since learning that clutch shares the engine oil with engine, i now understand why there are EO for cars and EO for bikes, i will stick to bike EO.
yes.. better do man.. haha.. come out with us next outing lahz.. we share with u more ;D
Agree though some might work, it still is too cumbersome as there are already R&D EO for bikes that work already.
Agree - esp with the huge amount of low cost and overengineered (ie, more than good) bike oils in the market it makes no sense to dispute common sense.
Until I find myself in a place where there's little infrastructure and oh no, there's only a selection of Soviet-era stuff lying around!
Then ahh, it's beneficial to know what makes a bike oil a bike oil, what's good for wet clutch and high revs, and so on. Surprise - sometimes you find that products designed for a very different purpose have a very similar composition... and they've been used to run motorcycles successfully as well.
General knowledge - the acquisition thereof and application in everyday life is an art form :D
hi all, recently when i ride, I found myself when i'm stopping at traffic light, i can't kick down to gear 1. I clutch in, and keep depressing the gear lever many times but no change in gear. Then lights change, i have to move off from whatever gear i'm in, which i think is 3rd or 4th gear, dies a few times lo but it give me momentum to continue without changing gear. Safe and Sound. Car never honk me. Probably see my P plate.
2nd incident, also when stopping at traffic light, I want to change to gear 1, and i can't. It stays at Neutral. I kick down to one and then the green Neutral light went away and back. So far I manage to off engine and restart the bike then i'm able to kick down to gear 1. Good thing traffic lights never change. Safe and sound.
All these things dont always happen. Probably might happen 1/10 times. Still i think it's dangerous. Anyone experience this before? Is this my gear lever problem or clutch problem?
Could be some issue somewhere but since bike is still rideable I don't really care about it. Like you say it happens rarely, and only if I stop the bike at gear 5 or something and eventually one of the gears will lock on.
Thus I make a practise of remembering to smoothly downshift as the bike slows.
If I stop the bike from neutral for a short while, chances are that the bike doesn't want to engage 1st until I manually push it forwards slightly... but recently I found engaging 2nd gear then kicking down puts it in first again :D
hi kaylan, well, that's what i did, i tried to gear down but gear wont engage, which is why i ended up in whatever gear i was when stopping. For the neutral one, I tried the 2nd gear downshift but it doesn't help.
Even though it rarely happens, but when it happens at the most awkward situation, like when you're at a turning pocket or stopping on a slope, i think it's quite awkward leh. :cry:
ha... I think its probably a minor problem... just that you haven't gotten used to the quirks of your bike :cheeky:
what is happening is probably that you "clutch in too much", to the point that you can't change your gears... especially for kicking from neutral to gear 1... if you are stationary, try to change gears at half clutch or 3/4 clutch... see if it helps... :smile:
this happens to all bike, not only phantom, what vidak mentions below is the cure...
J. P. Morgan
hi pple. my bike when in 6th gear will have a very loud noise. the noise is like when u have not enuff speed in the certain gear. like going to stall engine. but my speed is at 100 liao. do i need to overhaul liao?
stall the engine...? but when the engine is loud I can't see why the engine might want to stall...
I cannot diagnosis your problem over here, but I'm guessing that your clutch plates are worn out... thats why your engine seems louder than before...
still, it is best to bring the bike to a trusted mechanic to have a look... :cheers:
hey guys,
recently,when i am slowing down my bike,and when the engine brake effect kicks in,there seems to be loud bangs coming from my exhaust.it only happens only like when the engine brake is in effect.i changed my EO 2 weeks ago to Chessa 9000,but this problem surfaced like,3 days ago.any ideas why?
time to go tune your cub ;D
hey guys,
it is very likely that your air fuel ratio for your idling is now too rich, hence you would experience backfiring. just adjust your idling air fuel ratio screw on your carburetor a little clockwise (maybe try 1/4 turn) and see if things improve :smile:
ah,i suspected it was the carb tuning at first,but can the ratio change even if i did not touch the carburator during my last EO change?
of course... over time it is possible that the screw turned on its own because of the bike's vibrations...
ah,i see.thanks alot for the tips,i'll probably tinker around with the carb in the morning.hopefully i know what im doing.lol
ok here is idling (pilot) tuning class in condensed form...
there should only be two adjustment screws visible from the right side... the one sticking out towards the bottom with a knobby black plastic end that you can adjust with your bare fingers is the throttle stop screw... that adjusts the idling speed. the idling air fuel ratio screw (IAFRS) you are looking for should be flat, bronze in colour and it requires a flat head screwdriver to adjust.
turning the IAFRS clockwise makes the idling air fuel ratio richer, while anti-clockwise makes the ratio leaner. too rich = fouled spark plug, too lean = piston gets a hole / piston break off, so err on the side of tuning it rich please.
your objective is to tune it to neutral (balanced). it would be balanced when the idling speed is at the highest point. start by turning the IAFRS clockwise 1/4 turn. does the idling seems faster? turn another 1/4 turn clockwise (total 1/2). idling any faster? although I doubt the idling speed would increase for your case since it seems like your bike is running rich at idling...
so reset the screw to the position it was at (total 0). and slowly turn 1/4 turn anti-clockwise at a time to hear if the idling increases. and find the positions of the screw when the idling seems to be the highest. if you realise that the idling continues to increase when you have turned the IAFRS so much that it is loose / going to drop off, you would have to change to a smaller pilot jet... if that somehow happens then I will explain further in the future...
maybe you will end up feeling that turning the screw anti-clockwise 3/4 turn from 0 and anti-clockwise 1 complete turn have the highest idling speeds, choose the position that is slightly richer. in this case, that would be anti-clockwise 3/4 turn from 0.
with that, your idling air fuel ratio is set neutral. your backfiring should be minimal now.
however, it is possible that your idling speed is now way too high, so lower it by turning the throttle stop screw anti-clockwise to lower the throttle valve. if the idling is still too high after lowering the throttle valve to its lowest position, then hahaha you would have to buy a smaller pilot jet... but I seriously won't expect that to be required... but if that really happens then I will continue my lecture...
:cheers:
Solution: Its normal.
Reason: Air leakages.
Reason: Air filter clogged.
Reason: Fuse may be blown.
Solution: Obvious.
Reason: Water in petrol
Others:
- Check magneto coil.
Solution:
- Send to bikeshop.
Solution:
- 67474740 Tiko cheong.
- 64560018 Wing Yap.
Reason: Gasket Spoilt.
Reason: Speedo spoilt.
Solution: Bike shop.
Reason: Clutch is worn
Solution:Change new bearings.
Problem 21: Weak Battery.
Problem 23: IU Spoilt.
eh i got a problem with kicking to netural gear. Only can kick to netural when my engine stop. The other gear are fine.
Can someone explain to why like that?
thank you
trottle alittle then try kicking again. after sometime the gear box abit worn out already. But still can use de..
sometime is because of the engine oil u use also..
thank you
happened to me before. Try the cheap things first. change eo.check out the reviews on the ta's page
