  • Replies 4
can anyone help? my brake light not working? how to fix?
check the easy stuff first. check the bulb is not blown, and check the fuse. beyond that, you'll need a wiring diagram and a multimeter to trace the problem.
yeah..bulb and fuse first..
then check your the contacts which is activated by the brake..ie hand/leg..then check cables/wires.
yahh the connection between the brake switch and brake lever.
the front is normally the click click feeling when u presss and release lever.
rear is normally a spring hooked to lever.
