hi guys ive read some thread abt led diy , found out tht we need to place resistors to prevent too much current going in to the led and spoiling it , and can anyone share with me how to install led strip on my bike ? nsr sp ,
Link the led to where and where ? and if wanna add in a switch , hw do i do it ? pls help me thx ! :cheeky:
I will reach for it no matter how high it is :cheeky:
  • Replies 5
i've tried linking up my share of leds. depending on what type of led u are using. if just normal led bulb rated less than 15A(mybike) u might want to attach a resistor in series. but if your using led strips like me, see dp, its perfectly fine to just wiring up to power source, i tapped from my pole light. Led strips(the one im using at least) has resistors alr inside the strip.
oh , so i can just link all the led strip wire tgt and tap from my head light or pole light ? like..
[-- [LED strip 1]----]
[-- [LED strip 2]----]+ ---+[pole light]--[bATTERY]---]
[-- [LED strip 3]----]............................................]
[-- [LED strip 4]----]............................................]
[_____________________________________________]
and for LED bulb w/e resistor where do we find resistor ? and the resistor is placed b4 the LED bulb like
----- [battery]---- [Resistor]----[LED bulb]------[back to battery]
is this the case ?
thx !
