to all nsr SP riders.. i have a problem with my nsr 150. when i pick up my bike after around 35----40 km ,then i change to gear 2 then i carry on moving on.. when i reaches my traffic light,when i want to change back to gear one do i kick back to neutral? or can i kick back to gear 1? because when i imediately kick back to gear 1. i hear a loud THUCK sound coming out from the gear.. i need help.. is it my way of kicking the gears? or my bike's problem.. help is great appreciated.. =DD thanks to you all in advance..
  • Replies 16
try 2 kick into gear 1 in a more lower speed....
:makeup: :shy:
Reality is the only obstacle to happiness. .. ...
lol up to u to stop at wat gear.....can also go neutral way before the trafic light n stop with the brakes oni.depend on how u ride r bro..go n try out then see wat u are most comfortable with.no right or wrong answer...tuck sound normal r..unless damn loud like breaking den someting nt right r.
~Please Ride N Drive Safely.~
if u cant,its ok,but dont bring harm to other ppl.
wana die,go die alone.dnt bring innnocent ppl along.
OKae!
are you using a 'racing footrest'? if it is quite common just kick harder. sometimes from neutral damn hard to go to gear 1 also like keep got the ziggggg sound.
first two gears are "heavy". apparently if its very loud then most likely your speed is still high when you shift to gear 1
its nothing, just remember to close throttle. and kicking from neutral to gear 1 in high speed, creates that loud THUCK sound. this usually happens when you're about to reach a red light at neutral then suddenly green light.
u tried changing to a low gear on a high speed i think like wat the rest said....try getting a lower speed or if not just stop on gear 2 den change to neutral lor if red light, u'll get used to it...
July2004 - dec2007 ->NSR150SP (FU**29B)
April2008 - April2010 ->CBR400RRR (FP**86R)
April2010 - April 2011 ->SYM GTS200(FBB**09U)
April2011 - Currently ->S4SPEC1(FT**56J)
If you think you are beaten, YOU ARE
if you think you will lose, YOU HAVE LOST
if you think you cant, YOU DEFINATELY WON'T
SUCCESS only comes to the man WHO BELIEVES HE CAN!
