God bless! :cheers:
yeah..u nedd to buy means u need to buy..
for me..the eo change is 2.3 to 2.5 L..so i always have some around..i use that for top up or my diy oiler too..
i also have 2t around for another bike..so u see..if the bike really has the oil dumped on the floor...i can use the 2t as well for emergency use..:cheeky:
Hi guys,
my phantom has a oil leakage on the cover of the top left opposite the spark plug which covers vertically for the chain tension inside the engine facing left side. Is it mean that the gasket spolit???
buy a spare bottle of EO from LAB cheap like $3-$6 a bottle ;]
K, will buy a bottle soon. Any brand can right? As long as it's 2T can liao right? So the next bike clinic, I'll have some for the oiler system. Cheers!
better buy the eo ..4t.. u normally used...eg..planet uses nasa semi..get a bottle of that..u can use to top up your engine as well as oiler if u have it.
note do not use car eo on your bike..it will damage the clutch plate.
i have/use 2t... because one of my bike is a 2 stroker..i also use this 2t to top up my oiler..not for the engine..what i meant was if emergency than use as eo..
note..2t is added to petrol for a 2 stroker..
Oh! Den I have to get 4T lor, since I'm using Motul 5100 15w50 4T now but no spare lah. K lah, will just get 1 bottle to play save.
Hi all, need some advice here. Currently stuck at home with a punctured front wheel. Last night was still ok :(
I will use my floor pump and try to get to planet la , but if it fails , anyone know of any reputable shops that can repair phantom tyres in the AMK ave 10 area ? Any recommendations from the industrial parks etc? Dont want to get carrotted leh :dot:
12 Jun 2008 - Class 2B
28 Jun 2008 - Honda Phantom TA 200 (COE 11/3/17)
17 Jan 2009 - Class 3
27 Oct 2009 - Class 2A
28 May 2016 - Yamaha Fino 115 (COE 04/8/24)
9 June 2017 - Honda CB400 Spec 2 (COE 02/1/23)
agree.. tubeless tires very easy to repair.. unlike bicycles with tube in the inside.
I have a problem with my phantom.
After starting my engine, there's always like "tick tick" sound coming from the engine without clutching in. It's silent after clutching in. Did told the mechanic about it and he said the clutch plate is loose but said its ok.
The sound is quite loud and when i just got this bike, it was silent for a phantom. Maybe I didn't give as much TLC to it as compared to the previous owner. I'm intending to continue riding this bike for afew more years as in the midst of taking my Class 2A.
I do hope the problem can be solved. Thanks!
Background information:
Honda Phantom TA150 Black
Manufacture: 1999
COE till: 2019
Mileage: close to 98k
I went to change my engine oil today. During the draining, bout 200ml or less only came out. Is this a bad sign? Please advise.
wow... it's best for you to monitor the engine oil level for the next whole week.. If oil level continue to drop, bike may need overhaul..
this is not a bad sign, its a super bad sign man..
this happened t mine too..
th block is eating up your engine oil, if you were t ride with insufficient eo, chances are your piston ring wld come loose & its a matter of time for ovrhauling..
this happened t mine at least.
black&white saves life.
enquire @ [email protected] | 94786'999
yes, this is very serious. please check your oil level every 300km from now onwards... do not ride the bike if the oil level drops below the minimum level...
