Hi, sorry but I couldn't find anything on this. I've been adviced to change engine oil frequently to help maintain my engine to be as good as the first day I bought it. But is there more that can be done to maintain the engine? Like I should avoid letting my bike hit high rpm too often, all that?
Lube chain/check brake all these not counted. This thread is purely for ENGINE only.
http://i41.tinypic.com/2vj99ua.jpg
http://i243.photobucket.com/albums/ff288/jinpwnsyou/Whack_a_kitty.gif
  • Replies 19
How about checking of Spark Plugs? The plugs will show the condition of the engine cylinders. Using the right plugs is VERY VERY important.
* Suzuki GSR750
Maybe before changing ur EO & oil filter, u should flush it first using OWS engine flush..Making it clear the engine completely b4 refilling..thus making ur engine last longer,IMO lah..lol
Sharks are born swimming..:shades:
always give time for engine to warm up.
engine wear most at initial start n when it is cold.
most of us will startup engine wait for a minute or so then move off.
this is insufficient time to let the oil warm enough for it to be in fully function state.
it usually takes about 5 mins for oil to warm up at idle 1.5k rpm.
if u r in a hurry, just throttle up to 2~2.5k rpm for about 2~3 mins then go slow for 1 km.
Edited by stsoh
I try to do that as much as I can but sometimes really rush.. But yes, when I do go off early, I go slow at the first few kms!
Let me summarize
1. Change engine oil frequently
2. Use the right spark plugs
3. Flush engine with OWS Engine flush when changing EO
4. Warm up engine before moving off
By the way, my bike has no oil filter. Honda CBF 150. Is there something in the engine that does the oil filter's job?
others to consider include...
+ maintain clean/good radiator coolant (e.g. change every 24k kms or annually)
+ cleaning/washing the carburetors (e.g. every 16k kms)
+ synchronizing the air-valves (e.g. every 5k kms)
+ valve clearance (e.g. after substantial mileage, subjective)
+ check condition of ignition wires & contact points
+ check condition of magneto using voltmeter/multimeter
+ timing belt/chain change or adjustment
+ check condition of clutch if visible (for scooters)
+ etc...
Current Ride: FJS400 Silver Wing
Trips:
23~27 Dec 2014: 5D5N KL & Ipoh
Scooby's blog http://scoobydooby-doo.blogspot.sg/
Tech Corner http://www.singaporebikes.com/forums/showthread.php/325894-lt-Info-gt-Silverwing-400cc-600cc-Tech-Corner
bike tat dun have filter element, they do have a strainer filter.
it's a wire mesh cone shape usually located at the bottom where the drain plug is.
when u drain your oil by removing the drain plug then u can see it.
there will be a spring between drain plug n strainer.
just use air to blow the strainer n make sure nothing like carbon or sludge is stuck in between the mesh.
how to blow carbon in pipe if u riding auto bike? cannot rev sia.. haha
main stand la BRO!
Class2B>TP on 22 May -Passed
Class 4>? start by 2009
There's a book called "Motorcycle Owners' Manual" that you can get for about S$21 that has lots of information around some of the basic maintenance you can do on your bike. I find it very good information as I am new to bikes so your mileage might vary. But I do recommend a book at least for a solid foundation.
http://simonnunis.smugmug.com/photos/684724736_fuDoa-M-1.jpg
haha,but u havent tell us where to get the book.. :cheeky:
what goes around comes around.
I got mine from Borders Books at Whee Lock Place. Call them to check if they have anymore in stock before going to check. You can also call Books Kinokuniya to check.
Change oil filter every 2 oil change....I am change oil frequently.
Every 2000km or so....Sometimes fully syn sometimes semi syn depending on mood.....
Maintainin 4 stroke noting much leh .. unless its 2 stroke .. tats a killer ...
2 stroke killer? doubt that. the only difference to me is there is a 2t tank. other than that, its pretty much like any other motorsikal
Slow is smooth, smooth is fast
agree, to maintain a 2 stroker is more a hassle esp during full service. always hear "abg, ur this one wear out already", "abg, ur this one leaking already":faint:
dark mode, or light mode?
http://img.photobucket.com/albums/v241/one8tytwo/125ziblack.jpg
125zi
how about carbon build up?:thumb:
as long as you do your stuff right, dont think its a killer, definitely more maintenance, but isnt that bad. it varies from model to models, legendary pa si buay tor rxk are still holeshot-ing at traffic, roaming around at eway like no way
http://i44.tinypic.com/54c3gg.gif
2t tank ?? How bout the risk ure taking when ure 2t cable gets deposits and unable to dispense 2t in ya cylinder ?? Bamm !! Broken machine .. I dun really trust 2t tank coz they aint tat accurate in dispensing
2t .. But on the contary , im using 2t tank .. haha !! dumbazz me !!
Be humble on the road at all times coz u'll neva noe wen u need any rider's help...
