  Quote
Originally posted by SiaoSter@Aug 9 2006, 03:20 PM
eh anyone tried the ducati look alike sai tao?
dono will the headlight be as bright as the stock head light a not
i quite like the stock head light brightness :sweat:
the brightness is also due to the big reflactor ba...
my 2 cents...
  Quote
Originally posted by ad1da5@Aug 9 2006, 01:33 PM
Wan to share but not? I thinking of getting it too...
Hi Tis is my wire mesh :smile:
http://www.MyOnlineImages.com/Members/spec3/images/hondaz18dq.jpg
http://www.MyOnlineImages.com/Members/spec3/images/PIC_0008.JPG
http://www.MyOnlineImages.com/Members/spec3/images/PIC_0007.JPG
Some biker once said " If u haven't been to Gerik, U haven't been touring in Malaysia".
  Quote
bro, i have a question...
will the radiator fan always turn on for your bike after installing this? cos i see the holes like very small ones... :confused:
  Quote
nope :smile: Job well done
  Quote
Originally posted by s4vtec@Aug 9 2006, 02:30 PM
thanks for the comments...
engine breather is to dissipate heat build up when u r in a traffic jam or when u go JB then jam at customs... after installing, i did feel a bit of difference in the engine heat during traffic jams...
Yes breather hose is for a purpose.....but aren't it fixed at the wrong location?
Or this articles has more truth in it?
Venting pipe at crankcase oil cap?
:goodluck:
Guest quizesilver
s4vtec,
what u did is the wrong way and nt the correct way.
and all pls refer to the post by kushinagar that is the correct way.
the hose starts from somewhere near our carb
  Quote
Question: I have seen a lot of people installing a pipe on the engine tranny cap (they change the nut to one with the pipe connected). It was said to let the engine to cool faster. Some also got put one filter at the end of the venting pipe. It is true fact? Answer: There is always a proper way to route the vent crank(if its so necessary). I have seen many attempted to route it via the WRONG WAY which is from where you pour in your oil to the tranny. Seen many strokers who does the same as to route some yellow pipe from the tranny cap to the rear of the bike and finish the job with a tiny K&N filter. Its a waste of time and waste of money. Rightfully, the logic of venting the crank is to relieve the pressure built up within the crankcase and hence you see many 4 strokes engine route a pipe from the crank vent (not the engine tranny cap) to the rear and attach the end of the pipe to a filter. WHY? if you are adventurous enough, you see that the vented hose actually emit gas and at the same time suck in the gas(due to vacuum). This is called a \"breather\" hose and this is wat they do. So in order not to suck in particles back into the engine, you place a filter elements to catch all these dirts and dust particles (same logic with air intake air filter) and this is why it is totally illogical and unnecessary to have it on Two Strokes machines. Plus you vent it thru your tranny cap, if you insist on doing so, you will probably observe a drop in tranny pressure and this is surely bad news because the red light which represent low oil pressure will start blinking and most of us will probably thinks that the oil level is too low and attempt to top up with additional oil and causes the engine to run sluggish due to too much inertial build up and increase drag, lost of power... and plus, too much oil in the tranny will cause your oil seal to ... you know the rest... So in a nut shell, you can live without venting the crank. If you want, do it the right way. As for two strokes, don't bother doing so. It might look trick but to some who knows the implication, it's a joke.
can someone guide me on this?
i have questions...
1) where is this crank vent? (not the tranny cap, right?)
2) to do it the right way, how to do it? (im confused)
:confused:
thanks... :)
  Quote
any pics to show where is the correct place to install the breather tube w/filter?
thanks for the advices...
all learn from one another...
:cheer:
  Quote
Bro... thats a job well done!:thumb:
What do you use to paint the honda logo? Spray can? Paint Marker?
http://farm2.static.flickr.com/1055/527481558_8975eefe29_m.jpg
Dec00 - Aug03 : Honda Phantom TA150
Aug03 - Feb06 : Honda CBR400RR L-model
Oct03 - Mar04 : Honda NC35 RVF400RR
Feb06 - Oct06 : Honda CB400 HyperVtec
Oct06 - Sep07 : Honda NC35 RVF400RS
Sep07 - Now : Alfa Romeo 147 1.6 T.Spark
  Quote
my 2 cents...
yeah tats wat ithink too.....but if only they can serve the same brightness woohoo !! thats one sai tao worth getting !! :cheer:
  Quote
wat abt Spec 3 reflector? that one better than Spec2 and Hyper VTEC reflector... more brightness... :cheer:
Guest quizesilver
ask ur friendly mech,
i can't show u as i nt that firece to fix that.
i slow ride no need any extra vent.
good morning guys :smile:
my self installed hugger from Bro blood_red. :cheer:
Guest quizesilver
  Quote
that is a belly pan...
not a hugger...
  Quote
not a hugger...
oops!!! haha! paisei... wat's happening to me huh??? :sweat: :cheeky: :smile:
hi bro s4vtec which moto shop did u buy the belly pan? n how much?
looks kinda different compare frm the first belly pan... looks much more smaller huh..
  Quote
this belly pan can get from motoworld
shelf price is between $60 to $80
its smaller in terms of height but the length of this belly pan is longer than the old one it covers practically ur bottom part headers. :smile:
Guest quizesilver
correction can get from $50 - $80
ya depend on how well u noe them.
  Quote
yo, i actually bought the belly pan from a forumer, which he bought it from Motoworld.
self install... this is the longer version belly pan. :smile:
i did went down to Motoworld few weeks back to check out the belly pans...
there are a few versions depending on which one u want...
as for the price, i am not sure already. :sweat:
:btw: i'll be getting my hugger from Motoworld next month as this month over spend on my bike already... :giddy: :sian:
  Quote
wah, ur intro "machiam" Motoworld Salesman... haha...
:sweat: :cheeky: :cheer: :smile:
  Quote
Originally posted by s4vtec@Aug 9 2006, 02:09 PM
headlight cutoff switch... see attached pic... its under my ERP unit...
guys, i wana share and ask something. when engine is at idling, there is no charging. only when you rev throttle or travelling then there is charging.
can someone enlighten me? :confused:
for headlight of S4...if what i said above was correct...
in the morning when we cold start, sometimes engine will stall coz the headlight is drawing current from the batt and the charging system, causing it to stall. so the way to prevent stalling is to install a headlight switch so you can turn off your headlight when you cold start your bike.
can someone enlighten me again? :confused:
attached pic is my DIY headlight switch... under the ERP unit...
Guest quizesilver
s4vtec pls do not try to "sell" ur "product" to other forumer.
  Quote
Hi i also do this kind of thing but pls,here is to share info but not share then sell. I noe where you getting into. Seen a few of this "tactic" done by you. Not steady lah liddat bro :smile: evry body wud hav open their own "thread shop" if were allowed. Hope i didnt pissed you off.
Ive bought Rjays side bag and just went to Seng Kwang to discuss about making a stainless bracket for it. Quoted $240 for both sides. Its those tubular metal that takes a shape of reounded edge square that AT(African Twin) uses. Is the price justified?
http://i62.photobucket.com/albums/h89/Hyper_Vtec3/Sidebag.jpg http://i62.photobucket.com/albums/h89/Hyper_Vtec3/Overall.jpg
my ride my VTEC
