Fixing a Temperature meter/gauge/monitor for bikes that do not come with it (Eg: S4)
Hi all,
Not sure if someone has asked this before or not, but I cant seem to find any info on this:
Where can we fix a temperature gauge/meter for bikes that do not come with it? Eg: Super Four, etc.
I know that for bikes without the temperature gauge, there is usually a warning light if the engine is overheating. But I am looking at installing a temperature gauge so that I can monitor the engine's temperature for long distance riding at high speed, etc.
Any ideas on where I can fix it, and the costs?
arigato!
From Honda's manual:
The motorcycle presents you a challenge to master the machine, a challenge to adventure. You ride through the wind, linked to the road by a vehicle that responds to your commands as no other does...
  • Replies 39
Hi all,
arigato!
I am interested to know too
exige thanks for tagging!
Kawasaki 150ZX ::Rusty:: 2005-2010
Honda CB400 Revo ::BlackBeauty:: 2010-20XX
|Biologic iPhone Mount|Stebel Nautilus Horn|K&N Air Filter|
|Ah Pek's Grounding Wire|DIY 5V USB Port|Scorpio SR-i900|
|DIY Secondary Strobe Brake Leds|
http://desmond.yfrog.com/Himg697/scaled.php?tn=0&server=697&filename=pf6.png&xsize=640&ysize=640
at0m87, Iceachilles,
No problem!
Lets hope we can find some answers together from here
Got one device that can measure that and more...Digitally....I know MW has it.
http://www.acv.co.jp/01_product/active_digitalmonitor/ph7.jpg
http://www.acv.co.jp/01_product/active_digitalmonitor/ph8.jpg
http://www.acv.co.jp/01_product/active_digitalmonitor/ph6.jpg
OR ...Cheaper alternative...Temperature sticker. I still got a few left when I bought it over in US.
http://www.amazon.com/gp/product/images/B001PNQGEK/ref=dp_image_0?ie=UTF8&n=15684181&s=automotivehttp://www.amazon.com/gp/product/images/B001PNQGEK/ref=dp_image_0?ie=UTF8&n=15684181&s=automotivehttp://ecx.images-amazon.com/images/I/41AFCr-WLoL._SS500_.jpg
Edited by IvikaRazI
* Suzuki GSR750
Hi all,
arigato!
you can probably modify a digital temperature meter to read off the temperature from the bike. It will not be difficult but it will test your DIY skill and squeeze your brain juice.
An easier method and also not too expensive is to get the get the Trailtech Vapor Meter.
http://trailtech.net/adventure_vapor_kits.html
It comes standard with a temperature kit for water-cool bikes. It will involve cutting your radiator hose, and insert a T-joint in which the sensor is located, and wire in to the meter, you will have temperature reading on the Vapor meter. You can also set the upper temperature reading so that it will warn you when it reaches that level.
For air-cool bikes, there are other temperature sensor kits but these must be bought separately. There is kit to tap temperature from the spark plugs, from the engine oil, etc.
:p
Count me in!!!! =p
Tagged! ;-)
Thanks IvikaRazI~
Do you remember how much will it cost? This digital meter looks neat. I shall go MW check it out one of the days.
For the temperature sticker, where do you stick it on? The side of the radiator?
Reminds me of a similar type of sticker I used to stick on my fish tank.
:p
Thanks Demon for the info! I guess the first method is quite out for me. Unless maybe I get Cypher (fellow S4 biker here) to help me with it. haha.. I shall go check out MW and compare the display they have versus the Vapor Meter. Both looks good and can give me the data I want.
Thanks IvikaRazI~
I hope nothing too ex. I dun mind diy so long I know the place to get all the items and some simple guide. Ya, that sticker sure remind me of my dad's fish tank temp sticker. hahaha
Thanks IvikaRazI~
The LCD one .... be prepare to fork out money hahhaha
Actually the stickers juz stick to the radiator. So far been quite accurate or at least you know roughly how hot it is.
* Suzuki GSR750
I'm just going to head to Tangs and get myself a nice oven thermometer and wedge the darn thing in my engine compartment. ($10?) Of course, there's no way to read the temperature on the move, but most of my riding is start-stop city stuff and the gauge is there to give an indication of how lean I can run for the day... possibly more precise than using my ears and nose to estimate fuel/air ratio :3
For proper steampunk effects, I could even have a few oven thermometers stuck onto the cylinder head, block, exhaust manifold and crankcase :D
Now, where do I get a vacuum gauge to monitor my DIY forced induction system...
Ohh ya this is the readings I took last year from the sticker. It still works till this day.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc1/hs216.snc1/8322_171414756773_633266773_3612745_4543759_n.jpg
* Suzuki GSR750
Ok, I just visited Motorworld earlier and saw the Digital meter IvikaRazI mentioned.
Yeah.. its not cheap. The guy there quoted me $280 for the meter, including installation but excluding the temperature sensor.
The temperature sensor is out of stock at the moment. Said to cost about $60-80. This sensor will measure the temperature by intersecting your radiator and radiator hose.
So in total, it looks like it's gonna cost between $340-$360.
BUT.. before I left, the guy showed me another device. This one should be made in Taiwan if I'm not wrong. Its not as high-tech as the $280 display. This small one displays only the temperature and it comes together with a sensor. Best of all, this kit only costs $60 including installation! Cheap and good. Just nice for what I want too.
BUT... this sensor is not installed between the radiator and radiator hose. It is to be fixed at the place where the S4's original temperature sensor is. The PROBLEM is..... urghh... this sensor is slightly longer than the S4's original sensor... and the mechanic was unable to get the sensor screwed on. After trying in vain for sometime, he proposed that I either wait and get the more expensive display and sensor, or I bring my bike another day (I reached MW at 7pm+ just now), he try to help me diy/mod the sensor to fix it between the radiator and radiator hose.
So now I'm back at home contemplating my options. I guess if the $60-80 sensor stock comes in, maybe I'll buy the $60 taiwan kit, and pair it with the $60-80 sensor? It wont be as cheap, but its still as good? Hmmm....
how accurate are the readings taken from this temp sticker? which part of the radiator do you paste it at?
Class 2B - 26/03/2009
Class 2A - 01/06/2010
Class 3 - 10/07/2009
Rides(s)
1) Honda TA150 - 20/04/2009 to 31/08/2014
2) Honda CB400 Ver S - 12/07/2014 to ???
These stickers are actually used on scramblers to monitor temperature. So most places that does not exceed 120 degrees celcius would be fine. Juz stick to the radiator's metal section lor. Where else to stick. On the fins I dont think will stick firmly.
* Suzuki GSR750
Wah.. bro super ex sia. hahaha.
You are right, the location needs to be thermally conductive (clean, bare metal surface) and as smooth as possible for an accurate reading.
Mind PMing me the source/cost of the stickers? Locally available?
Today went to a hardware shop and saw a infra thermometer gun selling from $95~$130. No doubt cannot monitor during riding but after stopping and point and shoot. hahaha. much cheaper. Anybody got a cheaper method?
Only source.....amazon.com. I still got a few left with me.
* Suzuki GSR750
yea.. Its pretty pricey. And I'm somehow worried about the digital meter being vandalised / stolen if I were to install it.
hoho.. how much did you get it for? If its not too expensive, I don't mind getting one from you. Do PM me if ok?
Am rather tied down with work recently. But I will continue to source for other cheaper alternatives on engine temperature monitoring..
any idea what is the brand of the meter? any website that can get better details of specs?
The meter I saw was basically similar to what IvikaRazI has posted in #6:
http://www.singaporebikes.com/forums/showthread.php/301645-Fixing-a-Temperature-meter-gauge-monitor-for-bikes-that-do-not-come-with-it-(Eg-S4)?p=6683876&viewfull=1#post6683876
If not, I guess you can check out the other display Demon has posted:
:p
