Hi all,
Not sure is this the correct place to post. But I need help on doing Ghost multicast(dos).
Example:
PC 'a' is my image server. If I want to reclone 2 PCs at the same time, without insert bootdisk to each pc. Is there a way to do it? Thks
  • Replies 6
Yes you can...you need a bootp server for doing this or a DHCP and TFTP server. Using Pre-Boot Execution Environment (PXE) on the clients.
Do google it. I'm sure they have one suitable for your needs. I hope I've given the correct info and didn't leave anything out.
* Suzuki GSR750
Thks Ivikarazi.. sorry I'm noob in IT, I have tried google it but do not understand the step to do it. I only manage to reclone one PC at a time. Do you mind sharing the step how to clone many PC at a time without inserting bootdisc on each PC. Thks
You can try and look at this.
http://www.csc.liv.ac.uk/~greg/ghost4linux/index.html
There are no shortcuts. You may wanna read up on the white papers. Its not as simple as it seems. Its best if you can approach a person that has already done this and learn from him/her personally coz there are many ways to do this. Hope that helps.
* Suzuki GSR750
Thks again IvikaRazi.. maybe I will tried to figure out the link u gave as for my side there nobody to approach. Thks..:)
