I just changed my brake pads recently. Everything is fine till i rode in the rain. When it rains, my front brake suddenly got problem. I have to press harder than normal then got braking power. Also when i press harder, got loud sound come out and some vibration too. I ride a rxz.
issit brake pad problem? or smth else?
  • Replies 11
is it a loud screeching sound? I think its normal because water reduces the friction when it makes contact between the pads and disc brake. Thats why you need a longer braking distance in the rain.
yup do check your brake hose.get those steel type.and if u still find that not enough braking power,change to a better pad.and if u still find it not good enough,upsize your pump bore. =)
http://img600.imageshack.us/img600/2353/85571635.png
i believe its normal bro...
remember what school teaches you about intermittent braking on wet days?
it is because during rainy days, brakes are not as effective. for simple reason is your disc brake is wet hence its slippery.
i face the same thing too.. so gotto go slower on rainy days bro
ride safe!! :cheeky:
Edited by mfaisalby
Apr 2006 - Oct 2009: Yamaha RXZ 135 (FS 3*** E)
Oct 2009 - CURRENT: CB400 Spec 1 (FT 7*** J)
Yeah If Still Not Good Enough, Use Your Feet To Stop Like How Fred Flinstones Stop His Car. :lol:
Agreed, I face the same problem too when I ride in the rain... For effective braking, down gear and brake simultaneously, please ride slow during rainy days. Do regular check on the tires for worn out threads or insufficient pressure.
alright. cause this never happen with my old brake pads tt i have used for the past year. only until now when i change new brake pad den it happen
:lol::lol::lol:
Ride Defensively; always.
Class BB2BDC - 11AUG2010
Kawasaki KIPS -> 2010 ~ 2014
Class BB2ADC - NOV2016
Suzuki DRZ -> 2017 ~ 2018
Honda Revo -> 2018 ~
This also depends on the brake pads you use bro. A good one will work both in wet and dry conditions without and trouble. Change of brake hoses is to make the brakes more responsive to your touch. It is good to change also.
So what brake pads are you using?
change brake hose roughly hw much? for front or back or both tgt??
Depends on how many brake lines are need and brand & quality do play apart. Best to check with shops. Some brand names are HEL, Active and Swageline
Edited by IvikaRazI
* Suzuki GSR750
