  • Replies 8
There are general 3 types of oils. Mineral, Semi-Synthetic and Fully Synthetic.
Mineral is made from real crude oil, then they refine until you get the oil. Fully-Synthetic oil is oil which is made in the lab. Not from the ground. Semi-synthetic EO is a blend of mineral oils and synthetic oils.
You want, you can google it up more.
New bike use Semi-Synthetic or Fully Synthetic ??
Old bike use Semi-Synthetic or Fully Synthetic ??
请原谅我, 一切都是我的错, 都是我ä¸å¤Ÿæˆç†Ÿ
緣分和愛情是什麼
æˆ‘æœ€æ·±çˆ±çš„äººä¼¤æˆ‘å´æ˜¯æœ€æ·±
Semi-Synthetic or Fully Synthetic....Not that important. As a rule of thumb, Fully-Synthetic formulas lasts longer than Semi-Synthetic. The item that you need to take note is the Oil Viscosity. Older bikes will have more worn pistons than new bikes, thus the need to use thicker oil or higher viscosity. If too thin of Engine oil is used, it will leak into the chamber and gets burnt off with the petrol, which causes you to have to top up the Engine Oil.
* Suzuki GSR750
I have a fren that swore he nvr use fully syn. He only use semi syn on all his bikes upto 2004 yamaha r1. He did a top servicing and the mech was amaze how clean his engine were. Of coz oil change interval of 5k
Sent from my GT-P1000
Past to present rides
Honda nsr sp 150 pro arm
Honda cbr 600 rr
Aprilia sr max 300 I.e
Agreed. Regular maintenance and the know how is a way to go.
So mineral is beta for vintage bikes ya
If the engine is rated to be on Mineral Oil....the answer is yes.
* Suzuki GSR750
