Hey guys and gers,
a very² random tut came to my mind..
Anyone of you ever heard of, or tried to mix different brands/quality/type of E.O and use it? If u did or heard, what's the effect on the engine?
Total overhaul or nothing happen? Or tip top performance that let you clock better timing than Rossi on a Ducati 1098? hahahahaha... (Just in case, some of the folks are sensitive, the Rossi thing is just a joke, please stick to topic.)
Don't worry people,... this is just one of my very random thoughts... :cheeky:
Soooooo... anyone?? :angel:
Jul' 01 - Jun '02: Honda 185 XL
Jun' 02 - Mar '03: Yahama 200
May '06 - Oct '07 : Honda CB400 Version 'S'
  • Replies 12
The last time I changed EO, I used 3 bottles of fully synthetic Yamaha EO. Dunno why about a month later, my oil indicator kept lighting up. When I checked my engine oil level, apparently it has become low. Since I cannot find the same Yamaha EO at the nearby bikeshops, I topped up my EO with Shell semi-synthetic EO. To me, there was no difference in the feel of the bike. I've already send my bike for full servicing and it is now at the bikeshop cos I'm doing valve clearance as well. EO changing to now is Amsoil... :)
First learn stand, then learn fly. Nature's rules biker-sans. Not mine...
http://img15.imageshack.us/img15/1859/11superbikesmackdown11.jpg
The more we get together, the FASTER we'll be..
Mar 93 - Oct 94 : TZR125 FF5209R
Oct 94 - May 98 : GSX R400N FK3745K
May 98 - Oct 05 : GSX R400R FN3306D
Oct 05 - June 11 : '02 YZF R1 FBF3637M
June 11 - Feb 19 : '11 ZX10R
Feb 19 - ??????? : '14 S1000RR
so far i onli heard of ppl mix the same brand but diff quality as in the thickness of the EO :)
http://i60.photobucket.com/albums/h10/WesT_Spec-1/DSC00090-1.jpghttp://i60.photobucket.com/albums/h10/WesT_Spec-1/WESTSPEC.jpg
The Light Began to dim.. Music Fading out.. I Begin to Miss You
......................The Visual Cycle..........................
so Aie;s experience and West Spec seems like the answer is yes (its okie to mix EO) huh???
anyone else care to share anymore experiences??
its ok to mix IMHO but note that the EO which has a thicker viscosity will be below the bottle and after long use they will be together as 1 anot i dunno.
Life Is Never Fair.
Some pple slog for the paper in their wallet.
Some slog to feed the paper to the pple w/o the wallet.
when u do ur regular EO change, a percentage of the old oil is left in the engine after draining unless engine overhaul. so when u switch to a different EO u actually mix 2 different EO to a certain degree.
http://i125.photobucket.com/albums/p48/allen_key/KS_400.jpg
means 'In My Honest Opinion'
icic... okk... thanks... sorry ah.... i noob.. hahahaha
so basically wad u r saying is there is actually no harm if someone is to mix engine oils and use it right??
In My Humble Opinion... also can...
if frequent intervals of oil change is done, mix oil should be okie lah...
the honda cub that was on discovery channel didnt die after they put so much rubbish inside .... so... dun worry lah...
'Il rettilineo è una tortura'
i riding S4, not cub la... that's y i worry u see... hahaha
