...hi kelvin, i juz bought a drz with GPR slip on... its quite annoying when i close throttle...it keep backfiring sometimes its really piss me off... can u recommend me what i shud do the bike???
Live life to the fullest...... Be Safe... Be Considerate Like Me.....
  • Replies 318
You have a PM.
Best Regards
Kelvin 87178999
Unique Motorsports Pte Ltd
WL: Zul 84818999
*Unique Motorsports Forum*
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc6/183955_10150099536612106_160394947105_6496094_3621691_n.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc6/180182_10150099539307106_160394947105_6496114_332446_n.jpg
Best Regards
Kelvin 87178999
WL: Zul 84818999
Suzuki DRZ400SM - Performance Parts, Accessories & Servicing Packages
http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs595.snc3/31342_392758292105_160394947105_4229354_5372555_n.jpg
Servicing Packages for Suzuki DRZ400SM
Link to Servicing Packages for Suzuki DRZ400SM
Tyres for Suzuki DRZ400SM
Link to Tyres for Suzuki DRZ400SM
Sprockets + Chain
DID X Ring Chain + JT sprockets: $200
DID X Ring Chain + Original Sprockets: $260
DID X Ring Chain + DRIVEN sprockets: $280
DID X Ring Chain + ISA Sprockets: $280
DID X Ring Chain + AFAM Sprockets: $280
DID X Ring Chain + Supersprox Sprockets: $280
EK MVXZ Coloured X Ring Chain + DRIVEN/ISA/AFAM/Supersprox sprockets: $340
Air Filter
K&N: $105
BMC: $154
Street Legal Exhaust
Scorpion Full System: $1080 (New Model)
Delta Full System: $1050
WRP slip on aluminium : $890
WRP slip on Titanium: $1090
WRP slip on Titanium / carbon tip: $1290
Leovince slip on: $694.80 (UP $772)
Leovince Headers: $481
Leovince Full System: $1127.70 (UP$1253)
Yoshimura Titanium Oval Full System: $1880
Brakes/ Control
STAR Performance Brake lines: $110 (UP $130)
HEL brake lines + installation: $130
Venhill brake lines + installation: $230
Brake pad (WP, Gold Fren, Fizz Power, EBC, BRAKING etc): $25 to $75
BRAKING Front SK Disc 320mm: $510
BRAKING brake Caliper bracket for 320mm brake disc for OEM caliper: $110
BRAKING brake Caliper bracket for 320mm brake disc for BRAKING caliper: $110
BRAKING Rear Disc: $240
BRAKING 16mm Master Pump with lever: $470
BRAKING 16mm Master Pump with lever + BRAKING Reservoir:$ 480
BREMBO RCS15 Master Cylinder: $550
BREMBO RCS19 Master Cylinder: $550
BREMBO 16mm Master Pump Assembly: $288
BREBMO 16mm Master Pump Assembly + Clutch Assembly: $388
Motovation Products
- Motovation fork and axle sliders: $110
- Motovation heavy balancer with barend sliders : $75
- Motovation IMS Footpegs Sliders: $65
Others:
- JD Jettings for DRZ400SM: $180
- JD Jettings for DRZ400SM FCR 39mm carburetor: $180
- Keintech Fuel screw: $35
- 3 x 3 modifications: $35
- PAIR removal: $35
- ThumperTalk Manual Cam Chain Tensioner: $95
- Trial Tech Vapor Speedometer: $350
- Trial Tech Endurance Speedometer: $220
- LED signal lamps: $50 to $75
- LED tail lamp Acerbis red: $75
- LED tail lamp Acerbis white: $110
- Ohlins fork springs + dust covers + oil seals + Fuchs Silkolene fork oil + installation: $320
- Ohlins fork springs + dust covers + oil seals + Ohlins fork oil + installation: $400
- Ohlins rear shocks with installation: $1364
- DRIVEN Handlebar FATBAR: $150
- Renthal handlerbar (7/8): $130
- Renthal FATBAR: $180
- Renthal handlebar pad: $25
- Pivot Voltage Stabliser (made in Japan) $90
- Pivot Voltage Stabliser with Super Earth Cables (made in Japan) $148
- Revtec Impedance Stabiliser: $90
- Safari Fuel Tank 17 litres: $790
- Safari Fuel Tank 28 litres: $1090
- Broquet Fuel Charger B/2T: $59
- Broquet Fuel Charger B/3T: $80
- Samco Sports Silicone Hoses: $161 (DIY)
- Samco Sports Silicone Hoses + installation + Engine Ice: $211
- MR Digital voltmeter $55
- Dynamyx Digital Voltmeter: $55
- Stebel Twin Tone Horns (2pcs) + relay + installation: $65
- Stebel Nautilus Compact Horn (1pc): $85
- Hella Disc-Type Horns (2pcs) + relay + installation: $65
- Hella Twin Tone Horns (2pcs) + relay + installation: $65
- KTM 200 Headlight Assembly: $210
- KTM 200 Front Fender: $90
- Acerbis Supermoto handguard: $210
- Acerbis Multiplo "E" handguard: $230
- LED Vision headlight: $120
- WRP Wide Foot Pegs: $190
- Rough & Road 591 Rally Rack: $280
- IMS "Super Stock" Foot Pegs: $95
- IMS "Pro-Series" Foot Pegs: $120
-ASV F-1 Unbreakable Brake Lever :$85
-ASV F-1 Unbreakable Clutch Lever: $85
-ASV F-1 Unbreakable Brake and Clutch Lever Pair Pack: $135 (UP $170)
-ASV F-3 Unbreakable Brake Lever :$120
-ASV F-3 Unbreakable Clutch Lever: $120
-ASV F-3 Unbreakable Brake and Clutch Lever Pair Pack: $200 (UP $240)
-ASV C-5 Unbreakable Brake Lever :$150
-ASV C-5 Unbreakable Clutch Lever: $150
-ASV C-5 Unbreakable Brake and Clutch Lever Pair Pack: $240 (UP $300)
- Zeta Brake Lever: $95
- Zeta Clutch Lever: $95
- Zeta Amor Hand Guards: $180
- DRC Tail Lamp (Fender Eliminator) $145
- Trail Tech Striker: $350.00
- ThumperTalk Case Shields Ignition / Clutch Combo Pack $70 with installation
- DRIVEN coloured sprocket nuts $45
*Please check 1st post of this thread for latest updated pricelist. Thank you.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi there,
I'm riding DRZ400SM, need your help:
1. Can your mechanic tune my rear suspension higher + harder? If yes, how much & how long will it take?
2. How much is ur Braking Brake Disc & Brembo?
3. Venhill brake hose (front / rear)
Stay Fresh Always! :thumb:
hi,
Do you have ferodo sinistered brake pads for brembo 4 pot caliper?
Or which brake pads do you recommend for it?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
Hi there,
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
bro..service carburetter for drz how much?
You have a PM
Best Regards
Kelvin 87178999
WL: Zul 84818999
hey kelvin..wanna inquire..u gt drz big bore kit?can qoute me the price..hope to hear frm u soon
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
How much with installation?
My Rides
Gilera VXR200(2007-2009)
Kawasaki KRR150(2009-2009)
Suzuki K9 DRZ400sm(2009-Present)
Honda Wave125S(2010-Present)
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
May i noe this consists of changin of wat? Just the brake fluid container or wat?
And how much?
And also do u carry fcr 39mm keihin carb?
02 June 06 - 25 July 09.
-------kr150 FY941*K-------
25 July 09 - 10 June 10
-------Super4 SpecIII FBC6*94T-------
10 June 10 - 11 April 11.
-------YZF R6 10 FBE5*46P-------
11 April 11 - 8 August 12
-------DRZ SM400 FBC25*7D-------
8 August 12 - Present
-------YZF R1 07 FS35*5H-------
And how much?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
how much is it for a ktm short fender now? and jus wana enquire do you have any asv shorty lever in store if yes can u quote me the price?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
hi...can you quote me the price for the braking front disc and the brembo brake caliper is how much?
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
do you bring in fcr 39mm keihin carb,drz big bore kit and remus pipe? how much it will cost and have stock? thank you..
You have a PM.
Best Regards
Kelvin 87178999
WL: Zul 84818999
  • 5 weeks later...
is the abv item solely fo drz? any chance it cld fit an XRV750?
