'BRAKING' Brake Pads - Power Under Control
BRAKING Brake Pads now available at Unique Motorsports.
http://www.motovation-accessory.com.sg/images/article/7/brakingtop.gif
Braking was created in 1990 and immediately expressed its original ideas, which created the base for its future success, led by the strong certainty to be able to produce something new, in a sector, where everyone thought almost everything had already been expressed, and which was in the hands of few leading companies.
Their strong presence in this difficult market made of high-technology products led Braking to a constant and fast evolution, which took them to today's important productive reality.
Always committed to the race world, where Braking has obtained great success in the whole world, they've been able to propose technologically advanced solutions, easy to be accepted by everyone.
Starting from the oversize off-road and scooter kits, to the famous and unusual perimetral kit and then to the wave disks: these are the important steps which made our company a leader in the whole world.
Now Braking represents one of the most important realities in the after-market world of brake systems, and is the only company which can offer a valid alternative to the traditional round disk.
Braking is located north of Milan in the middle of Brianza, it covers a surface of 3000m2, has super-modern equipment and a specialized and very motivated staff.
http://www.motovation-accessory.com.sg/images/article/7/padslogo.gif
BRAKING have a large range of pads dedicated for every kind of motorcycle. Braking pads are available in several compounds created for every type of use. The basic material they use is particularly high for a coefficeient of friction. Mixed to a soft, non-aggressive metal component that serves as a kind of lubricant so that the pads on the brake better glide. That is the secret of unbelievably good, with a soulful BRAKING braking system - the driver always retains full control.
BRAKING brake pads are compatible with discs such as forged from cast iron and stainless steel, of course, particularly suited for use with our brakes for optimum braking and control. A combination of BRAKING-coverings with BRAKING discs is the best choice for best braking at full modularity.
Price: $65 each set with installation
Wave Disc:
BRAKING have invented the WAVE disk (see the photo) and, in doing so, have revolutionized the concept of braking. Thanks to several studies regarding deformation of metallic material and heat dissipation, BRAKING have increased the limit of the performance of stainless steel discs. Today a lot of teams use the Wave disks for racing, the same disks that are sold by our dealers.
All the BRAKING discs are made from stainless steel with a high percentage of carbon that has a high friction coefficient. The round discs, front and rear, keep the same measurements of the OEM disks, with more performance.
Braking wave discs are available fixed or floating in accordance with the OEM or update to the OEM oversize.
The floating discs of the STX series have the carriers made of black oxidized aluminum. The wave disks are available for (the) most of the bikes sold from the nineties in street category, off-road and scooter.
http://www.motovation-accessory.com.sg/images/article/7/diskstop.gif
STX: STX street uses the good high-carbon stainless steel, It is superior in the control characteristic like the cast iron. Inner uses the 7075-T6 Dura aluminum and has become floating type (fixing).
SK: The SK disk which was developed with Braking and domestic Sunstar Incorporated jointly as a wave disk of 07 models. It is called SK with use as a street and a one for race/lace. And use individually for Left and Right only.
S3: Wave semi-floating disc. Disc material and construction way: laser cut stainless steel AISI420, heat treated + finished on CNC machines.
BRAKING Wheels:
B-One project was born in the R&D Braking department, aiming at revolutionizing the fixing system of the disk onto the wheel, by improving the performances and at the same time reducing the number of components. Latest innovation Braking is the complete aluminum - Wheels - system called "B-ONE". Made by OZ, B-One are Aluminum Forged wheels.
Unifying forged elements with a special wheel, allows to avoid all non rigid connections, in order to give the system a superior rigidity level.
Also, getting the weight of the wheel’s axis closer, allows a lower gyroscopic effect, thus improving its handling, stability, and entering the curves on a motorcycle.
Braking wanted to give a new added value to the rotation masses, by creating a one-piece integrated group made of disk-hub & wheel, in order to decrease the inertias.
Wave disks integrated in a totally new wheel composed of fused and forged elements
A new solution to obtain incomparable performance, design and costs.
http://www.motovation-accessory.com.sg/images/article/7/wheelstop.gif
Kit Includes:
FRONT: Braking one-piece nine spoke wheel made of aluminum complete with floating wave disks
REAR: Braking one-piece nine spoke wheel made of aluminum, complete with wave disk, rubber bushing and aluminum sprocket 7075T6.
R1 07/08: $3000 with installation
GSX 1000R 09: $3000 with installation
Gilera VXR200/ST200 2006-09 Front BRAKING Wave Disc
http://i600.photobucket.com/albums/tt84/uniquemotor4/GileraVXR200-0609wavedisc.jpg
Braking has finally made a Front Wave Disc for Gilera VXR200/ST200 2006-09. BRAKING SM1 brake pads for the disc are also available.
Gilera VXR200/ ST200 2006-09
Front BRAKING Wave Disc: $170 with installation
Front BRAKING SM 1 Brake pad: $45 with installation
BRAKING Front Brake Disc + BRAKING brake Pad for Yamaha Sparkz 135 / X1R 135 ($130)
http://i600.photobucket.com/albums/tt84/uniquemotor4/BRAKINGSparkz.jpg
$130 BRAKING PACKAGE (UP $150)
- BRAKING Front Brake Disc x 1pc
- Installation
Specially Made for Singapore Yamaha Spark 135 and X1R 135!
While stock last!
BRAKING Wheels:
Kit Includes:
$3000 GSX 1000R 07/08 Package:
- FRONT: Braking one-piece nine spoke wheel made of aluminum complete with floating wave disks
- REAR: Braking one-piece nine spoke wheel made of aluminum, complete with wave disk, rubber bushing and aluminum sprocket 7075T6.
- Installation
$3000 R1 07/08 Package:
- Installation
Ready stock. While stock last!
Edited by Unique_Motorsports
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
  • Replies 180
Upzzz.. Heard alot of good comments abt BRAKING brake pads from frens.. Now that u all bring in, can change at ur shop liao.. Boss, wad's the price?
Max
SpecIII Rider
http://i277.photobucket.com/albums/kk53/u0605382/SNC00042-1.jpg
http://www.speedtest.net/result/333285646.png
Best Regards
Kelvin 87178999
WL: Zul 84818999
so for CB400 it will be $195 for 3 pairs ya?
Yup. You are right.
Best Regards
Kelvin 87178999
WL: Zul 84818999
How about R6 07??
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
any pads for gilera??? sm1? cm55??
Sorry, we do not have BRAKING brake pads for scooters.
Best Regards
Kelvin 87178999
WL: Zul 84818999
kelvin,the brake pump include the lever?can fit spec3?
Yes. Include brake lever. Can fit Spec 3.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hw much will it cost if diy braking brand brake pad??:angel:
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Wave Disc:
Wheels:
Kit Includes:
Braking Forged Master Pump
Braking New Forged Master Pump with/ without Integrated Reservoir.
Available in 16m or 19mm Piston
Brakelight Switch and mirror mount included.
Price: $470 with installation
cn be install on super 4 vtec 2?
Yes, available for Super 4.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  • 5 months later...
Braking Wave Rotor Availability for:
Honda Vtec1/2/3 Braking Front Wave Rotor $450each
Honda Vtec1/2/3 Braking Rear Wave Rotor $240each
Honda Revo Braking Front Wave Rotor ( Non- ABS ) $450each
Honda Revo Braking Rear Wave Rotor $240each
Aprilia RS125 2006-09 Braking Front Wave Rotor $450each
Suzuki DRZ400SM 310mm Braking Front Wave Rotor $450each
Suzuki DRZ400SM Braking Rear Wave Rotor $240each
Honda CBR1000RR 2008-09 Braking Front Wave Rotor $450each
Honda CBR1000RR 2008-09 Braking Rear Wave ROtor $240each
TMAX 500 2008-09 Front/Rear Rotor and many more.......Brakepads as well.
Best Regards
Kelvin 87178999
WL: Zul 84818999
how much to change all my brake disc in my cbr600 to wave disc?
any braking wave rotor for r1???
if have can quote me the price for both fronts n rear...??
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://www.motovation-accessory.com.sg/images/article/7/2009brakingpromotion.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi towkay, planning to change my rear brake disc soon, pls pm me yr best price :)
1) Braking rear disc
2) EBC brake pad (rear)
btw any offer for taking e braking rear disc? thanks..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
thanks towkay.. wil show up soon.. :D:shades:
Sure. Thank you for your support.
Best Regards
Kelvin 87178999
WL: Zul 84818999
any wave rotors for revo with ABS??
Only a Biker knows why a dog sticks his head out of a car window.
