Thanks for the information given. It really help me widen my knowledge about bikes especially mine.
Sent my bike for servicing and changed my sprocket, chain and headlight bulb. damage: $96.
I must say after the change, the bike has more power and is silent compared to my old dry chain.
There is engine braking but it does sound like its causing some damage if used at the wrong gear. I didn't know that my 150cc is technically a 300cc.
Hi Shuanneo
Sorry I did not pick up the fact that you have a TA 150.
Hamsterwhale is perfectly correct, your fuel/oilair mixture is delivered through a port which is uncovered by the piston, and the exhaust gas is removed by another port on the opposite side. This reduces the number of moving parts considerably. So you have no worries about a camchain tensioner as it is not fitted to your bike.
AS the TA 150 has 2 power strokes to the TA 200's one it also means your bike is the equivalent of a 300cc 4 stroke, the downside is you have no engine braking.
I re-discovered this fact on the island of Koh Chang several years ago, I was riding down a steep muddy track on a side of a mountain in a rainstorm. The bike kept accelerating (100cc Honda Wave) and I daren't apply the brakes too heavily. No problem I said to my wife, I'll change down, clunk 3rd, no difference apart from the engine increasing revs.
Hmm ok a bit fast but I'll try 2nd, clunk, now the engine is screaming accompanied by my wife, the bike is still accelerating.
I have no idea what speed we achieved going down this slope but somehow managed to keep the bike uprightish, slaloming through a couple of tight bends and luckily up the opposite slope as the 3 three of us were screaming like banshees in unison. Now that my friends was a Heineken moment.
Happy and safe trails
Aitch
although I don't really wish to test it, but I think phantoms can quick-shift upwards at least...
My favourite activity :D
You can quickshift down too. Blip the throttle to match RPMs. Everyone around you will go omgwtfbbq at the sound. Obviously sounds good :D
ah chong is inside a shop called planet, the shop is at ubi
here is a map for your reference:
http://photos.friendster.com/photos/78/20/5760287/2_991007228l.jpg
:cheers:
Thanks VidaK ! :thumb:
2B 181208
i have just replaced my spockets and DID o-ring chain ...cost me 120 bux ...
initially the bike was making some tap tap noise between 3rd - 5th gear ...
Ah Chong was able to pick out the problem immediately after a test ride and now my bike is a lot quieter and smoother.
My brake pump is fixed ! Is actually when installing the brake pad air when into the pump and cos the brake pump unable to function. Learn new things again ~
2B 181208
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
as I have thought so... the process of removing this air is called bleeding the brakes :smile:
Hi Mr Koh,
What's a good way to clear the brake dust from the pads?
Also a general qn:
It seems we have engines that are quite demanding on air; very pressure sensitive so if you overtake a lorry on the e-way you may have experienced a momentary loss of power as the wake turbulence from the larger vehicle takes its toll.
Any solutions for this? Airbox mod is probably out of the picture for most and can result in worse torque if done wrong but I have had success practising some offensive riding :p
Basically, overtaking anyone slowly usually results in the other driver racing you just for the hell of it. So I build up a huge head of speed and zoom past and I notice, hey, if you throttle up and accelerate decisively the intake isn't affected by the turbulence.
Anyways, Phantom riders are such an interesting bunch. Junior TA riders are usually rather careful. It's the uncles who race their Phantom 200s at 120+kph and slice through traffic like Yamaha hell riders :p
Do those uncles have smaller sprockets? Pureice and I conclude that with stock gearing the top gear redlines (ie, you hit rev limiter) at around 130kph indicated. I believe our machines can go significantly faster (or cruise more comfortably & economically) if the 6th gear ratio was smaller.
1. Switched to Motul 3000 on your recommendation and big difference. Whatever engineering they put in this oil really is superior to my previous $6 oil (Castrol 10W40). Engine does not "go rough" at higher RPMs and lose breath.
From your experience would you recommend remaining at Motul 3000 or should I try semisynth next? This is a 7 yr old engine block with lots of new and/or reconditioned parts and run in is more or less complete.
I'll skip the scientific technobabble but I've been given to know that a lighter oil can flow faster at a given pressure and thus perform a better job of reducing friction and transferring heat.
Lighter oils also provide better cold start protection due to lower viscosity at normal air temps. Which means they can start flowing faster than a 50 or 60 weight the moment the motor turns over.
Interestingly, recommended racing oils are almost always of a heavier type than for street use. I guess the 50 and 60 weights are great for high temperature, high stress / RPM conditions such as for local highways.
Looks like I answered my own question :D at least on the oil weightage bit. Synthetic indeed is superior to dino stuff but I'd prefer to always have fresh oil in the crankcase and that means the $10 Motul, changed regularly, is more than good enough for this purpose.
And oil additives are a big no no to me, having read about their development, use, and marketing. Some of them have bad side effects too..
(see, Phantoms are so fun. Can experiment with everything without blowing up :3 )
2. Back to brake pads - seems like there's a screeching sound from the heavily-used front brakes, but both front pads are not even visibly worn. I've taken to "skimming" the brakes with light pressure on the lever to get rid of whatever dust is on the contact area causing the screeching.
Does work as a temporary solution.
3. Need a generic recommendation for cleaning and oiling supplies for a oiled cotton gauze air filter (yep it appears mine has an aftermarket filter). Planet does sell the filter oil but not the cleaner.
Edited by Pandora's Kitten :3
Hi Mr Koh,
Also a general qn:
My preloved phantom 200 could do a 135 kph on a straight road. Now me old uncle already so ride px150 :p
For brake dust, dont be too troubled by it, Just give your brake disc a wash once in a while.
Hi Bros.
Need some advice from pros Bros here..
Recently, there's this "SCREEHING" sound coming out from my left side(REAR).
Guess not the Chain or Spocket. Could it be the WHEEL BALL BEARING?
The sound comes out on and off at times.
Appreciate your help.
Thank you!
Regards
5 Oct 2005 - Jun 2007(SP) FS6059X
18 Jun 2007 - 26 Nov 2007 -> CBR400, L model problematic FJ532*S
26 Nov 2007 - 12 Nov 2011 -> TA200, FV2X2G
12 Nov 2011 - 12 Nov 2012 -> SYM GTS200, FZ99*0D
29 Nov 2012 - 13 July 2015 -> KIA Rio HB 1.4M, SFY*
13 Jul 2015 - 28 Apr 2018 -> Kia Cerato V2 SKT*
28 Apr 2018 till current -> Hyundai Elentra S_trim SLZ*
That is so true - compared to decades ago, the products we have on the shelves today appear to be highly overengineered.
It is indeed 'to each his own' with regards to oil. The motors that come with synthetics from the factory are much more likely to be fire-breathing monsters that run at 17,500rpm, than a 200cc motor that doesn't even come with a horsepower rating...
Syns are always superior oils to dinos regardless, but whether it's prudent to pay 3x more for a Motul full synthetic is up to individual vanity.
For me, a good analogy is whether one should buy the best and greatest Corei7 processor for an office workstation. For the majority of computer users out there in the corporate world, the potential of that powerful processor will never be used.
I didn't buy this bike to go 140kph on the highway (would have chosen TA150 for that) or to race around town doing despatch (rather take the MRT).
That is why I'm perfectly happy with Castrol 10W40 ($6) despite its poor lubrication at higher RPMs, and Motul 3000 20W50 with its smoother performance and better HTHS lubrication is divine.
Of course, one day I'd discover the nirvana of synthetic oil (as some can attest to), but there's no hurry to do so. Better to be happy with what you have and explore at leisure, than to be never satisfied with chasing for what others say is the best and greatest.
Advices pls.....
Thanks
Advices pls.....
Thanks
:cheers:
I had posted this in the current page... :weep:
Solution: Obvious.
Others:
Solution:
- Send to bikeshop.
Solution:
this the updated list dude? :thumb:
  • 3 months later...
hi guys, got my license already!:clap:
I took the bike for a ride today and hor, I dont know it's me or what, It kinda feel like driving lorry for anyone who drove a lorry before.. it's like my speed at 80 plus but the engine was like damn loud and pushing it to close to 90 the handlebar also like a bit vibrating..
When i drove my dad's lorry, max gear and at 80 something, it kinda feel like i'm already pushing the lorry too much.. feels the same with the bike..
And my bike really hard to start.. :(
probably weak battery cos i din really go rev it regularly beforehand.
Edited by hecter85
80+ on ur meter or real speed? its pretty normal for phantom to be like that... as for mine it will get loud n vibrate near 100 (my meter) which is abt 80 for real spd
eh, got such thing one ah.. it's 80+ on meter.. how you tell your speed if not by meter? haha..
I rode in t-shirt and berms, when i stop hor, i thought my hairs on my arms and legs got static.. lol.. Nv experience that when i'm learning bike..
Gear up bro! Dun leave it to chance! Some of us got the scares to proof that it's not worth it, especially for ladies! Ride safe and live to ride another day!
Don't do it to others what you don't want others to do to you! God bless! :cheers:
well said from Pureice ! ;DD Get at least a FF helmet... you got only 1 brain 1 head.. Once gone it's gone..
by stock all our phantom meter are not accurate... so if i see max spd 90 i will go 110 if 80 i go 100... i assume u are not wearing gloves, tts y u might feel a lil numb by the vibration... most of the time wearing glove + jeans will help a lil...
