Not to worry, it is coming from the front shock absorber. My bike got the sound also.
http://pics.homere.jmsp.net/t_24/101x80/031002_arc.gif
They are coming!(War Of the Worlds)
  • Replies 311
Guest bomerman81
think its beta to go let mech check it out..... but most like mothing to wori lah....:smile:
anyone can give me some advice? when i move off halfclutch or moving at slow speed can hear a rubbing sound from the rear disc plate,but i go to bike shop ,the mechanic take out my rear brake caliper he say my caliper kanna oil so thats why got rubbing sound between the brake pad and the disc plate.dunno is it true or not.after he clean liao still got a bit of the sound.
have to service yrs caliper already... long old is urs bike???
my pistol of the caliper stuck for my bike.. which is 8 yrs old already that why... beofre that the caliper is giving problem..
All one knows how to rectify the brake screeching problem? I always encounter this and it doesn't goes off at all. :help:
Aoccdrnig to a rscheearch at an Elingsh uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer is at the rghit pclae. The rset can be a toatl mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae we do not raed ervey lteter by it slef but the wrod as a wlohe
I think it's time to change ya brake pads bro pad wear liao
http://www.honda.co.jp/factbook/motorshow/2003/motor/img/05_09.jpg
My Motto : Ride Fast , Brake Harder
Good In Nature But Evil By My Own Free Will
God's Biggest Mistake Is The Creation Of Man / Now It Has Turned Against HIM
The Worst Thing A Human Being Has To Endure Is Not Being Comfortable In His Own Skin
Sex Is Fun When U Minus The Clothes And Divide The Legs, But Not When You Start MULTIPLYING !!!
I have check it, but its not worn out yet.
try clean ur brake disc rotors,maybe abit dirty.
may is time to do bleeding...
http://img.photobucket.com/albums/v703/kazuhikyo/combination1.jpg
The more I ride my SV, the less I care about going to the annual bike show and looking at new,
or expensive, or exotic machinery. I'm continuing to mod my bike into exactly what I want it,
and enjoying every mile I put on it.
should be ur brake dirty.... the sound is the powder fm the brake pad rubbing on the disc.
All information is provided here with good intentions and to the best of my knowledge and is not liable for any negative effects that might occur due to this information. Thank You.
Take out ur pads and sand them. The rotors sand them as well.
Or change pads.
I recommand Gold Fren from FJT $15 only DIY.
My level presure is inconsistence.
Sometime feel the level pressed a bit it will touch the braking point and sometimes about 3/4 mark before it started to brake.
Anyone have this problems?
I thought brake oil over heating, but sometime even initial when I get the bike cold the presure is like all the way and after which 3/4 mark and the feeling is like haiz...
I bleed the brakes with speed bleeder and motul 5.1 fully syn brake oil.
So shouldnt be there be air inside....
I cleaned the calipers and ensure no piston was strucked.
I sanded the rotors and brake pads.
I mean it still can brake but I dont like the inconsistence feeling..
My brake setup:
Hel brake lines
Motul 5.1 fully syn brake oil
Speed bleeders
Vesrah sintered pads JL series
Pls advice guys!
hello my frend.. u r quite an expert in this..
anyway.. wat is speed bleeder?
braake oil is those dot 4 lah.. dot 5 stuffs right? y yours is motul? is it the same?
i have the same problem.. i found that my front is not stright.. think hit a pot hole in JB. so i adjusted the brake discs to counter this problem.. no choice..
maybe u can check it out too..
Don't DIed WIth RegreTS...
How u adjust ur front dics to counter this problem?
Ur front not straight, check ur tire or wheel bearing.
Speed bleeders -----> http://www.speedbleeder.com/
took out all the brake discs screw.. then tighten all w a bit of torque.. when u turn e wheels.. some area of disc will touch brake pad more when free turning.. u can c n hear.. then tighten more torque in tat area..
final torque is ...130kg.f... i need to check my torque wrench unit again..
speed bleeding just to help bleeding of brakes easier right? if tats the case i leave it to motortiams/...
motul is a brand, dot 4 dot 5 is a industrial standard set to state how much heat the brake fluid can stand, the higher the dot, the higher the temp it can withstand. when we brake, there will be friction cause by the brake pads & disc so there'll be heat gng to the brake fluid, so the brake fluid can't tahan, will break down then the brakes cant work properly already
guess its cheaper over the time lah. then it gurantees a perfect air free seal. unless the motordiam has the proper equipment, if not, they won't be able to bleeding it perfectly
help need ,recently my front brake got this problem ,dont know wats the problem .
brake line is hel . change 2 month onli ,brake pad still got lah .
can it be the brake oil ?care to share ?
http://www.siddham.cn/yuan1/images/mantra_six_2.gif
