hi bros, need some comments. my bike now got a problem with starting.
will have a tick tick sound when press ignition key. so according to the info, it should be battery weak. but i remember the battery changed less than 6 months only.
so i read on n e info states it might be rectifier, but that also less than 6 months old.
so do u all think is battery or rectifier?
the only difference to my bike now is i added LED. but i seldom switch it on. n also, i fixed up all e led on my own n when to mechanic n ask him help to help me connect to the power cause i not sure which one to fix to. he helped me connect the black wire from the led to the black wire in the left side chrome cover there and the other cable which is the red one, he connected onto a nut at the carbon starter there... might this be the problem??? is this set up draining e battery even without switching on the LED???
thanks bros. really appreciate ur help. :)
did he put a fuse...? or else there is a risk of short circuit...
Solution: Its normal.
Reason: Air leakages.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Solution: Retune the carb.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
Problem 24: Where to get visor / assesories after 6.30pm.
Solution: Lim Ah Boy (Kelantan Lane around Jalan besar Hawker centre).
Problem 25: Can Phantom change headlights?
Reason: No reason in particular / cosmetics.
Solution: Yes. Can change and it all depends on your DIY / mech's skill.
Solution: http://www.pinkphantom.com - (Source to get nice headlights)
Solution: LAB - (Source to get nice headlights
Guyz do your phantom have little jerks when going at 120km/hr-140km/hr. something like no petrol felling... Little jerks for a few times then ok already..
I am curious.... how u manage to go all up to 120-140kmph!!
Think my bike will vibrate like crazy even @ 100kmph!!
Haiz... but cant compare lah... mine is old bike n a noob rider... haha
2008-2010 Honda Phantom TA200
2010-2013 Honda CB400 SPEC2
2013 Yamaha YZF-R6
mine is an fv plate. no problems achieving that.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Solution: www.pinkphantom.com - (Source to get nice headlights)
Thank you :angel:
since you are new, have you tried oiling/lubricating your chain? Try with your engine NOT running, press/sit down on your seat and stand. Repeat that to confirm if sound is from suspension.
Might be rear wheel bearing if noise from rear. Or your suspension? Try and follow what I mentioned above to the other dude. :thumb:
wad bout like wen i do free wheeling sometimes.. there a weird sound coming from my bike.. its like a goli(marble) sound, rolling somewhere in the bike..
is it the wheel bearing? but i don encounting anything from turing n stuffs.
:angry:RiDe iF YoU dArE... lOwEr YoU gO... ThE mOrE KiCk yOu Got...BuT mY fOoTrEsT cHuI...o_O
Passed 2B - 18thMar09'
Phantom TA200 - FUxxxxK 24thMar09' to 18thJun11'
RoadWin R125 - FBC****M 23rdJun11'
time to tighten your chain tension dude.. just drop by planet and ah chiong will know.
Help Mate!!! I just came back after Washing my Phantom.. NOtice a NAIL Was in my Back Tyre & There is Air coming out bit by bit.... can u all guys help me Which bike shop to go on 2moro?? cause 2moro is a Holiday, Scare Waste trip going down.. I staying in the West now anyway.... :'(
Reason: Air filter clogged.
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
Hi people,
Hopefully u guys can help me out.. Ive had a TA 200 FW plate for 3 odd years already. Recently, i had a major accident on the PIE when my bike chain DERAILED, got stuck in the rear tyre and i skidded on the expressway. Luckily i suffered minor scratches.. Since then ive been super paranoid regarding my bike chain. My new "heavy duty" bike chain started rattling again a month ago and i got it tightened.. and now its the same problem. I paid 100 for the chain set and sprocket change. Is this problem of chain loosening so common with the TA200 that its better for me to change to another bike? I seriously cannot live with the fear of that accident happening again
Thanks in advance guys, Appreciate it
phantom have this problem of getting a loose chain.. to prevent any mishaps, visually check your chain to make sure its not loose.. lube it often. learn how to tighten it yourself but make sure it isnt too tight..
Hi people,
as with every accident...have we learn anything out of it..??
we need to overcome the phobia and pick ourself up and move on..
the very first question is why did the chain derailed/break??
chains are not made to derailed/break like that...it is make to last until it is too long to use on the bike...
the normal reaction i would say ..hey u did not maintain the chains properly at regular intervals..like cleaning and lubbing it with the correct lub, adjusting the tension etc etc:dozed:
..bad sprockets/chains with bad tensions..are accidents waiting to happen.:(
anyway besides brakes and tyres..chains are the next likely to fail due to lack of maintenace and this part actually needed to be inspected , adjusted at regular intervals or after a ride in the rain or mud..and replaced worn parts when required..
Thanks for the wake up call MrSingh..
Edited by mepkoh
Hi people,
I believe that you neglected your chain and failed to do a pre ride inspection and no, its not a common problem. Have not find the need to tighten my chain after proper lubrication and no gunning.
any idea where do i jet my PK? wanna lub it and i finally got a jet. where do i rest the jet on? pipe? i just wanna lift the back up.
and yes.. maintence is a must. at least once a month.. gosh need to change my sproket soon ;-(
At first I thought you wanna jet your Phantom carb... Then I realised that you meant jack. Yep, jack on pipe. I jack it near the heat shield there, but must make sure nothing heavy in box. If dunno/not sure where/how, next time go planet n observe... :)
pardon me for the poor english spelling ;0
but i jack the pipe , bike will fall on the left and only the front wheels will be lifted up lez... how to just pop the back up and the front still touch the ground?
Haha. It's ok. For your case, it seems that your bike is tail heavy (forgot that you got 3 boxes!). Try emptying the boxes and if that still doesn't work, try putting some load on the handlebar.
oh.. i remove my side boxes already.. so i get my friend to put some weight b4 i lub chain...
cause i seen koon do before. he can lift the back up with effort.. maybe need go back to him for lesson again.
Go to planet and see it get done. Btw chuan, i decided not to get the scissors jack.Have learn the skill to push while lubing at the same time.
is there a better way? share share lez... shi fu!
