  • Replies 2.2k
hi unique...can 3 pts crash bar install onto pb1?
Can. The 3 points crash bars can be installed onto Ver S/ R / PB 1/ Vtec I/II/III.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
Tires Promotion for Honda Super 4/Vtec
Tires for Super 4/Vtec I/II/III
Servicing & Tuning of Carburetors:
- Servicing of Carburetors
- Tuning of Carburetors
Cost: $60
Clutch Plates:
- Replacement of clutch friction disks
- Replacement of clutch cover gasket
- Installation charges
Cost: $120
K&N Air Filter:
- Replacement of stock air filter with K&N air filter (For Ver S and Vtec only)
Cost: $65
Servicing of K&N Air Filter:
- Servicing of K&N air filter
Cost: $10
Steering Cone Bearings:
- Replacement of both steering cone bearings
Cost: $80
Fork Servicing Package:
$80 Package
- Replacement of both fork oil seals
- Replacement of both fork dust cover
- Servicing of both forks
- MAXIMA or Yamaha fork oil
$96 Package
- Replacement of both fork clips
$200 Package
- Replacement of both fork springs
Radiator Hoses (Coolant Hoses):
$180 Package
- Replacement of all 7 coolant hoses
- Flushing of radiator and cooling system
- Engine Ice Hi Performance Coolant
- Workmanship
$480 Package
- Replacement of all 7 coolant hoses with Samco Sports Hoses
- Workmanship
Rear Suspension Servicing Package:
- Servicing of both rear suspensions (Require one to two days time)
Cost: $180
3 Points Crash Bar:
- Available in Black or Chrome
Cost: $55 with installation
Magnum2 Stebel Horns:
- Installation of a set of Magnum2 Stebel Horns
Cost: $40 with installation
Radiator Flush + Engine Ice:
- Radiator Flush
- Top up with Engine Ice Hi Performance Coolant
Cost: $50
Bellypan:
- Installation of bellypan
Cost: $55
Respray of Bike:
- Respray of Super 4/Vtec (Time required: 7- 10 days)
Cost: $250++
Respray of rim:
- Respray of rim with 2k paintwork (Time required: 2- 4 days)
Cost: $80 for one rim, $160 for both rims
Headlamp Control Switch:
- Installation of headlamp control switch
Cost: $25
Aftermarket Spec III Look Alike Head Lamp:
- Installation of aftermarket Spec III Look Alike Head Lamp
Cost: $110
Brake Pads:
- Replacement of worn brake pads
- Many brands to choose from
Cost: $20 - $65 per set
OWS 3 in 1 Performance Package:
- OWS 210 Engine Flush
- OWS 220 Engine Protector
- OWS 360 Gas Treatment
Cost: $68
Wheel Bearings:
- Replacement of 2x front wheel bearings : $28
- Replacement of 2x rear wheel bearings : $28
- Replacement of 2x rear wheel bearings + 1x sprocket bearing: $38
Wheel Balancing:
- Balancing of one rim: $25
- Balancing of both rims: $40
Carbon Fibre Levers Set:
- Carbon Fibre Brake Lever
- Carbon Fibre Clutch Lever
Cost: $28
Brake Discs:
- Front Original Honda Brake Disc: $255 with installation each
- Rear Original Honda Brake Disc: $155 with installation
- Rear Aftermarket Flower Brake Disc: $60 with installation
Duplicating of Spec II/III HISS Keys:
- Duplicating of 1 key + Memory Setting :$60
- Duplicating of 2 keys + Memory Setting :$100
Bleeding of Brake Lines:
- Bleeding of both front brake calipers
- Bleeding of rear brake caliper
- Using Motul 5.1 Brake Fluid
Cost: $60
HEL Brake Lines:
- Replacement of all 3 brake lines (2 in front, 1 at rear)
- Many colours to choose from
- Bleeding of all brake lines
Cost: $200
Venhill Brake Lines (UK):
- Link to more details
Cost: $220
Brake Calipers:
- Servicing of calipers
- Replacement of all caliper o rings
Cost: $130 for front 2 calipers & $70 for rear caliper
Exhaust System:
- Yoshimura Titantium Exhaust: $600
- Yoshimura Titantium Firespec Exhaust: $630
- GPR Carbon Fibre Exhaust: $490
- Scorpion Carbon Fibre Oval Exhaust: $660
- Scorpion Titanium Oval Exhaust: $660
- Scorpion Titanium Flame Oval Exhaust: $720
- Leovince Plain Exhaust: $530
- Leovince Carbon Fibre Exhuast: $690
- Moriwaki Stainless Steel Full System (Short): $1400
- Moriwaki Titanium Full System (Long/ 2.8kg only): $1600
- Micron Full System: $1450
Volt Meter:
- Installation of volt meter : $50
- Meter Holder: $10
All the above are for Honda CB400 PB1/ Ver S/ Ver R/ Vtec I/II/III. Should you need have any further enquiry, do not hesitate to contact us at:
- Tel: 68446378
- Emai: [email protected]
- PM us on SBF
hie..out of all the prices u stated, wats the price for new chain & sprocket? thanks
Chain & Sprockets Replacement:
GPR X ring chain + sprockets: $150
RK X ring chain + sprockets: $190
DID X ring chain + sprockets: $220
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi There, is the 3 points crash bar made of stainless steel?
Nope. Made from metal but not stainless steel. Stainless steel will cost much more.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi,
Can you duplicate a spare key using mine as the master key at bike shop was lost and the cost?
Hello, are you there......
Hi,
Yes, we can duplicate/memory spare keys for Vtec II/III. Do drop by when free.
Best Regards
Kelvin 87178999
WL: Zul 84818999
do u do bike washing?
Sorry, no. However we have a wash area. You can DIY.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Shawn and Kelvin, Baik ar u guys, :thumb: .. Good service, Friendly and got free drink! Will recommend my frens to UM.. P.S, I dont noe whats the guy(Big, Long hair) name and say thanks for servicing my carburetors. Good Job done.:thumb:
Rockstar Bro! :thumb:
Thank you for your feedback and support.
The big size guy is Ah Kee.
Have a good day.
Best Regards
Kelvin 87178999
WL: Zul 84818999
yo bro,
spray painting or do you use coating?:confused:
Spray painting. The same paintwork you see on your fuel tank and fairings.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Sitemap of Unique Motorsports
Looking for any services or promotions offered by Unique Motorsports?
Simply click and view them at:Sitemap of Unique Motorsports
Best Regards
Kelvin 87178999
WL: Zul 84818999
Vtec Radiator Cover with cooling plate: $95 with installation
http://www.uniquemotorsports.com.sg/pic/vtecradiator.gif
http://www.uniquemotorsports.com.sg/acc/vtecradiator2.gif
Best Regards
Kelvin 87178999
WL: Zul 84818999
YOSHI Front Fork Stabilizer for Yamaha Sparkz 135 @ $75 with installation
http://www.uniquemotorsports.com.sg/acc/t135fork2.gif
RACING BOY Front Fork Stabilizer for Yamaha Sparkz 135 @ $75 with installation
http://www.uniquemotorsports.com.sg/acc/t135fork.gif
YOSHIMURA Front Fork Stabilizer (Carbon Look) for Honda CB400 Super 4 @ $95 with installation
http://www.uniquemotorsports.com.sg/acc/vtecforkcarbon.gif
DAYTONA Front Fork Stabilizer for Honda CB400 Vtec I @ $165 with installation
http://www.uniquemotorsports.com.sg/acc/daytona.gif
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi..i would like to enquire,i bought a super4 version S recently and it has very weak pick up,the rpm meter goes up very slowly when I rev the engine.. what could be the problem?? I have recently changed my chain and sprocket, my air filter is original, and it is very new..Which package should i take up which might help solve the problem..Thank You
van_s
Do drop by when free, i get my guys to check for you.
Hi Guys,
would like to check for the chain and sproket replacement. for the sproket is it the original honda sproket?
Yes. Original Honda sprockets.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi. May i noe if u guys carry motul 7100 and wat is the cost for oil change [3.2L] wif honda oli filter for spec3? In case there is no 7100, let me noe the price for motul 300V. :angel:
We have Motul 300v. $85 for Vtec and Ver S.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Chain + Sprockets Replacement:
- GPR X ring chain + sprockets: $150
- RK X ring chain + sprockets: $190
- DID X ring chain + sprockets: $220
can i check with you is your price list above still the same for cb400 Spec 2?
Is the sprockets from honda? If not made from where?
It Is Not How FAST You Can Travel, But How FAST You Can Handle?
Yup. The above prices are applicable to all Super 4/Vtec I/II/III.
Honda original sprockets.
Best Regards
Kelvin 87178999
WL: Zul 84818999
